POV-Ray : Newsgroups : povray.text.scene-files : Latice work Macros and examples Server Time
15 May 2025 21:42:00 EDT (-0400)
  Latice work Macros and examples (Message 1 to 3 of 3)
Subject: Latice work Macros and examples
Date: 1 Nov 1999 17:34:38
Message: <381E10A6.E39B11D8@ndirect.co.uk>
Textures must be declared before the macro call, but you can
change that if you wnat to.
The paramaters VVertical and HHorizontal refer to the amount
of pov units you want to fill, so if you use
object{Laticework(10,10,0.5,T_Wood31)}
the finished product will cover an area <-5,-5,-0.25>,
<5,5,0.25>.  obviously you can translate and rotate after
calling.
The version that uses cylinders instead of a box for the
center piece is CylLatice which is also icluded
below.
Enjoy
Steve
// ***************************************  Laticework
#macro
Laticework(VVertical,HHorizontal,Thickness,LaticeTexture)
  #declare LongBox
  union{
box{<-1.5,-0.25,-(Thickness/2)>,<1.5,0.25,Thickness/2>}
        box{<-0.5,-0.5,-(Thickness/2)>,<0.5,0.5,Thickness/2>
rotate z*45}
       }//End of
union
  #declare LaticePiece=
  union{
        object{LongBox}
        object{LongBox translate y*2.5}
        object{LongBox rotate z*-90 translate <1.25,1.25,0>}
<-1.25,1.25,0>}
        rotate z*45
        scale<0.25,0.25,1>
  union{
        #local Accross=0;
        #local MoveIt=0.875;
        #while(Accross<HHorizontal)
          #local UpDown=0;
          #while(UpDown<VVertical)
            object{LaticePiece translate <Accross,UpDown,0>}
            #local UpDown=UpDown+MoveIt;
          #local Accross=Accross+MoveIt;
        #end //End of outer While.
        texture{LaticeTexture}
        translate<-(HHorizontal/2),-(VVertical/2),0>
       } //End of union.
#end  //End of macro.
//**************************  CylLatice
#macro
CylLaticework(VVertical,HHorizontal,Thickness,LaticeTexture)
  #declare LongBox
  union{
        cylinder{<0,0,-(Thickness/2)>,<0,0,Thickness/2>,0.5}
       }//End of
union
  union{
        object{LongBox}
<-1.25,1.25,0>}
        rotate z*45
        scale<0.25,0.25,1>
  union{
        #local Accross=0;
          #local UpDown=0;
       } //End of union.
Subject: Re: Latice work Macros and examples
Date: 2 Nov 1999 12:13:10
Message: <8E72BD482seed7@212.120.113.81>
Thanks Steve.
For some inspiration for lattice designing I can recommend this
book:
Cinese Lattice Designs
by Daniel Sheets Dye
ISBN  0-486-23096-1
Dover Publications, Inc. New York
~ $13.95
It has over 1200 illustrations.
Ingo
Date: 3 Nov 1999 09:11:39
Message: <382032BC.4F9BC5BB@ndirect.co.uk>
Thanks ingo, I've made a note of this and will try to get it
from the library.
> Thanks Steve.
> book:
> ISBN  0-486-23096-1
> ~ $13.95
> Ingo
