![](/i/fill.gif) |
Textures must be declared before the macro call, but you can
change that if you wnat to.
The paramaters VVertical and HHorizontal refer to the amount
of pov units you want to fill, so if you use
object{Laticework(10,10,0.5,T_Wood31)}
the finished product will cover an area <-5,-5,-0.25>,
<5,5,0.25>. obviously you can translate and rotate after
calling.
The version that uses cylinders instead of a box for the
center piece is CylLatice which is also icluded
below.
Enjoy
Steve
// *************************************** Laticework
#macro
Laticework(VVertical,HHorizontal,Thickness,LaticeTexture)
#declare LongBox
union{
box{<-1.5,-0.25,-(Thickness/2)>,<1.5,0.25,Thickness/2>}
box{<-0.5,-0.5,-(Thickness/2)>,<0.5,0.5,Thickness/2>
rotate z*45}
}//End of
union
#declare LaticePiece=
union{
object{LongBox}
object{LongBox translate y*2.5}
object{LongBox rotate z*-90 translate <1.25,1.25,0>}
<-1.25,1.25,0>}
rotate z*45
scale<0.25,0.25,1>
union{
#local Accross=0;
#local MoveIt=0.875;
#while(Accross<HHorizontal)
#local UpDown=0;
#while(UpDown<VVertical)
object{LaticePiece translate <Accross,UpDown,0>}
#local UpDown=UpDown+MoveIt;
#local Accross=Accross+MoveIt;
#end //End of outer While.
texture{LaticeTexture}
translate<-(HHorizontal/2),-(VVertical/2),0>
} //End of union.
#end //End of macro.
//************************** CylLatice
#macro
CylLaticework(VVertical,HHorizontal,Thickness,LaticeTexture)
#declare LongBox
union{
cylinder{<0,0,-(Thickness/2)>,<0,0,Thickness/2>,0.5}
}//End of
union
union{
object{LongBox}
<-1.25,1.25,0>}
rotate z*45
scale<0.25,0.25,1>
union{
#local Accross=0;
#local UpDown=0;
} //End of union.
Steve email mailto:sjl### [at] ndirect co uk
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
![](/i/fill.gif) |
