Below is the source code for an image I posted 22. August to the
povray.binaries.images news group; "72 Antiblobs":
news://news.povray.org/39A31644.AB3DE5EF%40online.no
Btw.: There are 92 "Antiblobs", not 72.
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
// Copyright 2000 by Tor Olav Kristensen
// mailto:tor### [at] hotmail com
// http://www.crosswinds.net/~tok/tokrays.html
#version 3.1;
#include "stones.inc"
global_settings { ambient_light 1.5 }
// First the macro that generates all the blobs
#macro AntiBlobs(CtrArray, RadArray, StrArray, Trh, BlbArray)
#local NrOfBlobs = dimension_size(CtrArray, 1);
#local CntA = 0;
#while (CntA < NrOfBlobs)
#local CtrA = CtrArray[CntA];
#local RadA = RadArray[CntA];
#local StrA = StrArray[CntA];
#declare BlbArray[CntA] =
blob {
threshold Trh
sphere {
CtrA, RadA
strength StrA
#local CntB = 0;
#while (CntB < NrOfBlobs)
#if (CntA != CntB)
#local CtrB = CtrArray[CntB];
#local RadB = RadArray[CntB];
#local Dist = vlength(CtrB - CtrA);
#if (Dist < RadA + RadB)
#local PowA = pow(1 - pow(Dist/2/RadA, 2), 2);
#local PowB = pow(1 - pow(Dist/2/RadB, 2), 2);
#local NStrB = (Trh - StrA*PowA)/PowB;
sphere {
CtrB, RadB
strength NStrB
#end // if
#end // if
#local CntB = CntB + 1;
#end // while
#local CntA = CntA + 1;
#end // while
#end // macro AntiBlobs
// Then a macro that returns the passed object tilted in
// the direction of a vector
#macro Tilt(Thing, Vector)
#local xAngle = (Vector.z < 0 ? -1 : 1)*
degrees(acos(vnormalize((x + z)*Vector).x));
#local yAngle = degrees(acos(vnormalize(Vector).y));
object {
Thing
rotate xAngle*y
rotate -yAngle*z
rotate -xAngle*y
#end // macro Tilt
// Code to find the coordinates for the centers of all the 92 "anti-
// blobs" (60 + 12 + 20 = 92)
// Co-ordinates for a Buckminsterfullerene
#declare NrOfBuckyPts = 60;
#declare BuckyArray =
array[NrOfBuckyPts] {
< 2.226730, 0.594920, 2.684200>,
< 3.134080, 0.161810, 1.635440>,
< 3.250250, 1.240130, 0.668290>,
< 2.414560, 2.339640, 1.119120>,
< 1.782170, 1.940950, 2.364960>,
< 1.342130, -0.311850, 3.256820>,
<-0.027000, 0.086540, 3.535890>,
<-0.890470, -1.048410, 3.257750>,
<-0.054970, -2.148180, 2.806770>,
< 1.324810, -1.692910, 2.806120>,
< 3.117650, -1.159560, 1.204400>,
< 2.193000, -2.107290, 1.802560>,
< 1.720910, -2.995760, 0.754440>,
< 2.353890, -2.597090, -0.491290>,
< 3.216930, -1.462050, -0.213260>,
< 3.345290, 0.950710, -0.688050>,
< 3.328380, -0.430390, -1.138540>,
< 2.581820, -0.487170, -2.383660>,
< 2.137050, 0.858790, -2.702690>,
< 2.608990, 1.747420, -1.654660>,
< 1.709970, 3.101980, 0.194250>,
< 1.809270, 2.799410, -1.223290>,
< 0.501490, 3.010120, -1.820490>,
<-0.406030, 3.443130, -0.771880>,
< 0.340880, 3.499990, 0.473170>,
< 0.472290, 2.321910, 2.631870>,
<-0.264220, 3.118480, 1.665080>,
<-1.643750, 2.662990, 1.665550>,
<-1.759930, 1.585190, 2.632880>,
<-0.452190, 1.374270, 3.230230>,
<-2.230680, -0.584280, -2.701320>,
<-3.138380, -0.151090, -1.652660>,
<-3.254550, -1.228980, -0.685460>,
<-2.418840, -2.328500, -1.136370>,
<-1.785970, -1.930080, -2.382100>,
<-1.346280, 0.322850, -3.273640>,
< 0.023000, -0.074940, -3.552420>,
< 0.885930, 1.060390, -3.274220>,
< 0.049970, 2.159870, -2.823390>,
<-1.329630, 1.704060, -2.823020>,
<-3.122300, 1.170370, -1.221530>,
<-2.197990, 2.118350, -1.819620>,
<-1.725990, 3.007160, -0.771470>,
<-2.358450, 2.608490, 0.474240>,
<-3.221550, 1.473440, 0.196030>,
<-3.349590, -0.938890, 0.670910>,
<-3.332630, 0.442150, 1.121470>,
<-2.585870, 0.499300, 2.366750>,
<-2.141500, -0.846500, 2.686090>,
<-2.613600, -1.735240, 1.637920>,
<-1.714530, -3.090350, -0.211190>,
<-1.814140, -2.787320, 1.206480>,
<-0.506670, -2.998220, 1.803800>,
< 0.400930, -3.431500, 0.755070>,
<-0.345460, -3.488360, -0.490180>,
<-0.475910, -2.310710, -2.648970>,
< 0.260190, -3.107130, -1.682110>,
< 1.639710, -2.651480, -1.682710>,
< 1.756120, -1.573340, -2.649740>,
< 0.448510, -1.362650, -3.246970>
// Code that are not needed for this scene.
// This array contains information about how to select pairs
// of points in the BuckyArray that are to be used as endpoints
// in e.g. cylinders so that they ties the pentagons together.
#declare OtherLines =
array[30][2] {
{ 00, 05 }, { 01, 10 }, { 02, 15 }, { 03, 20 }, { 04, 25 },
{ 09, 11 }, { 14, 16 }, { 19, 21 }, { 24, 26 }, { 29, 06 },
{ 35, 30 }, { 40, 31 }, { 45, 32 }, { 50, 33 }, { 55, 34 },
{ 39, 41 }, { 44, 46 }, { 49, 51 }, { 54, 56 }, { 59, 36 },
{ 07, 48 }, { 12, 53 }, { 17, 58 }, { 22, 38 }, { 27, 43 },
{ 08, 52 }, { 13, 57 }, { 18, 37 }, { 23, 42 }, { 28, 47 }
// If you like to make the hexagons in a "Buckyball" instead of
// pentagons, then you need this information.
// Just use the array below to look up which pair of points in the
// BuckyArray to use for the cylinders.
// Note that if you render all of them, then some of the cylinders
// will "double"
#declare Hexagons =
array [20][6][2] {
{ { 00,05 }, { 05,09 }, { 09,11 }, { 11,10 }, { 10,01 }, { 01,00 } },
{ { 01,10 }, { 10,14 }, { 14,16 }, { 16,15 }, { 15,02 }, { 02,01 } },
{ { 02,15 }, { 15,19 }, { 19,21 }, { 21,20 }, { 20,03 }, { 03,02 } },
{ { 03,20 }, { 20,24 }, { 24,26 }, { 26,25 }, { 25,04 }, { 04,03 } },
{ { 04,25 }, { 25,29 }, { 29,06 }, { 06,05 }, { 05,00 }, { 00,04 } },
{ { 09,08 }, { 08,52 }, { 52,53 }, { 53,12 }, { 12,11 }, { 11,09 } },
{ { 14,13 }, { 13,57 }, { 57,58 }, { 58,17 }, { 17,16 }, { 16,14 } },
{ { 19,18 }, { 18,37 }, { 37,38 }, { 38,22 }, { 22,21 }, { 21,19 } },
{ { 24,23 }, { 23,42 }, { 42,43 }, { 43,27 }, { 27,26 }, { 26,24 } },
{ { 29,28 }, { 28,47 }, { 47,48 }, { 48,07 }, { 07,06 }, { 06,29 } },
{ { 30,35 }, { 35,39 }, { 39,41 }, { 41,40 }, { 40,31 }, { 31,30 } },
{ { 31,40 }, { 40,44 }, { 44,46 }, { 46,45 }, { 45,32 }, { 32,31 } },
{ { 32,45 }, { 45,49 }, { 49,51 }, { 51,50 }, { 50,33 }, { 33,32 } },
{ { 33,50 }, { 50,54 }, { 54,56 }, { 56,55 }, { 55,34 }, { 34,33 } },
{ { 34,55 }, { 55,59 }, { 59,36 }, { 36,35 }, { 35,30 }, { 30,34 } },
{ { 39,38 }, { 38,22 }, { 22,23 }, { 23,42 }, { 42,41 }, { 41,39 } },
{ { 44,43 }, { 43,27 }, { 27,28 }, { 28,47 }, { 47,46 }, { 46,44 } },
{ { 49,48 }, { 48,07 }, { 07,08 }, { 08,52 }, { 52,51 }, { 51,49 } },
{ { 54,53 }, { 53,12 }, { 12,13 }, { 13,57 }, { 57,56 }, { 56,54 } },
{ { 59,58 }, { 58,17 }, { 17,18 }, { 18,37 }, { 37,36 }, { 36,59 } }
// Find and store the points in the middle of each of the pentagons
#declare NrOfPents = 12; // Number of pentagons
#declare PentagonMids = array[NrOfPents]
#declare Counter = 0;
#while (Counter < NrOfPents)
#declare Cnt = Counter*5;
#declare PentagonMids[Counter] =
(BuckyArray[Cnt + 00] +
BuckyArray[Cnt + 01] +
BuckyArray[Cnt + 02] +
BuckyArray[Cnt + 03] +
BuckyArray[Cnt + 04])/5;
#declare Counter = Counter + 1;
#end // while
// Find and store the points in middle of each of the hexagons
#declare NrOfHexs = 20; // Number of hexagons
#declare HexagonMids = array[NrOfHexs]
#while (Counter < NrOfHexs)
#declare HexagonMids[Counter] =
(BuckyArray[Hexagons[Counter][0][0]] +
BuckyArray[Hexagons[Counter][1][0]] +
BuckyArray[Hexagons[Counter][2][0]] +
BuckyArray[Hexagons[Counter][3][0]] +
BuckyArray[Hexagons[Counter][4][0]] +
BuckyArray[Hexagons[Counter][5][0]])/6;
#end // while
// Now copy all these point into a new matrix: BallArray
#declare vNr = NrOfBuckyPts + NrOfPents + NrOfHexs;
#declare BallArray = array[vNr]
#while (Counter < NrOfBuckyPts)
#declare BallArray[Counter] =
BuckyArray[Counter];
#end // while
#declare BallArray[NrOfBuckyPts + Counter] =
PentagonMids[Counter];
#end // while
#declare BallArray[NrOfBuckyPts + NrOfPents + Counter] =
HexagonMids[Counter];
#end // while
// Then make the length of all of the vectors in BallArray equal to 3
#while (Counter < vNr)
#declare BallArray[Counter] = vnormalize(BallArray[Counter])*3;
#end // while
// Prepare some arrays to hold intial information about each "antiblob"
// (Center, Radii and Strength arrays)
#declare CenterArray = array[vNr]
#declare RadiusArray = array[vNr]
#declare StrengthArray = array[vNr]
// Fill the arrays
#declare CenterArray = BallArray
#declare PtCnt = 0;
#while (PtCnt < vNr)
#declare RadiusArray[PtCnt] = 0.95; // Experiment with this value
#declare PtCnt = PtCnt + 1;
#end // while
#declare PtCnt = 0;
#declare StrengthArray[PtCnt] = 1; // Experiment with this value
#end // while
// Define the threshold for all the "antiblobs"
// This value will control how "intimate" their "kissing" will be
#declare Threshold = 0.03; // Experiment with this value
// Generate the antiblobs
#declare BlobArray = array[vNr]
AntiBlobs(CenterArray, RadiusArray, StrengthArray, Threshold, BlobArray)
// Code for "Exploding" the resulting ball a little bit
#declare PtCnt = 0;
#declare BlobArray[PtCnt] =
object {
BlobArray[PtCnt]
translate BallArray[PtCnt]*0.4
#end // while
// And then let all the "antiblobs" loose
#declare PtCnt = 0;
object { BlobArray[PtCnt] texture { T_Stone13 } }
#end // while
// Sample code to make 8 simpler "antiblobs"
// This code only needs the AntiBlobs macro above.
// (So to render this you may delete all the other code between the
// Tilt macro and these lines.)
#declare NrOfBlobs = 8;
array[NrOfBlobs] {
< 1, -1, 1>/2,
<-1, -1, 1>/2,
<-1, -1, -1>/2,
< 1, -1, -1>/2,
< 1, 1, 1>/2,
<-1, 1, 1>/2,
<-1, 1, -1>/2,
< 1, 1, -1>/2,
array[NrOfBlobs] {
1.0,
1.0,
1.0,
1.0,
1.0,
1.0,
1.0,
1.0
array[NrOfBlobs] {
1.0,
1.0,
1.0,
1.0,
1.0,
1.0,
1.0,
1.0
#declare Threshold = 0.04; // Also try 0.001 and 0.12 here
#declare BlobArray = array[NrOfBlobs]
#declare SomeCells =
union {
#declare PtCnt = 0;
#while (PtCnt < NrOfBlobs)
object { BlobArray[PtCnt] texture { T_Stone23 } }
#end // while
object {
SomeCells
translate <0, 0, -8>
//light_source { -100*z color White }
// Make a background
sphere {
0, 200
normal {
granite
turbulence <1, 1, 1>/20
frequency 1
octaves 2
omega 0.2
lambda 0.1
granite
color_map {
[ 0.0 color Red/2.5 ]
[ 0.5 color Blue/1.5 ]
[ 1.0 color Red ]
frequency 1
octaves 2
omega 0.2
lambda 0.1
finish {
specular 0.2/2
scale 198
rotate 50*y
// And then let there be light !
#declare AreaLight =
light_source {
10*y
color White
area_light 10*x, 10*z, 3, 3
jitter
Tilt(AreaLight, <1, 1, -1/2>)
angle 15
location <5, 4, -10>*4.5
look_at <0, 0, 0>
