Subject: My Attempt at a 3d Wood Surface - Source File
Date: 26 Oct 1999 16:31:48
Message: <38160fb4@news.povray.org>
// Persistence of Vision Ray Tracer Scene Description File
// File: wood3d.pov
// Vers: 3.1 SuperPatch
// Desc: 3d hite_field wood planks
// Date: 10/24/99
// Auth: Eric L. Freeman
// INITIAL VARIABLES
#declare ScX = 2/12; file://scale the plank
#declare ScY = 0.05/12; file://scale the plank
#declare ScZ = 12/12; file://scale the plank
#declare ScPig = 5.7; file://scale the pigment
#declare TransPig = 1000; file://for random translating of the texture
#declare Gapper = 0.025; file://the gap between the planks
#include "woods.inc"
// LIGHT
light_source {
<-60,100,30>
color White*1.23
background {DarkBrown/3}
#declare R1 = seed(123);
#declare Looper1 = 0; file://inner loop control
#declare Looper2 = 0; file://outer loop control
#declare NumX = 2; file://the number of planks in the x direction
#declare NumZ = 2; file://the number of planks in the z direction
#while (Looper2 < NumX)
#while (Looper1 < NumZ)
#declare TransPig = 1000*rand(R1);
#declare RotPig = <rand(R1)*4,rand(R1)*4,0>;
object {
height_field {
pattern 200,200 {
hf_gray_16
// the following 2 pigment definitions are taken
// from the T_Wood1 texture definintion in woods.inc
// to change woods, change the wood texture below
// and the pigment
// P_WoodGrain1A color_map {M_Wood1A}
P_WoodGrain1B color_map {M_Wood1B}
translate <0,0,TransPig>
scale <1,1,1/ScZ>
scale ScPig
rotate RotPig
T_Wood1
scale <1/ScX,1,1/ScZ>
scale ScPig
rotate RotPig
scale <ScX,ScY,ScZ>
translate <Looper2*(ScX+Gapper),0,Looper1*(ScZ+Gapper)>
#if ( int(Looper2/2)=Looper2/2 )
translate <0,0,(ScZ+Gapper)/2>
#declare Looper1 = Looper1+1;
#declare Looper2 = Looper2+1;
// CAMERA
location <0,0.15,-0.15>
look_at <0,0,0>
rotate y*20
translate <(ScX+Gapper)*(NumX/2),0,(ScZ+Gapper)*(NumZ/2)>
Subject: Re: My Attempt at a 3d Wood Surface - Source File
Date: 26 Oct 1999 16:37:15
Message: <381610fb@news.povray.org>
Hey all,
Just looking at my post and Outlook Express puts a "file:" in front of all
the double "/"s. Should source files be posted as attachments instead of
copy/pasting them into the message body???
Eric
"A wise and frugal government, which shall restrain men from injuring one
another, which shall leave them otherwise free to regulate their own
pursuits of industry and improvement, and shall not take from the mouth of
labor the bread it has earned. This is the sum of good government."
- Thomas Jefferson
- First inaugural address, 1801
http://www.ametro.net/~ericfree
On Tue, 26 Oct 1999 15:37:39 -0500, Eric Freeman wrote:
>Hey all,
No, Microsoft should be bombed into oblivion. Other newsreaders don't have
that bug. Your post appears fine to me.
These are my opinions. I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Oh come on Ron ! If Microsoft were bombed into oblivion that would leave
us with Macintosh to pick on and that would be about as much fun as shooting
fish in a bowl.
Ken Tyler - 1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
>fish in a bowl.
Oh, you are still alive. I was worried someone kicked your power cord from
the wall. Admit it, you're too busy cataloging all those links I gave you
this morning to bother with us mere mortals, aren't you?
Yeah I'm still alive. I am just suffering from sensory overload... overload...
Date: 26 Oct 1999 21:19:44
Message: <38165330@news.povray.org>
The solution is to never follow a comments // immediately with any
character. Spaces prevent this from happening and I'm already relearning my
commenting habits to try and prevent this.
There's always the Edit/Replace in the Windows versions editor also. You
could make all // into //(spc) or remove the "file:" likewise.
Eric Freeman <eri### [at] ametro net> wrote in message
news:381610fb@news.povray.org...
> Hey all,
> Eric
> - Thomas Jefferson
Date: 26 Oct 1999 21:37:28
Message: <38165758@news.povray.org>
Joke is on me, in Outlook my // (spc) came out wrong.
omniVERSE <inv### [at] aol com> wrote in message
news:38165330@news.povray.org...
my
> could make all // into file://(spc) or remove the "file:" likewise.
> Bob
> > Hey all,
all
of
> > Eric
one
of
> > - Thomas Jefferson
Date: 26 Oct 1999 22:38:02
Message: <3816657E.E7FFA081@enst.fr>
> Bob
OTOH it fixes the problem for netscape...
Jerome
* Always listen to experts, * Jérôme M. BERGER
* they'll tell you what can't * mailto:ber### [at] iname com
* be done and why... * http://www.enst.fr/~jberger
* Then do it. *
Date: 27 Oct 1999 00:36:14
Message: <3816813e@news.povray.org>
news:38165758@news.povray.org...
Same here. In my original post I spent about 5 minutes trying to type //
(without the space) and finally had to resort to 'double "/"' instead.
WAIT!!!! I just got the // above to work!!!! Type a slash, then a space,
then another slash, then another space, then back up and remove the space in
between the slashes. Who said MS products aren't user friendly??
Eric
- Thomas Jefferson
Date: 27 Oct 1999 02:26:58
Message: <38169b32@news.povray.org>
You don't want a head count do you?
news:3816813e@news.povray.org...
in
> Eric
Date: 27 Oct 1999 16:24:45
Message: <38175f8d@news.povray.org>
Just union two hf's. See the code under "Grim Woods."
GrimDude
gri### [at] netzero com
news:38160fb4@news.povray.org...
> // File: wood3d.pov
> // Date: 10/24/99
> // LIGHT
> light_source {
> <-60,100,30>
> color White*1.23
> object {
> height_field {
> pattern 200,200 {
> hf_gray_16
> // and the pigment
> scale <1,1,1/ScZ>
> scale ScPig
> rotate RotPig
> texture {
> T_Wood1
> scale ScPig
> rotate RotPig
> scale <ScX,ScY,ScZ>
> #end
> #end
> #end
> // CAMERA
> camera {
> look_at <0,0,0>
> rotate y*20
Netscape does that too, but if you leave a space before and
after the // then it doesn't do it.
Eric Freeman wrote:
> Hey all,
> Eric
> - Thomas Jefferson
Steve email mailto:sjl### [at] ndirect co uk
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
