POV-Ray : Newsgroups : povray.text.scene-files : Source for 'More fun with displace warps' Server Time
15 May 2025 07:05:24 EDT (-0400)
  Source for 'More fun with displace warps' (Message 1 to 1 of 1)
Subject: Source for 'More fun with displace warps'
Date: 18 Dec 2000 12:25:59
Message: <3A3E48A4.D28550B1@gmx.de>
This is the pigment code for the pictures posted in p.b.i.
You can play around with nearly everything in those pigments to get new
interesting results.
// Begin POV-Code
// Christoph Hormann, December 2000 <chr### [at] gmxde>
#declare P_Base_1=
      spherical
      scallop_wave
      pigment_map {
        [ 0.00 quilted
               color_map {
                 [ 0.0 color rgb<0.100, 0.000, 0.200> ]
                 [ 0.3 color rgb<0.000, 0.000, 0.300> ]
                 [ 0.6 color rgb<0.000, 0.000, 0.000> ]
               scale 0.8
        [ 0.005 quilted
               color_map {
                 [ 0.0 color rgb<0.200, 0.100, 0.500> ]
                 [ 1.0 color rgb<0.000, 0.000, 0.100> ]
               scale 0.8
        [ 0.50 quilted
               color_map {
                 [ 0.0 color rgb<1.000, 0.456, 0.456> ]
               scale 0.8
        [ 0.60 quilted
               color_map {
                 [ 0.0 color rgb<0.256, 0.230, 0.800> ]
               scale 0.8
        [ 0.80 quilted
               color_map {
                 [ 0.0 color rgb<1.000, 0.800, 0.200> ]
               scale 0.8
      scale 5.4
#declare P_Warped_1=
      P_Base_1
      warp {
        black_hole 0, 3
        strength 1
        falloff 3
      warp {
        black_hole 0, 4
        strength 1
        falloff 3
      warp {
        black_hole 0, 5
        strength 1
        falloff 3
      warp {
        displace {
          spiral1 6
          sine_wave
          color_map {
            [0.0 color rgb -10 ]
            [1.0 color rgb 16 ]
          scale 5
          type 1
      warp {
        displace {
          spiral1 6
          sine_wave
          color_map {
            [1.0 color rgb 16 ]
          scale 5
          type 1
#declare P_Warped_2=
      P_Base_1
      warp {
        displace {
          spiral1 7
          color_map {
            [1.0 color rgb 16 ]
          scale 5
          type 1
      warp {
        displace {
          spiral1 7
          color_map {
            [0.0 color rgb 16 ]
            [1.0 color rgb -10 ]
          scale 5
          type 1
#declare P_Warped_3=
      P_Base_1
      warp {
        displace {
          spiral1 7
          triangle_wave
          color_map {
            [1.0 color rgb 16 ]
          rotate 180*x
          scale 6
          type 1
      warp {
        displace {
          spiral1 7
          color_map {
            [0.0 color rgb 16 ]
          scale 5
          type 1
#declare P_Warped_4=
      P_Base_1
      scale 0.6
      warp {
        displace {
          spiral2 5
          color_map {
            [0.0 color rgb -1 ]
            [1.0 color rgb 16 ]
          scale 5
          type 1
      warp {
        displace {
          spiral2 5
          color_map {
            [0.0 color rgb -1 ]
            [1.0 color rgb 16 ]
          scale 5
          type 1
      scale 1/0.6
// End POV-Code
