![](/i/fill.gif) |
// Persistence of Vision Ray Tracer Scene Description File
// File: curvtext.pov
// Vers: 3.1 SuperPatch
// Desc: curved text
// Date: 10/06/99
// Auth: Eric L. Freeman
// Uses the "max_extent" feature of the SuperPatch to position the text
// but can be positioned by hand in regular POV
light_source {
<-20,80,-120>
color White
light_source {
<20,80,-120>
color White
light_source {
<0,0,120>
color White
// FRONT VIEW
location <0,1.7,-3.4>
look_at <0,0,-1.7>
// TOP VIEW
location <0,20,-1.7001>
look_at <0,0,-1.7>
angle 8
// THE TEXT-CURVING CODE *****************
#declare TextDepth = 2.2;
#declare StartAngle = 20;
#declare RotaterAngle = -20;
// THE FIRST LETTER
#declare Pee = text {
ttf "c:\windows\fonts\arialbd.ttf" "P"
TextDepth, 0
#declare PeeExtent = max_extent (Pee);
#declare PeeObj = object {
Pee
translate -PeeExtent/2
translate <0,0,-TextDepth/2>
rotate <0,StartAngle,0>
// THE SECOND LETTER
#declare Ohh = text {
ttf "c:\windows\fonts\arialbd.ttf" "O"
TextDepth, 0
#declare OhhExtent = max_extent (Ohh);
#declare OhhObj = object {
Ohh
translate -OhhExtent/2
rotate <0,StartAngle+RotaterAngle,0>
// THE THIRD LETTER
#declare Vee = text {
ttf "c:\windows\fonts\arialbd.ttf" "V"
TextDepth, 0
#declare VeeExtent = max_extent (Vee);
#declare VeeObj = object {
Vee
translate -VeeExtent/2
rotate <0,StartAngle+RotaterAngle*2,0>
// COMBINE ALL LETTERS INTO A SINGLE OBJECT
#declare AllText = union {
object {PeeObj}
object {OhhObj}
object {VeeObj}
// THEN MAKE A HOLLOW CYLINDER
#declare TheCylinder = difference {
cylinder {
<0,-1,0>,
<0,3,0>
TextDepth*0.9
cylinder {
<0,-2,0>,
<0,4,0>
TextDepth*0.8
// FINALLY, MAKE AN INTERSECTION OF THE TWO OBJECTS
intersection {
object {TheCylinder}
object {AllText}
pigment {Red}
![](/i/fill.gif) |
