POV-Ray : Newsgroups : povray.text.scene-files : Source code for bevelled box Server Time
31 Oct 2024 08:18:39 EDT (-0400)
  Source code for bevelled box (Message 1 to 7 of 7)
Subject: Source code for bevelled box
Date: 10 Oct 2000 20:14:07
Message: <39E3AFCA.B8FB8283@online.no>
Here's my "Total Overkill" code for calculating position of corners for
a bevelled box.
This is a reply to  Greg M. Johnson's post "truncated cubes" to
povray.binaries.images  6. October:
news://news.povray.org/39DDC1B9.8637A48C%40my-dejanews.com
news://news.povray.org/39E1B9BD.60A199EA%40my-dejanews.com
Note: This code does not bevel any convex shape of plane intersections.
(But some of the macros below could be useful when writing code that
does this.)
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
// Copyright 2000 by Tor Olav Kristensen
// mailto:tor### [at] hotmailcom
// http://www.crosswinds.net/~tok/tokrays.html
#version 3.1;
global_settings { ambient_light color White }
#declare infinite = 100000;
#declare nothing = 1/infinite;
#declare less = -nothing;
#declare more = +nothing;
//#declare smaller = 1 + less;
//#declare bigger  = 1 + more;
// The macros that do the "dirty" work
// Scalar Triple Product of 3 vectors
#macro S3Prod(v1, v2, v3)
  vdot(v1, vcross(v2, v3))
#end // macro S3Prod
// Find the intersection of 3 planes
#macro pl2pl2pl(pPlane1, vPlane1, pPlane2, vPlane2, pPlane3, vPlane3)
  ((vdot(pPlane1, vPlane1)*vcross(vPlane2, vPlane3) +
    vdot(pPlane2, vPlane2)*vcross(vPlane3, vPlane1) +
    vdot(pPlane3, vPlane3)*vcross(vPlane1, vPlane2))/
    S3Prod(vPlane1, vPlane2, vPlane3))
#end // macro pl2pl2pl
// Make a convex shape by intersection of planes
#macro MakeConvex(PlaneNormals, PlaneDistances)
  #local NrOfPlanes = dimension_size(PlaneNormals, 1);
  #local PlaneCnt = 0;
  intersection {
    #while (PlaneCnt < NrOfPlanes)
      plane { PlaneNormals[PlaneCnt], PlaneDistances[PlaneCnt] }
      #local PlaneCnt = PlaneCnt + 1;
    #end // while
#end // macro MakeConvex
// Determine if there are any planes between a point and origo
#macro PlaneUnder(p0, PlaneNormals, PlaneDistances)
  #local PointDist = vlength(p0);
  #local CloserPlane = false;
  #local Cnt = 0;
  #while(Cnt < NrOfPlanes & !CloserPlane)
    #local PlaneDist = PlaneDistances[Cnt];
    #if (PlaneDist < PointDist)
      #local vPlane = vnormalize(PlaneNormals[Cnt]);
      #local DOT = vdot(p0, vPlane);
      #if (DOT > 0)
        #local CloserPlane = (PlaneDist + more < DOT);
      #end // if
    #end // if
    #local Cnt = Cnt + 1;
  #end // while
  CloserPlane
#end // macro PlaneUnder
// Find all possible corners at the intersections of every triple
// of non-parallel planes and test each of them to see if they are
// "false" (i.e. with a plane "below"). Write all the real ones to
// a file. Write to another file which 3 planes each of the "real"
// corners are in the intersection of. Return the number of "real"
// corners found
#macro WriteCorners(PlaneNormals, PlaneDistances,
                    MapFileName, CornerFileName)
  #fopen MapFile MapFileName write
  #fopen CornerFile CornerFileName write
  #write (CornerFile, " \n")
  #write (MapFile, " \n")
  #local CornerCnt = 0;
  #local PlaneCnt0 = 0;
  #while (PlaneCnt0 < NrOfPlanes - 2)
    #local vPl0 = PlaneNormals[PlaneCnt0];
    #local PlaneCnt1 = PlaneCnt0 + 1;
    #while (PlaneCnt1 < NrOfPlanes - 1)
      #local vPl1 = PlaneNormals[PlaneCnt1];
      #local PlaneCnt2 = PlaneCnt1 + 1;
      #while (PlaneCnt2 < NrOfPlanes)
        #local vPl2 = PlaneNormals[PlaneCnt2];
        #if (S3Prod(vPl0, vPl1, vPl2) != 0)
          #local pPl0 = PlaneDistances[PlaneCnt0]*vnormalize(vPl0);
          #local pPl1 = PlaneDistances[PlaneCnt1]*vnormalize(vPl1);
          #local pPl2 = PlaneDistances[PlaneCnt2]*vnormalize(vPl2);
          #local pCommon = pl2pl2pl(pPl0, vPl0, pPl1, vPl1, pPl2, vPl2);
          #if (!PlaneUnder(pCommon, PlaneNormals, PlaneDistances))
            #write (CornerFile, pCommon, ",\n")
            #write (MapFile, <PlaneCnt0, PlaneCnt1, PlaneCnt2>, ",\n")
            #local CornerCnt = CornerCnt + 1;
          #end // if
        #end // if
        #local PlaneCnt2 = PlaneCnt2 + 1;
      #end // while
      #local PlaneCnt1 = PlaneCnt1 + 1;
    #end // while
    #local PlaneCnt0 = PlaneCnt0 + 1;
  #end // while
  #fclose MapFile
  #fclose CornerFile
  CornerCnt
#end // macro WriteCorners
// Read numbers or vectors from a text file into an array
// Note: There's no check for nr of items in the file or the size of
// the array.
#macro ReadFileToArray(FileName, Array)
  #local NrOfItems = dimension_size(Array, 1);
  #fopen ReadFile FileName read
  #local Cnt = 0;
  #while (Cnt < NrOfItems)
    #read (ReadFile, Temp)
    #declare Array[Cnt] = Temp;
  #end // while
  #fclose ReadFile
#end // macro ReadFileToArray
// Output the components of a 3D vector to the debug window
#macro PrintVector(v0)
    #debug "<"
    #debug str(v0.x, 9, 6)
    #debug ", "
    #debug str(v0.y, 9, 6)
    #debug ", "
    #debug str(v0.z, 9, 6)
    #debug ">"
#end // macro PrintVector
// Put spheres at every point in the array
#macro PlotCorners(CornerArray, Radius)
  #local NrOfCorners = dimension_size(CornerArray, 1);
  union {
    #local Cnt = 0;
    #while (Cnt < NrOfCorners)
      sphere { CornerArray[Cnt], Radius }
    #end // while
#end // macro PlotCorners
// Output the data for the planes given by the two arrays to the
// debug window
#macro ListPlanes(PlaneNormals, PlaneDistances)
  #debug "\n"
  #local Cnt = 0;
  #while (Cnt < NrOfPlanes)
    #debug "\nPlane No. "
    #debug str(Cnt, 3, 0)
    #debug "  Normal vector: "
    PrintVector(PlaneNormals[Cnt])
    #debug "  Distance from origo: "
    #debug str(PlaneDistances[Cnt], 0, -1)
  #end // while
  #debug "\n"
#end // macro ListPlanes
// Output the data for the corners given in the two arrays to the
// debug window
#macro ListCorners(CornerMapArray, CornerArray)
  #debug "\n"
  #local NrOfCorners = dimension_size(CornerMapArray, 1);
  #local Cnt = 0;
    #local CI = CornerMapArray[Cnt];
    #debug "\nCorner No. "
    #debug str(Cnt, 4, 0)
    #debug ":  Plane "
    #debug str(CI.x, 3, 0)
    #debug " & Plane "
    #debug str(CI.y, 3, 0)
    #debug " & Plane "
    #debug str(CI.z, 3, 0)
    #debug "  Common point: "
    PrintVector(CornerArray[Cnt])
  #end // while
  #debug "\n"
#end // macro ListCorners
// Parameters for the bevelled box
#declare L = 3; // Length
#declare H = 1; // Height
#declare W = 2; // Width
#declare BevelSize = 0.1;
//#declare BevelSize = BevelSize/sqrt(2);
#declare SphereRadius = 0.03;
// Initialize arrays for the needed planes
#declare NrOfPlanes = 18;
#declare ArraysOfNormals =
array[NrOfPlanes]{
   +x,   +y,   +z,
   -x,   -y,   -z,
  +x+y, +x+z, +y+z,
  +x-y, +x-z, +y-z,
  -x+y, -x+z, -y+z,
  -x-y, -x-z, -y-z
#declare ArrayOfDistances = array[NrOfPlanes]
#declare Cnt = 0;
  #declare vN = ArraysOfNormals[Cnt];
  #declare ArrayOfDistances[Cnt] =
    vdot(vnormalize(vN), vN*<L, H, W>)/2 - (Cnt < 6 ? 0 : BevelSize);
  #declare Cnt = Cnt + 1;
#end // while
ListPlanes(ArraysOfNormals, ArrayOfDistances)
// Call the macros
#declare NrOfCorners = WriteCorners(
                         ArraysOfNormals,
                         ArrayOfDistances,
                         "PlaneTriples.txt",
                         "Corners.txt"
#declare ArrayMapOfCorners = array[NrOfCorners]
#declare ArrayOfCorners    = array[NrOfCorners]
ReadFileToArray("PlaneTriples.txt", ArrayMapOfCorners)
ReadFileToArray("Corners.txt", ArrayOfCorners)
ListCorners(ArrayMapOfCorners, ArrayOfCorners)
object {
  MakeConvex(ArraysOfNormals, ArrayOfDistances)
  pigment { color Grey }
object {
  PlotCorners(ArrayOfCorners, SphereRadius)
  pigment { color Red }
background { color Blue/2 }
light_source { <4, 3, -5>*10 color 1.2*White }
  location <2, 1, -2>*1.2
  look_at <0, 0, 0>
Subject: Re: Source code for bevelled box
Date: 10 Oct 2000 21:19:13
Message: <39E3C12C.29AA9B11@erols.com>
> for a bevelled box.
If all you want to do is make a bevelled box, use the BevelBox()
macro from my Throughly Useful Macros file.
  http://users4.50megs.com/enphilistor/macs.htm
The macro intersects three boxes to produce the beveled box;
the code is much neater.
This acutally produces the determinant of the matrix formed by the
three vectors.
John
ICQ: 46085459
Date: 11 Oct 2000 12:17:30
Message: <39E49199.E9485C80@online.no>
> > for a bevelled box.
Yes, my solution is much too complex to be useful for making a
bevelled box.
But since he asked about the coordinates for the corners,
and since I was working on some macros that dealt with such
problems, I just tried to put them together in a way that solved
his problem
I agree that this is a much more efficient way to make a bevelled box.
> three vectors.
Yes, I know.
Regards
Tor Olav
Date: 11 Oct 2000 20:44:20
Message: <39E50A81.BA7FCC50@erols.com>
> > three vectors.
> Yes, I know.
Okay, it's just that I'd never seen it called the "scalar triple
product."
John
ICQ: 46085459
Date: 11 Oct 2000 21:14:40
Message: <39E50F85.26415E5@online.no>
> > for a bevelled box.
I have had a little look at your BevelBox macro.
It's a nice way to make a I bevelled box.
But I have a optimalization to suggest for you.
I belive that if you rewrite it like this:
#macro BevelBox(Start,End,Bevel)
  #local pS=Start+<0,0,0>;
  #local pE=End+<0,0,0>;
  #local sB=Bevel/sqrt(8);
  #local vC=(pS+pE)/2;
  #local vD=<abs(pS.x-pE.x),abs(pS.y-pE.y),abs(pS.z-pE.z)>/2;
  #local xE=(vD.y+vD.z)/2-sB;
  #local yE=(vD.x+vD.z)/2-sB;
  #local zE=(vD.x+vD.y)/2-sB;
  intersection {
    box { -1,1 matrix <vD.x,0,0, 0,xE,xE, 0,-xE,xE, vC.x,vC.y,vC.z> }
    box { -1,1 matrix <yE,0,-yE, 0,vD.y,0, yE,0,yE, vC.x,vC.y,vC.z> }
    box { -1,1 matrix <zE,zE,0, -zE,zE,0, 0,0,vD.z, vC.x,vC.y,vC.z> }
    bounded_by { box { pS,pE } }
then it will have 2 less divisions and 1 less addition and 1 less
subtraction.
This is how I would have done it (if I were to use your method):
#macro BevelledBox(pCorner1, pCorner2, sBevel)
  #local vB=(pCorner2-pCorner1+<0,0,0>)/2;
  #local vD=<abs(vB.x),abs(vB.y),abs(vB.z)>;
  #local vE=(<vD.y+vD.z,vD.x+vD.z,vD.x+vD.y>-sBevel/sqrt(2)*<1,1,1>)/2;
  intersection {
    box { -1,1 matrix <vD.x,0,0,0,vE.x,vE.x,0,-vE.x,vE.x,0,0,0> }
    box { -1,1 matrix <vE.y,0,-vE.y,0,vD.y,0,vE.y,0,vE.y,0,0,0> }
    box { -1,1 matrix <vE.z,vE.z,0,-vE.z,vE.z,0,0,0,vD.z,0,0,0> }
    bounded_by { box { -vD,vD } }
    translate pCorner1+vB
#end // macro BevelledBox
I haven't done much testing, but it seems to do the same.
Tor Olav
Date: 11 Oct 2000 21:19:17
Message: <39E51098.DA713AC0@online.no>
> > > three vectors.
> > Yes, I know.
> product."
http://mathworld.wolfram.com/ScalarTripleProduct.html
http://www.torget.se/users/m/mauritz/math/vect/determ.htm
Tor Olav
Date: 12 Oct 2000 09:26:58
Message: <39E5BC20.1D8ED209@erols.com>
> subtraction.
Hmm.  I never worry too much about parsing speed.  My current IRTC
entry, for instance, has a shot that takes 3 minutes to parse for each
frame, which is the longest that any non-experimental scene of mine
has taken to parse.  Usually my parsing is done in ten to fifteen
seconds.
John
