I'm trying to create a ying/yang sort of image. Here is some source that
defines the objects. On paper it seems like it would work, but when
rendered, there is a nice gap between the two halves. I have messed around
with different formulae, but can't get it right. Can anyone grok the formula
for this? :)
// Source //
#declare O_Ying=
union
#declare R=0;
#while (R<1)
#declare A=R*180;
#declare X=1.5*cos(radians(A))+0.5;
#declare Y=0.0;
#declare Z=1.5*sin(radians(A));
sphere
<X,Y,Z>,R
#declare R=R+0.01;
#declare O_Yang=
object
O_Ying
rotate y*180
// End Source //
Paul Vanukoff
van### [at] primenet com
OK I give up, I just made the Ying/Yang with CSG, dunno why I didn't do that
before. Guess I wanted that puffy spherey look. I wanted a beveled look, but
I have a better idea for that now.
// Source //
#declare O_Ying=
intersection
cylinder
< 0,-0.1, 0>, < 0, 0.1, 0>, 2
box
<-3,-0.2,-3>, < 3, 0.2, 0>
inverse
cylinder
<-1,-0.2, 0>, <-1, 0.2, 0>, 1
inverse
#declare O_Ying=
union
object
O_Ying
cylinder
< 1,-0.2, 0>, < 1, 0.2, 0>, 1
// End Source //
Paul Vanukoff
Is it too late? I worked out an equation for what I think you're
trying to get. The radius depends on the angle A in a more
complicated way, but this seems to close up the gap.
#declare O_Ying=
union
#declare R=0;
#while (R<1.0001)
#declare A=R*180;
#declare X=2*cos(radians(A))/(-3+cos(radians(A)));
#declare Y=0.0;
#declare Z=2*sin(radians(A))/(-3+cos(radians(A)));
sphere
<X,Y,Z>,(-1+cos(radians(A)))/(-3+cos(radians(A)))
#declare R=R+0.01;
#declare O_Yang=
object
O_Ying
rotate y*180
Adam C.
> for this? :)
> // Source //
> #declare O_Ying=
> union
> #declare R=0;
> #while (R<1)
> #declare A=R*180;
> #declare Y=0.0;
> sphere
> <X,Y,Z>,R
> #declare R=R+0.01;
> #end
> #declare O_Yang=
> object
> O_Ying
> rotate y*180
> // End Source //
> Paul Vanukoff
Please do not cross-post messages to other groups. I just now realized I
had inadvertently done so too (3 times) by replying to this thread.
Paul Vanukoff wrote in message <386a1908@news.povray.org>...
formula
>for this? :)
As I always say, when in doubt - cheat!
This code generates a correct monad (technical term for a yin-yang) using
only primitives and CSG.
Hope it helps.
// A monad (yin/yang without the interior circles) from primitives only.
// Brendt Hess
#declare Cyl1=cylinder {<0,0,0>,<0,.1,0>,1} // size of final monad
#declare Cyl2=cylinder { <0,0,0>,<0,.1,0>,.5} // 1/2 size of final
monad.
#declare CylPart=difference { object { Cyl1 }
object { Cyl2 scale <1,1.01,1> translate
<0,0,.5>}
<0,0,-.5>}
box {<-1.01,-.01,-1.01>,<0,.101,1.01>}
// put the pieces together
#declare YinYang=union { object { CylPart pigment {rgb 1}}
object { CylPart rotate y*180 pigment { rgb 0 }}
object { Cyl2 translate <0,0,.5> pigment {rgb 1}}
object { Cyl2 translate <0,0,-.5> pigment {rgb 0}}
// now, let's look at it
camera
location <0,4,0>
look_at <0,0,0>
angle 45
light_source { <0,10,0> rgb 1}
YinYang
plane {y,-2 pigment {rgb <.5,.5,0>}}
// end of code
Oops - that's what I get for replying now, reading later :)
Here's a method of doing it from spheres that works as well (based on your
code). It uses the fact that a sphere at any given point around the radius
r is proportional to the cosine of r/2.
// Source //
#declare O_Ying=
union
#declare R=1;
#while (R>0)
#declare A=R*180;
#declare A1=90-A/2;
#declare RealR=cos(radians(A1));
sphere {<0,0,0>,RealR translate < 2-RealR,0,0> rotate y*A}
#declare R=R-0.01;
#declare O_Yang=
object
O_Ying
rotate y*180
// End Source //
Brendt Hess wrote in message <387bb1db@news.povray.org>...
This doesn't work either, but it might give you some ideas...
global_settings { assumed_gamma 2.2 }
light_source { < -20, 20, -20 > color White }
camera
location < 0, 0, -10 >
look_at < 0, 0, 0 >
#declare O_Ying =
union
#declare R = 0;
#while( R <= 1 )
cylinder
< 0.0, 0.0, -0.002 >,
< 0.0, 0.0, 0.002 >,
R
translate < 1.92 - R, 0, 0 >
rotate R * R * R * 180 * z
#declare R = R + 0.01;
object
O_Ying
rotate -0.1 * y
pigment { Red }
object
O_Ying
rotate 180 * z
rotate 0.1 * y
pigment { White }
"Paul Vanukoff" <van### [at] primenet com> wrote in message
news:386a1908@news.povray.org...
// I tried this:
#declare O_Ying=
union
#declare R=0;
#while (R<1)
#declare A=R*180;
#declare X=1.5*cos(radians(A));
#declare Y=0.0;
sphere
<X,Y,Z>,sqrt(R)*R
#declare R=R+0.01;
#declare O_Yang=
object
O_Ying
rotate y*180
object {O_Yang pigment {rgb 1} translate <-.575,0,.1>}
object {O_Ying pigment {rgb 0} translate <.575,0,-.1>}
Sloppy isn't it? There's obviously an equation possible for making this
thing don't you suppose? I took a look on the infamous 'net and wasn't
successful, or rather there was so much about "Ying-Yang" I couldn't sift
through it all.
// Bob
"Spock" <spo### [at] home com> wrote in message news:386a29e0@news.povray.org...
> camera
> look_at < 0, 0, 0 >
> #declare O_Ying =
> union
> #declare R = 0;
> #while( R <= 1 )
> cylinder
> R
> #end
> object
> O_Ying
> rotate -0.1 * y
> pigment { Red }
> object
> O_Ying
> rotate 180 * z
> rotate 0.1 * y
> pigment { White }
I think the problem with the original approach is the outside of the
object does not form part of a circle. Even if you get the things to
line up perfectly you will end up with an oval at best.
Give the code I posted a try. I said it doesn't work but it sure looks
good from one angle. BTW you don't need to rotate by "R * R * R"
but just "R * R" instead. I was playing around with higher orders to
see if it smoothed things out... not worth it.
You can replace the cylinders in my code with spheres if you really
like the 3D effect. Here is the modified code:
camera
look_at < 0, 0, 0 >
#declare O_Ying =
union
#declare R = 0;
#while( R < 1 )
sphere
< 0, 0, 0 >
R
rotate R * R * 180 * z
object
O_Ying
pigment { Red }
object
O_Ying
rotate 180 * z
pigment { Blue }
background { White }
Well, I graphed what I wanted on some paper, and see where (at least part
of) the problem is; when A=90, the X needs to equal 0, but is at 0.5. I
think I know how to fix it, and working on it right now.
Paul Vanukoff
I tried this. It *is* closer. Still not "perfect" though .. :)
Thank you for the alternate method. It is something to work with.
Paul Vanukoff
Spock wrote in message <386a33cc@news.povray.org>...
Okay, this is finally the last time I try it too using what you had done
here before Paul :-)
With AA done on it and looking face on it seems fine, plus it's
now complete with that pair of dots found on these symbols. What I still
don't know though is which is Ying and which is Yang, so switch the names if
need be.
Tweaking, if any, left up to others from now on.
// Ying Yang again
camera {location < 0, 5, 0 >look_at 0}
light_source {10*y,1}
background {color rgb <1,0,0>}
#declare O_Ying=
intersection
cylinder
< 0,-0.199, 0>, < 0, 0.199, 0>, 2
box
inverse
pigment {rgb <1,0,0>}
cylinder
inverse
#declare O_Yang=
union
object
O_Ying
cylinder
< .975,-0.2, 0>, < .975, 0.2, 0>, .975
cylinder // the white sides (black) dot
< .975,-0.21, 0>, < .975, 0.21, 0>, .25
pigment {rgb 0}
rotate 180*y
#declare YingYang=
union {
union {
object {O_Ying}
cylinder
<.975,-0.2, 0>, <.975, 0.2, 0>, .975
cylinder // the black sides (white) dot
pigment {rgb 1} finish {ambient 1}
pigment {rgb 0}
object {O_Yang pigment {rgb 1} finish {ambient 1}}
YingYang
// Bob
Cool .. that seems to do the trick, as Spock has shown in p.b.a. Thanks!
Paul Vanukoff
Adam Coffman wrote in message <386A5828.984A09DC@ipfw.edu>...
>#declare O_Ying=
>union
> #declare R=0;
> #while (R<1.0001)
> #declare A=R*180;
> #declare Y=0.0;
> sphere
> #declare R=R+0.01;
> #end
>#declare O_Yang=
>object
> O_Ying
> rotate y*180
>Adam C.
around
formula
>> for this? :)
>> // Source //
>> #declare O_Ying=
>> union
>> #declare R=0;
>> #while (R<1)
>> #declare A=R*180;
>> #declare Y=0.0;
>> sphere
>> <X,Y,Z>,R
>> #declare R=R+0.01;
>> #end
>> #declare O_Yang=
>> object
>> O_Ying
>> rotate y*180
>> // End Source //
>> Paul Vanukoff
