![](/i/fill.gif) |
// Persistence of Vision Ray Tracer Scene Description File
// File: cinderblock.pov
// Vers: 3.1
// Desc: the masonry called cinder block
// Date: 99.65
// Auth: Bob Hughes mailto:inv### [at] aol com?Subject=PoV-Scene
/* Note: if no AA is used the texture will not look right, advice is
to use AA of at least default amount. Mortar has been put in a little
unrealisticly, just so you know. This isn't the best of scripts, there
is no real end-use defined. Giving it up so I can move on again,
however anyone should be able to throw the individual blocks together
somehow; it is after all a scene file instead of a include. I hope
I've made this clear enough to read okay. Good luck. */
global_settings {
assumed_gamma 2.4
max_trace_level 8
ambient_light <1.4,1.5,1.6>*.9
radiosity {
brightness 3
count 123
distance_maximum 25
error_bound 0.4
gray_threshold 0.5
low_error_factor 0.7
minimum_reuse 0.012
nearest_count 6
recursion_limit 1
/* User selectables */
// light factor for texture finish; use smaller number in brighter, or
more lights [.75 to 1.5 typical]
#declare LF = .9; // this is experimental
// painted surface? (textures the -z surfaces)
#declare Painted = yes; // can be yes only if Special is "no"
// corner block?
#declare Corner = no;
// mortar at end?
#declare MortarEnd = yes;
// special test? (diagonal half painted blocks)
#declare Special = yes; // can be yes or no only if Painted is "yes"
or "no"
/* lights, camera */
// camera location
#declare CX = 50;
#declare CY = 50;
#declare CZ = -50;
// main light
light_source { 0,<1.3,1.275,1.25>*(1.125/(LF*.825))*.9
// area_light <5,0,0>,<0,5,0>,3,3 jitter adaptive 1
translate -100*z rotate <45,45,0>
// fill light
light_source { <33,50,75>,<.2,.225,.25>*1.5 }
camera
location <CX,CY,CZ>
angle 33
look_at <1.67,3.3,0>
/* Environment */
sky_sphere // morning
pigment
gradient y
color_map {
[0.0 color rgb<1.0,0.825,0.675>] [1.0 color rgb<0.45,0.55,0.75>] }
// ground
plane {y,0 pigment {rgb<.7,.65,.625>} normal {wrinkles .2} finish
{ambient .15 diffuse .8}}
/* Textures */
#declare MortarTexture=
pigment {granite frequency 5 color_map {
[.1 color rgb .825]
[.2 color rgb .925]
[.4 color rgb .85]
[.5 color rgb .8]
[.8 color rgb .85]
} ramp_wave }
normal {granite -.2 frequency 5 sine_wave}
finish {ambient <.1333,.15,.1667>*(LF/1.125) diffuse
.79*(1.125/LF)
specular .09 roughness .2 brilliance .8 crand .025}
scale <1/8,1,1> /* only adjusted for set of example blocks (comment
out if single block
without Special used) */
#declare CinderTexture=
pigment {granite frequency 3 color_map {
[.1 color rgb .6]
[.2 color rgb .9]
[.4 color rgb .75]
[.5 color rgb .85]
[.8 color rgb .7]
} scallop_wave }
normal {granite -.6 frequency 3 ramp_wave}
.72*(1.125/LF)
specular .03 roughness .4 brilliance .6 crand .05}
out if single block
#declare YellowPaintM=
texture {MortarTexture}
texture {pigment {gradient z color_map {
[.025 color rgb<.9,.75,.5>*1.25]
[.05 color rgbf 1]
} ramp_wave }
normal {granite .125 scale .33}
finish {ambient .125 diffuse .7 specular .1 roughness
.09 phong .05 phong_size 10
reflection .025 reflection_exponent .6}
scale 3.75
scale <1/8,1,2> /* only adjusted for set of example blocks (comment
out if single block
translate -3.8*z}
#declare YellowPaintC=
texture {CinderTexture}
[.05 color rgbf 1]
} ramp_wave }
normal {granite .125 scale .36}
reflection .05 reflection_exponent .4}
scale 3.75
out if single block
translate -3.8*z}
#declare ClearPaint= // no paint
texture {pigment {rgbf 1}}
/* Mortar */
#if (MortarEnd=yes)
#declare Mortar=
union {
// union {
// end
difference {
superellipsoid {<.1,.1> scale <.36,3.85,3.75> translate <8,-.05,0>}
cylinder {-z,z,1 scale <.575,4.8,.25> translate <8,0,-3.875>}
cylinder {-z,z,1 scale <.575,4.8,.25> translate <8,0,3.875>}
// end cut
#if (Corner=no)
superellipsoid {<.4,.4> scale <1,5,2.5> translate 8*x}
// opposite end mortar
difference {
#if (Corner=off)
translate 4.15*y
// bottom
difference {
superellipsoid {<.1,.1> scale <8.5,.36,3.75> translate .125*x}
cylinder {-x,x,1 scale <9,.525,.2> translate <0,0,-3.8>}
cylinder {-x,x,1 scale <9,.525,.2> translate <0,0,3.8>}
// hole cutouts
superellipsoid {<.4,.4> scale <3,7,2.67> translate <-3.45,-2.125,0>}
superellipsoid {<.4,.4> scale <3,7,2.67> translate <3.45,-2.125,0>}
// end cuts
#if (Corner=no)
superellipsoid {<.4,.4> scale <1,5,2.5> translate -8.25*x}
superellipsoid {<.4,.4> scale <1,5,2.5> translate 8.25*x}
// texturing
#if (Special=no) // special use
#if (Painted=yes)
texture {gradient x frequency 1 texture_map {
[1 YellowPaintM]
} ramp_wave scale <8,1,1> // rotate <0,0,45>
#else
texture {MortarTexture} // normal use
#end // Special
translate -3.65*y
#else
// base mortar only
#declare Mortar=
difference {
// hole cutouts
// end cuts
#if (Corner=off)
// texturing
#if (Painted=yes)
[1 YellowPaintM]
#else
#end // Special
translate -3.65*y
// object {Mortar translate 4*y}
/* Block */
// half block
#declare CinderBlockHalf=
difference {
box {-1,1 scale <15.5,7.36,7.36>/2}
superellipsoid {<.4,.4> scale <3,4.25,2.25> translate -3.45*x}
superellipsoid {<.4,.4> scale <3,4.25,2.25> translate 3.45*x}
// texturing
#if (Special=no)
#if (Painted=yes)
[1 YellowPaintC]
#else
#end // Special
scale <1,1,.5>
// object {CinderBlockHalf}
// full block
#declare CinderBlock=
// union {
// object {Mortar}
difference {
// box {-1,1
superellipsoid {<.05,.05> scale <15.5,7.36,7.36>/2}
superellipsoid {<.3,.3> scale <3,7,2.67> translate <-3.45,-2.125,0>}
superellipsoid {<.3,.3> scale <3,7,2.67> translate <3.45,-2.125,0>}
#if (Corner=off)
superellipsoid {<.3,.3> scale <1,5,2.5> translate -8.25*x}
superellipsoid {<.3,.3> scale <1,5,2.5> translate 8.25*x}
// end slots
superellipsoid {<.3,.3> scale <.45,5,.25> translate <-7.875,0,-3>}
superellipsoid {<.3,.3> scale <.45,5,.25> translate <-7.875,0,3>}
superellipsoid {<.3,.3> scale <.45,5,.25> translate <7.875,0,-3>}
superellipsoid {<.3,.3> scale <.45,5,.25> translate <7.875,0,3>}
// texturing
#if (Special=no)
#if (Painted=yes)
[1 YellowPaintC]
#else
#end // Special
// object {CinderBlock translate 4*y}
/* Placement (example only) */
#declare Blocks=
union {
object {CinderBlock}
object {CinderBlock translate 16*x}
object {CinderBlock translate -16*x}
object {CinderBlock translate <8,7.75,0>}
object {CinderBlock translate <-8,7.75,0>}
// texture choice
texture {gradient x texture_map {
#if (Special=no) // otherwise previous texture applies
[1 YellowPaintC scale <1/6,1,1>]
#else
[.45 YellowPaintC scale <1/6,1,1>]
[.55 CinderTexture scale <1/8,1,1>]
} scale <26.5,1,1> // stretch size to these blocks
rotate 45*z // angles the paint line
translate -8.5*x // positions to one end
translate 4*y // raise above ground at y=0
#declare Mortars=
union {
object {Mortar}
object {Mortar translate 16*x}
object {Mortar translate -16*x}
object {Mortar translate <8,7.5,0>}
object {Mortar translate <-8,7.5,0>}
// texture choice
[1 YellowPaintM scale <1/6,1,1>]
#else
[.45 YellowPaintM scale <1/6,1,1>]
[.55 MortarTexture scale <1/8,1,1>]
/* Wall section test */
union {
object {Blocks}
object {Mortars}
![](/i/fill.gif) |
