![](/i/fill.gif) |
Below is the source code for an image I posted 5. September to the
povray.binaries.images news group; "Fibonacci Stones":
news://news.povray.org/39B44A76.2ECBA98A%40online.no
(The image shows my "AnitBlobs" in a Fibonacci pattern)
For this image I borrowed some code from Alf Peake's post
"Golden Ratio" to this group 31. August:
news://news.povray.org/39ad9be0%40news.povray.org
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
// Copyright 2000 by Tor Olav Kristensen
// mailto:tor### [at] hotmail com
// http://www.crosswinds.net/~tok/tokrays.html
#version 3.1;
#default {
finish {
phong 0.6
phong_size 100
diffuse 0.6
// Macros
#macro Tilt(Thing, Vector)
#local xAngle = (Vector.z < 0 ? -1 : 1)*
degrees(acos(vnormalize((x + z)*Vector).x));
#local yAngle = degrees(acos(vnormalize(Vector).y));
object {
Thing
rotate xAngle*y
rotate -yAngle*z
rotate -xAngle*y
#end // macro Tilt
#macro AntiBlobs(CtrArray, RadArray, StrArray, Trh, BlbArray)
#local NrOfBlobs = dimension_size(CtrArray, 1);
#local CntA = 0;
#while (CntA < NrOfBlobs)
#local CtrA = CtrArray[CntA];
#local RadA = RadArray[CntA];
#local StrA = StrArray[CntA];
#declare BlbArray[CntA] =
blob {
threshold Trh
sphere {
CtrA, RadA
strength StrA
#local CntB = 0;
#while (CntB < NrOfBlobs)
#if (CntA != CntB)
#local CtrB = CtrArray[CntB];
#local RadB = RadArray[CntB];
#local Dist = vlength(CtrB - CtrA);
#if (Dist < RadA + RadB)
#local PowA = pow(1 - pow(Dist/2/RadA, 2), 2);
#local PowB = pow(1 - pow(Dist/2/RadB, 2), 2);
#local NStrB = -abs((StrA*PowA - Trh)/PowB);
sphere {
CtrB, RadB
strength NStrB
#end // if
#end // if
#local CntB = CntB + 1;
#end // while
#local CntA = CntA + 1;
#end // while
#end // macro AntiBlobs
// Some of the code here are borrowed from Alf Peake
#declare phi = (sqrt(5) - 1)/2;
#declare Inc = phi*360;
#declare Offset = 0.5;
#declare MaxCount = 400; // Number of "stones"
#declare CenterArray = array[MaxCount]
#declare RadiusArray = array[MaxCount]
#declare StrengthArray = array[MaxCount]
#declare BlobArray = array[MaxCount]
#declare Cnt = 0;
#while (Cnt < MaxCount)
#declare Rad = sqrt(Cnt + Offset)/10;
#declare CenterArray[Cnt] = vrotate(z*Rad, y*Cnt*Inc);
#declare RadiusArray[Cnt] = 0.15;
#declare StrengthArray[Cnt] = 1;
#declare Cnt = Cnt + 1;
#end // while
#declare Threshold = 0.08;
AntiBlobs(CenterArray, RadiusArray, StrengthArray, Threshold, BlobArray)
// Some code borrowed from POV-Ray's "stones1.inc" file
#declare Turb = 0.6;
#declare GranitePigment =
marble
turbulence Turb
color_map {
[ 0.000 color rgbf <0.894, 0.886, 0.886, 0.000> ]
[ 0.154 color rgbf <0.745, 0.745, 0.753, 0.000> ]
[ 0.308 color rgbf <0.902, 0.902, 0.859, 0.000> ]
[ 0.444 color rgbf <0.729, 0.706, 0.694, 0.000> ]
[ 0.615 color rgbf <0.588, 0.592, 0.635, 0.000> ]
[ 0.803 color rgbf <0.608, 0.616, 0.659, 0.000> ]
[ 1.000 color rgbf <0.894, 0.886, 0.886, 0.000> ]
#declare Granite1 =
pigment { GranitePigment }
finish {
ambient 0.2
crand 0.03
#declare Granite2 =
normal {
marble
turbulence Turb
bump_size 0.4
finish {
ambient 0.2
crand 0.17
// Release the blobs and texture them
union {
#declare PtCnt = 0;
#while (PtCnt < MaxCount)
object {
BlobArray[PtCnt]
marble
turbulence Turb
texture_map {
[ 0.70 Granite1 ]
[ 0.80 Granite2 ]
scale 0.2
translate CenterArray[PtCnt]*0.1 // To move them a little apart
#declare PtCnt = PtCnt + 1;
#end // while
// Lights, background and camera
sky_sphere {
marble
turbulence 1.2
color_map {
[ 0 color rgb <0, 1, 2>/8 ]
[ 1 color rgb <0, 0, 1>/2 ]
scale 0.5
#declare AreaLight1 =
light_source {
50*y
color White
area_light 10*x, 10*z, 3, 3
jitter
#declare AreaLight2 =
light_source {
50*y
color Red/4
jitter
Tilt(AreaLight1, <1, 1/2, 1>)
Tilt(AreaLight2, <-1, 1, 1>)
location <0, 5, 0>
angle 40
look_at <0, 0, 0>
![](/i/fill.gif) |
