POV-Ray : Newsgroups : povray.text.scene-files : Mushroom placement file Server Time
28 Jul 2024 18:23:00 EDT (-0400)
  Mushroom placement file (Message 1 to 1 of 1)
Subject: Mushroom placement file
Date: 28 Dec 1999 14:25:08
Message: <38690E6C.F554E9A2@inapg.inra.fr>
// Gilles Tran
camera
  location  <6, 5, -10.0>
  direction 1.5*z
  right     4/3*x
  look_at   <0.0, 0.3,  0.0>
background{color rgb 1}
light_source{<1000,1000,-1000> color rgb 2}
#declare txtMushroom=texture{pigment{bozo color_map{[0 color Red][0.5
color Red][0.5 color White][1 color White]}} scale 0.3}
#declare a=0; //initialize the rotation angle
#declare rStem=1; // radius stem big mushroom
#declare rHatmin=0.7; // max radius hat small mushroom
#declare rHatmax=1.3; // max radius hat small mushroom
#declare rd=seed(1);  // random seed
#declare apos=0; // initialize the intermushroom angle
// father mushroom
union{
        cylinder{0,y*rStem*3.3,rStem texture{pigment{White}}}
        cone{0,rStem*3,y*rStem,0 translate y*rStem*3.3}
        texture{txtMushroom}
#while (a<360)   // mushrooms rotate clockwise around the father
mushroom
// for each new mushroom we calculate its "hat" radius, its distance
from the father mushroom
// and then calculate the minimal angle so that it doesn't collide with
the father or the previous one
        #declare rtmp=rand(rd); // random value for the new mushroom
        #declare rHat=rHatmin*(1-rtmp)+rtmp*rHatmax; // radius of the
current mushroom hat
        #declare rpos=(rStem+rHat)*(1+rand(rd));  // radius of the
position of the current mushroom
        #if (a=0)
                #declare pos=x*rpos; // first mushroom
                #declare apos=0;
                #declare a=0.0001;   // needed to get out from here
        #else
                #if (rpos_old-rHat_old>rpos+rHat |
rpos-rHat>rpos_old+rHat_old) // new mushroom can't intersect the old one
                                #declare ra=rpos -
pow((rHat+rHat_old),2)/rpos;
                                #declare apos=degrees(acos(ra/rpos));
                #else
                        #if (rpos<rpos_old)  // new mushroom is closer
to the father mushroom than the previous one
                                #declare
ra=(pow(rpos,2)-pow((rHat+rHat_old),2)+pow(rpos_old,2))/(2*rpos_old);
                        #else // new mushroom is farther from the father
                                #declare
ra=(pow(rpos,2)-pow((rHat+rHat_old),2)+pow(rpos_old,2))/(2*rpos);
                #declare a = a + apos; // rotate this angle
                #declare pos=vaxis_rotate(x*rpos,y,a); // new mushroom
position
                // now we place the small mushroom
                union{
                        cylinder{0,y*rHat*1.2,rHat*0.3 pigment{White}}
                        cone{0,rHat,y*rHat*0.3,0 translate y*rHat*1.2 }
                        translate pos
        #declare pos_old=pos;
        #declare rpos_old=rpos;
        #declare rHat_old=rHat;
plane{y,0 pigment{Green}}
