![](/i/fill.gif) |
Abstract Experiment on Graph Paper
By Michael Andrews.
This needs the superpatch to run.
Otherwise, enjoy.
global_settings { assumed_gamma 1.0 max_trace_level 10 ambient_light 3
radiosity {
count 200
error_bound 0.33
gray_threshold 0.3
distance_maximum 0
low_error_factor 0.33
nearest_count 9
minimum_reuse 0.001
brightness 3.3
recursion_limit 2
background { color rgb <1/15,1/sqrt(15),1>*0.5 }
// Light constants.
#declare lightDir = vnormalize(<-0.5,2.1,-2>);
#declare lightLen = 1.5e4;
#declare lightRad = lightLen*sin(radians(0.25));
#declare lightCol = <1,.97,.95>;
// Camera constants.
#declare camPos = <-0.35, 0.5, -0.75>*6;
#declare camLookAt = <0,0,0>;
#declare camAngle = 25;
up <0, 1, 0>
right <4/3, 0, 0>
location camPos
direction <0.0, 0.0, 1>
angle camAngle
look_at camLookAt
light_source {
0*x
colour rgb lightCol
translate lightDir*lightLen
parallel
point_at 0
media_attenuation on
#declare pS = pigment { bozo colour_map {[0 rgb 0][1 rgb 1]} scale 1/4 }
#declare pR = pigment { bozo colour_map {[0 rgb 0][1 rgb 1]} scale 1/4 translate 100 }
#declare N = 30;
union {
#declare Y = 0; #while (Y < N)
#declare hfS = height_field {
pattern N+1,N+1 {
hf_gray_16
pS translate -y*Y/(N-1)
scale <N,N-1,N>/(N-1)
#debug concat("Layer ", str(Y,0,0), "\n")
#declare X = 0; #while (X < N)
#declare Z = 0; #while (Z < N)
#declare nS = <0,0,0>;
#declare S = trace (hfS, <(X+0.001)/(N-1),2,(Z+0.002)/(N-1)>, -y, nS);
#declare pT = max(0,min(1,2*S.y-1));
#if (pT > 0)
// uncomment the following #if and the coresponding #end to get the shell
// #if (X=0 | Y=0 | Z=0 | X=(N-1) | Y=(N-1) | Z=(N-1))
box {
-1,1
#switch (pT)
#range (0.0, 0.2) scale 0.6/(N-1) rotate (pT/0.2)*(nS-0.5)*<-1,1,1>*30 #break
#range (0.2, 0.9) scale 0.6/(N-1) rotate ((pT-0.2)/0.7)*(nS-0.5)*<1,-1,1>*30
#break
#range (0.9, 1.0) scale 0.6/(N-1) rotate ((pT-0.9)/0.1)*(nS-0.5)*<1,1,-1>*30
#break
translate <X,Y,Z>/(N-1)-0.5
material {
function { pT }
texture_map {
[0.2 pigment { rgbf 0.8 } finish { ambient 0.1 diffuse 0.5
specular 0.5 reflection 0.5 }]
[0.2 pigment { rgb <0.8,0.3,0.9>*0.7 } finish { ambient 0.1 diffuse 1
brilliance 0.5 }]
[0.9 pigment { rgb <0.6,0.3,0.9>*0.2 } finish { ambient 0.1 diffuse 1
brilliance 0.5 }]
[0.9 pigment { rgb <0.6,1,0.4> } finish { ambient 0.1 diffuse 1
brilliance 15 }]
[1.0 pigment { rgb <0.6,1,0.4>*0.3 } finish { ambient 0.1 diffuse 1
brilliance 15 }]
interior { ior 1.33 fade_distance 1/N fade_power 1/3 }
// #end
#declare Z = Z + 1; #end
#declare X = X + 1; #end
#declare Y = Y + 1; #end
// Graph paper
#declare fnGrid = function { 1-max(abs(1-((abs(x%1))*2)),abs(1-((abs(z%1))*2))) }
plane {
y,0
function {
min(fnGrid(x,0,z),min(fnGrid(x*2,0,z*2),fnGrid(x*10,0,z*10)))+0.02*noise3d(x*20,0,z*20)
colour_map {[0.04 rgb <0.3,0.8,0.9>][0.04 rgb 1]}
normal {
average
normal_map {
[1 bumps -0.5 scale <5,1,0.2>*1/5 ]
[1 bumps -0.5 scale <0.2,1,5>*1/5 ]
scale 0.1
translate -y*0.5*(N+1)/N
![](/i/fill.gif) |
