![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
//Added a prism to the middle to eliminate that hole in the center of
it.
//The spike macro:
// twyst(1,2,3,4,5,6,7)
// 1 = Points array, dim. [#points][2]
// 2 = Height of spike
// 3 = Rotation between two layers
// 4 = Radius of rounded edge at base
// 5 = Spacing ratio (should be almost 1)
// formula is height = (1-pow(Ratio,Layer))*Height
// 6 = Number of layers, not enough will cut the spike short
// because of the spacing ratio
// 7 = color difference between layers
// rainbow cycles every mult. of 3
#macro twyst(Points,Height,Rot,Rad,Rat,Num,Clr)
#local Nctr = 0;
#local RecH = 0; //RecH = current layer's height
#local RecR = -Rot; //RecR = current layer's rotation
#local Scale = 1; //Scale = scale factor for current layer
#local Color = (clock*3); //stores 0-3 indicating rainbow position
#local numpoints = dimension_size(Points,1);
union {
#while (Nctr < Num) //Layer counter
#local RecR = RecR+Rot; //increase rotation
#local Rctr = 0;
#local Color = mod(Color+Clr,3);
#local CTemp = mod(Color,1);
#declare Vary = color rgb<0,1-CTemp,CTemp>; //rainbow colors
#if (Color < 2) #declare Vary = color rgb<1-CTemp,CTemp,0>; #end
#if (Color < 1) #declare Vary = color rgb<CTemp,0,1-CTemp>; #end
// here you can average Vary with other colors
#declare Vary = color Vary*.5+SkyBlue*.3+Gray95*.2;
#while (Rctr < numpoints) //points counter
cylinder { < Points[Rctr][0], 0, Points[Rctr][1] >,
< Points[mod(Rctr+1,numpoints)][0], 0,
Points[mod(Rctr+1,numpoints)][1] >, Rad
rotate RecR*y scale Scale
translate RecH*y pigment { Vary }
finish { specular .9 roughness .005 } }
sphere { < Points[Rctr][0], 0, Points[Rctr][1] >, Rad
#local Rctr = Rctr + 1;
#local Rctr = 0;
prism { -Rad,Rad,numpoints+1
<Points[Rctr][0],Points[Rctr][1]>,
<Points[0][0],Points[0][1]>
#local RecH = Height-RecH; //adjust RecH for next layer
#local RecH = RecH*Rat;
#local Scale = RecH/Height; //adjust scale for next layer
#local Nctr = Nctr + 1;
} #end
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Final Twyst (No hole in the middle)
Date: 17 Sep 1999 21:16:48
Message: <37e2e800@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
*drool* Umm. . .where's the huge electric sho*ZZZZAAAAAPPPPPPPP!!!!!!*
Ow.
-Kentucky Fried Ian
Larry Fontaine <lfo### [at] isd net> wrote in message
news:37DF1826.65DB629A@isd.net...
> file://Added a prism to the middle to eliminate that hole in the center of
> it.
> file://The spike macro:
> #local Nctr = 0;
> #local RecH = 0; file://RecH = current layer's height
> #local RecR = -Rot; file://RecR = current layer's rotation
> #local Scale = 1; file://Scale = scale factor for current layer
> #local Color = (clock*3); file://stores 0-3 indicating rainbow position
> union {
> #while (Nctr < Num) file://Layer counter
> #local RecR = RecR+Rot; file://increase rotation
> #local Rctr = 0;
> #declare Vary = color rgb<0,1-CTemp,CTemp>; file://rainbow colors
> #while (Rctr < numpoints) file://points counter
> #end
> #local Rctr = 0;
> #end
> #local RecH = Height-RecH; file://adjust RecH for next layer
> #local Scale = RecH/Height; file://adjust scale for next layer
> #end
> } #end
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
