Here's the source for the peeling paint texture. You may feel the need
to
scale it down :) Be aware that you must have the superpatch to use
this code. Enjoy the new area of texture-making this
opens up!
#declare Walls=
function{
pigment{
granite scale 30
color_map{
[0 rgb 0][.1 rgb .1][.15 rgb .7][.2 rgb .75][.21 rgb 1][.25 rgb
.6][.7 rgb 0][1 rgb .5]
texture{
pigment{
granite scale 60
color_map{
[.1 rgb<.7 .7 .5>][.18 rgb<.8 .8 .6>][.2 rgb<.7 .7 .5>][.21 rgb 1][1
rgb .8]
normal{ function{ Walls } 1.5 }
Samuel Benge
STB### [at] aol com
"And you can fly
High as a kite if you want to
Faster than light if you want to
Speeding through the universe
Thinking is the best way to travel"
-The Best Way to Travel, The Moody Blues
