POV-Ray : Newsgroups : povray.text.scene-files : Re: a little game Server Time
9 Nov 2026 18:39:13 EST (-0500)
  Re: a little game (Message 1 to 27 of 27)
Subject: Re: a little game
Date: 7 Jan 1999 07:21:03
Message: <3694A6BE.20A984B2@aol.com>
A little unsure of how to continue the formatting of this scene, so I'm
going to just add it in new again. Might be troubles encountered with
multiple posts of this thing at about the same time, which will cause
dropping out of scene code on occasion.
//BEGIN my change
     location <-100, 10, -100>
     sky <0, 1, 0>
     look_at <0, 0, 0>
light_source {
     <-1000, 800, -2000>
     color rgb<1, 1, 1>
plane {
     <0, 1, 0>, 0
          color rgb<1, 1, 1>
//bobs part one
#declare C=1;
#while (C<9)
sphere {0,1
 pigment {rgb C/10 filter C/9}
  normal {waves .4 turbulence .2 scale .1 phase clock}
  finish {ambient .6-(C/11) diffuse .2+(C/15) specular .6 roughness .01
reflection .25
   irid {.6 thickness .3 turbulence .2} brilliance -.15 metallic .4}
  interior {ior 1.05 caustics 4 fade_distance 1.5 fade_power 1}
 scale <C/3,C/4,C/5>*7 rotate C*45*y rotate clock*360*y
  translate <3,5,-7>*4
#declare C=C+1;
//bobs part one
//END my change
gemelli david wrote:
> Hi,
> a few days ago, I posted an image called "foggy scene" in
> binaries.images
> and received very good suggestions. The problem is, I am not able to
> make
> everything, because:
> - there are a lot of things I am not good enough to do.
> - my computer is very slow (486DX2-66 8Mo).
> This gave me an idea, I don't know if it has been tried before (you did
> it
> with a poem I don't remember when):
> I posted an 'empty' scene, just a white floor, a camera and a light in
> scenes-text and the resulting image (very short !) in binaries.image
> with
> the name "a little game".
> What I suggest is that anyone who has an idea, take the source, post a
> message telling he is working on it and when it will be finished then
> post
> the results to the different groups (image and source).
> The main idea is that you can add what you want, even if it bears no
> relation
> to (I took this expression from my French/English dictionary, so ?) the
> rest
> of the scene or if it is a new part of an existing object, but you can't
> modify something that was already done. It may be preferable that the
> thing
> you add is a little/simple thing or a part of something.
> I am curious to see what can be resulting of this !
> Please tell me if you find this stupid or useless, maybe I am the only
> one to
> think it should be funny ?
>                          David GEMELLI
> // OK, that's it. The White plane is all yours
> // Feel free to add any comments you want !
> camera {
>      sky <0, 1, 0>
>      look_at <0, 0, 0>
> light_source {
>      <-1000, 800, -2000>
>      color rgb<1, 1, 1>
> plane {
>      <0, 1, 0>, 0
>      pigment {
>           color rgb<1, 1, 1>
=Bob
Download 'us-ascii' (1 KB)
Date: 8 Jan 1999 09:41:00
Message: <369618fc.0@news.povray.org>
I "checked out" the scene. Please don't change it. I'll check it back in
soon, with my added object.
Johannes.
Date: 8 Jan 1999 10:25:18
Message: <3696235e.0@news.povray.org>
And here the scenefile after my addition...
Johannes
     sky <0, 1, 0>
     look_at <0, 0, 0>
light_source {
     <-1000, 800, -2000>
     color rgb<1, 1, 1>
plane {
     <0, 1, 0>, 0
          color rgb<1, 1, 1>
//bobs part one
#declare C=1;
#while (C<9)
sphere {0,1
reflection .25
#declare C=C+1;
//bobs part one
//Johannes' part 1
union {
  superellipsoid { <0.1, 0.1> }
  superellipsoid { <1.0, 0.1> translate  0.93*y }
  superellipsoid { <1.0, 0.1> translate  0.93*x }
  material
    texture
      pigment { color rgb <0.8, 0.0, 0.0> }
      finish {
        ambient 0.2
        diffuse 0.3
        brilliance 0.099
        phong 1.0
        phong_size 4.3
        specular 0.22
        roughness 0.001
  scale <2.5, 2.5, 1.25>
  rotate <0, 0, 45>
  translate  <-80, 3.3, -70>
//End Johannes' part 1
Date: 8 Jan 1999 10:27:26
Message: <3696236D.1A365341@pacbell.net>
> Johannes
HEY !! Mr. Tyler  has it. It shall return.
Ken Tyler
tyl### [at] pacbellnet
Date: 8 Jan 1999 13:36:16
Message: <36964F4C.E6C5D7B2@bahnhof.se>
Hello..
I'll be waiting for it, I think I have something.. (Prepare for RENDER time...)
//Spider
> > Johannes
> Ken Tyler
Date: 8 Jan 1999 14:17:16
Message: <3696594A.6787954B@pacbell.net>
It returneth.
Next person !
Ken Tyler
     sky <0, 1, 0>
     look_at <0, 0, 0>
light_source {
     <-1000, 800, -2000>
     color rgb<1, 1, 1>
plane {
     <0, 1, 0>, 0
          color rgb<1, 1, 1>
//bobs part one
#declare C=1;
#while (C<9)
sphere {0,1
reflection .25
#declare C=C+1;
//bobs part one
//Johannes' part 1
union {
  material{
    texture{
      finish {
        ambient 0.2
        diffuse 0.3
        brilliance 0.099
        phong 1.0
        phong_size 4.3
        specular 0.22
        roughness 0.001
  rotate <0, 0, 45>
// Start Ken 3of3
  #declare Obelisk =
  intersection{intersection{intersection{
  plane{x,0 rotate  5*z translate 9*x }
  plane{x,0 rotate  5*z translate 9*x rotate  90*y }
  plane{x,0 rotate  5*z translate 9*x rotate 180*y }
  plane{x,0 rotate  5*z translate 8*x rotate 270*y}}
  plane{x,0 rotate 30*z translate 5*x translate 60*y}
  plane{x,0 rotate 30*z translate 5*x translate 60*y rotate  90*y}
  plane{x,0 rotate 30*z translate 5*x translate 60*y rotate 180*y}
  plane{x,0 rotate 30*z translate 5*x translate 60*y rotate 270*y}
  plane{y,0 inverse}}
  cylinder{z*-10,z*10,6 scale<1,1.75,1>inverse pigment{rgb 0}}}
  #declare OBTex =
  texture{pigment{granite turbulence 5 color_map{
  [.25 rgb<.70,.67,.64>][.50 rgb<.65,.63,.59>]
  [.75 rgb<.70,.67,.64>][1.0 rgb<.65,.63,.59>]}}
  finish{ambient .4 diffuse .35}}
  #declare Obelisk_Set =
  union{
  object{Obelisk scale<1.5,1.25,1>translate<-100,0,50>texture{OBTex scale 10}}
  object{Obelisk scale<1.5,1.25,1>translate< 100,0,50>texture{OBTex scale 10}}}
  union{
  #declare A = 0;
  #while  (A<10)
  object{Obelisk_Set translate 250*z*A}
  #declare A=A+1; #end rotate 45*y}
  fog{distance 150 color rgb<.70,.67,.63>fog_type 2 fog_offset 15 fog_alt 1}
// End Ken 3of3
Date: 8 Jan 1999 14:48:58
Message: <36966055.1A3B1517@bahnhof.se>
I'm at it.
//Spider
Ken wrote:
> It returneth.
> Next person !
> Ken Tyler
> camera {
>      sky <0, 1, 0>
>      look_at <0, 0, 0>
> light_source {
>      <-1000, 800, -2000>
>      color rgb<1, 1, 1>
> plane {
>      <0, 1, 0>, 0
>      pigment {
>           color rgb<1, 1, 1>
> //bobs part one
> #declare C=1;
> #while (C<9)
> sphere {0,1
> reflection .25
> #declare C=C+1;
> #end
> //bobs part one
> //Johannes' part 1
> union {
>   material{
>     texture{
>       finish {
>         ambient 0.2
>         diffuse 0.3
>         brilliance 0.099
>         phong 1.0
>         phong_size 4.3
>         specular 0.22
>         roughness 0.001
>   rotate <0, 0, 45>
> // Start Ken 3of3
>   #declare Obelisk =
>   plane{y,0 inverse}}
>   #declare OBTex =
>   union{
>   union{
>   #declare A = 0;
>   #while  (A<10)
> // End Ken 3of3
Date: 8 Jan 1999 15:27:28
Message: <3696695A.22ED9A48@bahnhof.se>
Done..
Added a sky.
     sky <0, 1, 0>
     look_at <0, 0, 0>
light_source {
     <-1000, 800, -2000>
     color rgb<1, 1, 1>
plane {
     <0, 1, 0>, 0
          color rgb<1, 1, 1>
//bobs part one
#declare C=1;
#while (C<9)
sphere {0,1
reflection .25
#declare C=C+1;
//bobs part one
//Johannes' part 1
union {
  material{
    texture{
      finish {
        ambient 0.2
        diffuse 0.3
        brilliance 0.099
        phong 1.0
        phong_size 4.3
        specular 0.22
        roughness 0.001
  rotate <0, 0, 45>
// Start Ken 3of3
  #declare Obelisk =
  plane{y,0 inverse}}
  #declare OBTex =
  union{
  union{
  #declare A = 0;
  #while  (A<10)
// End Ken 3of3
//Spider's part one .
//I decided the scene needed a sky.. I had planned on adding some mountains in the
bkg,
but I didn't have my HF's left.. (damned)
//The sky is very fuzzy and carootnish, a bit dark, but I like it...
//If there is space later, I have a #declare foor a minor wood.... (Hmm... 24 trees,
*48
(Gnarled trees.))
#declare fast=false; //Set this to true to remove some skies. (Good for speed)
#declare SkyOut = 20000; //outer
#declare SkyIn = 15000; //inner
#declare SkyScale = 270; //The scale.
sphere { //Sky layer 1
  <0,0,0>,SkyOut
  hollow
  #if(fast=true) pigment { colour red 1 } #else
      bozo
      turbulence <0.70,0.4,0.7>
      octaves 3 omega 1/6 lambda 2.5
      color_map {
        [0.0 color rgb <0.850, 0.700, 0.750> ] [0.1 color rgb <0.550, 0.600, 0.650> ]
        [0.5 color rgb <0.184, 0.184, 0.309> ] [1.0 color rgb <0.100, 0.100, 0.200> ]
      scale <3, 1, 3> scale SkyScale
    rotate <clock*360, -clock*240, clock*120>
sphere { //Sky layer 2
  <0,0,0>, SkyIn
  hollow
      bozo
      turbulence 0.65 octaves 3 omega 1/6 lambda 2.5
      color_map {
        [0.0 color rgb <0.88, 0.85,0.85> ] [0.05 color rgb <0.80, 0.75, 0.75> ]
        [0.25 color rgbf 1] [1.001 color rgbf 1] }
      scale <6, 1, 6> scale SkyScale
    rotate <clock*240, -clock*320, clock*180>
//End Spider 1
Date: 9 Jan 1999 00:37:27
Message: <3696EA0F.DC52CEEC@televar.com>
I'm going to add a bit, should be done in a few hours...
Spider wrote:
> Done..
> Added a sky.
> camera {
>      sky <0, 1, 0>
>      look_at <0, 0, 0>
> light_source {
>      <-1000, 800, -2000>
>      color rgb<1, 1, 1>
> plane {
>      <0, 1, 0>, 0
>      pigment {
>           color rgb<1, 1, 1>
> //bobs part one
> #declare C=1;
> #while (C<9)
> sphere {0,1
> reflection .25
> #declare C=C+1;
> #end
> //bobs part one
> //Johannes' part 1
> union {
>   material{
>     texture{
>       finish {
>         ambient 0.2
>         diffuse 0.3
>         brilliance 0.099
>         phong 1.0
>         phong_size 4.3
>         specular 0.22
>         roughness 0.001
>   rotate <0, 0, 45>
> // Start Ken 3of3
>   #declare Obelisk =
>   plane{y,0 inverse}}
>   #declare OBTex =
>   union{
>   union{
>   #declare A = 0;
>   #while  (A<10)
> // End Ken 3of3
bkg,
*48
> (Gnarled trees.))
>   <0,0,0>,SkyOut
>   hollow
>     pigment {
>       bozo
>       color_map {
>   #end
>   <0,0,0>, SkyIn
>   hollow
>     pigment {
>       bozo
>       color_map {
>   #end
> //End Spider 1
Date: 9 Jan 1999 02:08:25
Message: <3696FF62.98333316@televar.com>
Ah, nevermind.  I'm tired and my additions are ending up too far away to see the
detail.
Date: 9 Jan 1999 02:20:02
Message: <36970322.0@news.povray.org>
Okay in that case I got it
Mike Metheny
lon### [at] vtedu
http://loneshepherd.ml.org/
"When one's words are no better than silence, one should keep silent."
Date: 9 Jan 1999 04:01:51
Message: <36971aff.0@news.povray.org>
Here's my part.  Ack sorry I posted the image here too. (In the above post).
Mike Metheny
lon### [at] vtedu
     sky <0, 1, 0>
     look_at <0, 0, 0>
light_source {
     <-1000, 800, -2000>
     color rgb<1, 1, 1>
plane {
     <0, 1, 0>, 0
          color rgb<1, 1, 1>
//bobs part one
#declare C=1;
#while (C<9)
sphere {0,1
reflection .25
#declare C=C+1;
//bobs part one
//Johannes' part 1
union {
  material{
    texture{
      finish {
        ambient 0.2
        diffuse 0.3
        brilliance 0.099
        phong 1.0
        phong_size 4.3
        specular 0.22
        roughness 0.001
  rotate <0, 0, 45>
// Start Ken 3of3
  #declare Obelisk =
  plane{y,0 inverse}}
  #declare OBTex =
  union{
10}}
10}}}
  union{
  #declare A = 0;
  #while  (A<10)
// End Ken 3of3
in the bkg, but I didn't have my HF's left.. (damned)
24 trees, *48 (Gnarled trees.))
speed)
  <0,0,0>,SkyOut
  hollow
      bozo
      color_map {
0.650> ]
0.200> ]  }
  <0,0,0>, SkyIn
  hollow
      bozo
      color_map {
0.75> ]
//End Spider 1
// Lone Shepherd's part {Mike Metheny}
// A shuriken; transparent parts shown to show sort of a motion blur.  Would
add more but that would seriously increase render time :0
#declare star =
        merge{
                difference{
                        prism {
                                conic_sweep
                                linear_spline
                                .95, // sweep the following shape from here
                                1, // ... up through here
                                9, // the number of points making up the
shape ...
                                <0,3>, <.75,.75>, <3,0>, <.75,-.75>,
<0, -3>, <-.75,-.75>, <-3,0>, <-.75,.75>,<0,3>
                                translate<0,-1,0>
                       cylinder{<0,-4,0>,<0,4,0>,.5}
                difference{
                        prism {
                                conic_sweep
                                linear_spline
shape ...
                                rotate <180,0,0>
                                translate <0,1,0>
                 torus{.5,.05}
#declare bozotext1 =
        bozo
        color_map {
          [0.00 color rgb<0.184314,0.309804,0.184314>]
      [0.33 color rgb 0]
      [0.66 color rgb<0.55,0.47, 0.14>]
      [1.00 color rgb .5]
        turbulence 3
        scale <3,.8,.8>*1.3
        rotate <5,10,30>
   finish { phong .4 reflection .5 metallic}
#declare startrail =
union{       //transparent stars
#declare B=1;
#while (B<5)
#declare bozotext2 =
        bozo
        color_map {
          [0.00 color rgbt<0.184314,0.309804,0.184314,1-.2*B>]
      [0.33 color rgbt <0,0,0,1-.02*B>]
      [0.66 color rgbt<0.55,0.47, 0.14,1-.2*B>]
      [1.00 color rgbt <.5,.5,.5,1-.2*B>]
        turbulence 3
        scale <3,.8,.8>*1.3
        rotate <5,10,30>
object{star texture{bozotext2} scale 2 rotate<100,10,(5*B)-15> translate
<-75+2*B,25-4*B,-33-8*B>}
#declare B=B+1; #end
object{star texture{bozotext1}  scale 2 rotate <100,10,-5> translate  <-65,
5, -73>}
object{startrail}
//End Lone Shepherd (Mike Metheny) part
Date: 10 Jan 1999 17:45:43
Message: <36992DFD.4B5DCCCE@pacbell.net>
Mind if I take a whack at it?    (rendering on a P200 w 64MB, this MIGHT take a
few hours...)
> Mike Metheny
> lon### [at] vtedu
> camera {
>      sky <0, 1, 0>
>      look_at <0, 0, 0>
> light_source {
>      <-1000, 800, -2000>
>      color rgb<1, 1, 1>
> plane {
>      <0, 1, 0>, 0
>      pigment {
>           color rgb<1, 1, 1>
> //bobs part one
> #declare C=1;
> #while (C<9)
> sphere {0,1
> reflection .25
> #declare C=C+1;
> #end
> //bobs part one
> //Johannes' part 1
> union {
>   material{
>     texture{
>       finish {
>         ambient 0.2
>         diffuse 0.3
>         brilliance 0.099
>         phong 1.0
>         phong_size 4.3
>         specular 0.22
>         roughness 0.001
>   rotate <0, 0, 45>
> // Start Ken 3of3
>   #declare Obelisk =
>   plane{y,0 inverse}}
>   #declare OBTex =
>   union{
> 10}}
> 10}}}
>   union{
>   #declare A = 0;
>   #while  (A<10)
> // End Ken 3of3
> speed)
>   <0,0,0>,SkyOut
>   hollow
>     pigment {
>       bozo
>       color_map {
> 0.650> ]
> 0.200> ]  }
>   #end
>   <0,0,0>, SkyIn
>   hollow
>     pigment {
>       bozo
>       color_map {
> 0.75> ]
>   #end
> //End Spider 1
> #declare star =
>         merge{
>                 difference{
>                         prism {
>                                 conic_sweep
>                                 linear_spline
> shape ...
>                                 translate<0,-1,0>
>                 difference{
>                         prism {
>                                 conic_sweep
>                                 linear_spline
> shape ...
>                                 rotate <180,0,0>
>                                 translate <0,1,0>
>                  torus{.5,.05}
> texture {
>       pigment {
>         bozo
>         color_map {
>       [0.33 color rgb 0]
>       [1.00 color rgb .5]
>         turbulence 3
>         scale <3,.8,.8>*1.3
>         rotate <5,10,30>
> #declare B=1;
> #while (B<5)
> texture {
>       pigment {
>         bozo
>         color_map {
>         turbulence 3
>         scale <3,.8,.8>*1.3
>         rotate <5,10,30>
> 5, -73>}
> object{startrail}
 george erhard
 microsoft certified system engineer
 http://home.pacbell.net/dcnblues
 remove "nospam" from domain when replying
Date: 10 Jan 1999 19:17:53
Message: <3699438F.4263A12C@pacbell.net>
OK, done.  Included is the source for this and a small file to make the
heightfield.  Render it separately (160x100 no AA works great) and put the image
it makes in your Include path.
But, y'all knew that already...
I probably 'broke the rules' by making this two files instead of one, but then
again, this is pretty freeform! ":)
// Desc: "A Little Game"
// Date:  1/10/98
// Auth:  (gemelli started it...)
     sky <0, 1, 0>
     look_at <0, 0, 0>
light_source {
     <-1000, 800, -2000>
     color rgb<1, 1, 1>
plane {
     <0, 1, 0>, 0
          color rgb<1, 1, 1>
//bobs part one
#declare C=1;
#while (C<9)
sphere {0,1
reflection .25
#declare C=C+1;
//bobs part one
//Johannes' part 1
union {
  material{
    texture{
      finish {
        ambient 0.2
        diffuse 0.3
        brilliance 0.099
        phong 1.0
        phong_size 4.3
        specular 0.22
        roughness 0.001
  rotate <0, 0, 45>
// Start Ken 3of3
  #declare Obelisk =
  plane{y,0 inverse}}
  #declare OBTex =
  union{
10}}
10}}}
  union{
  #declare A = 0;
  #while  (A<10)
// End Ken 3of3
// in the bkg, but I didn't have my HF's left.. (damned)
// 24 trees, *48 (Gnarled trees.))
  <0,0,0>,SkyOut
  hollow
      bozo
      color_map {
0.650> ]
0.200> ]  }
  <0,0,0>, SkyIn
  hollow
      bozo
      color_map {
0.75> ]
//End Spider 1
// add more but that would seriously increase render time :0
#declare star =
        merge{
                difference{
                        prism {
                                conic_sweep
                                linear_spline
                                .95, // sweep the following shape from here...
                                9, // the number of points making up the shape
                                translate<0,-1,0>
                difference{
                        prism {
                                conic_sweep
                                linear_spline
                                rotate <180,0,0>
                                translate <0,1,0>
                 torus{.5,.05}
        bozo
        color_map {
      [0.33 color rgb 0]
      [1.00 color rgb .5]
        turbulence 3
        scale <3,.8,.8>*1.3
        rotate <5,10,30>
#declare B=1;
#while (B<5)
        bozo
        color_map {
        turbulence 3
        scale <3,.8,.8>*1.3
        rotate <5,10,30>
5, -73>}
object{startrail}
// begin DcnBlues contribution (george erhard)
// sort of hexagonal thing to fill up the space in the right front corner...
height_field
  tga
  "hexplane.tga"     // source posted after this source, render seperately!
    pigment { rgb <0.658824, 0.658824, 0.658824> }
    finish {
        ambient 0.3
        diffuse 0.7
        reflection 0.15
        brilliance 8
        specular 0.8
        roughness 0.1
    normal {
        bumps -0.5
        scale <1, 0.001, 0.001>
     scale <25, 3, 25>
     translate  <-95, 0, -115>
    // End dcnblues contribution... such as it was!  :)
// END "LITTLEGAME"Source
// HEIGHT-FIELD GENERATOR FILE -- render this seperately!
plane
  z, // backplane
  7.5 // move it a little ways away
        hexagon
        color rgb 1
        color rgb 0.5
        color rgb 0
        rotate 90*x
  finish {ambient 1  diffuse 0} // look ma, no lights needed!
 george erhard
 remove "nospam" from domain when replying via e-mail
Date: 10 Jan 1999 21:14:24
Message: <36995DA5.D310F145@bahnhof.se>
let me ask here...
Are we allowed to add again ???
Just wondering, having a few ideas... *grin*
//Spider
Date: 10 Jan 1999 22:10:59
Message: <36996BC5.3BB74528@virginia.edu>
I have the file now... bbiab..:))
Steve
Date: 11 Jan 1999 00:49:44
Message: <369990F8.89541F1A@virginia.edu>
I am also finished.  Here is the source (again, detatch the heightfield
source and render separately I did it at 320x240 no AA)
Steve
// Date:  1/10/98
     sky <0, 1, 0>
     look_at <0, 0, 0>
light_source {
     <-1000, 800, -2000>
     color rgb<1, 1, 1>
plane {
     <0, 1, 0>, 0
          color rgb<1, 1, 1>
//bobs part one
#declare C=1;
#while (C<9)
sphere {0,1
reflection .25
#declare C=C+1;
//bobs part one
//Johannes' part 1
union {
  material{
    texture{
      finish {
        ambient 0.2
        diffuse 0.3
        brilliance 0.099
        phong 1.0
        phong_size 4.3
        specular 0.22
        roughness 0.001
  rotate <0, 0, 45>
// Start Ken 3of3
  #declare Obelisk =
  plane{y,0 inverse}}
  #declare OBTex =
  union{
scale 10}}
scale 10}}}
  union{
  #declare A = 0;
  #while  (A<10)
     #declare A=A+1;
  rotate 45*y}
fog_alt 1}
// End Ken 3of3
mountains
(Hmm...
speed)
  <0,0,0>,SkyOut
  hollow
      bozo
      color_map {
0.600,
0.650> ]
0.100,
0.200> ]  }
  <0,0,0>, SkyIn
  hollow
      bozo
      color_map {
0.75> ]
//End Spider 1
Would
#declare star =
        merge{
                difference{
                        prism {
                                conic_sweep
                                linear_spline
here...
shape...
                                translate<0,-1,0>
                difference{
                        prism {
                                conic_sweep
                                linear_spline
here...
shape...
                                rotate <180,0,0>
                                translate <0,1,0>
                 torus{.5,.05}
        bozo
        color_map {
      [0.33 color rgb 0]
      [1.00 color rgb .5]
        turbulence 3
        scale <3,.8,.8>*1.3
        rotate <5,10,30>
#declare B=1;
#while (B<5)
        bozo
        color_map {
        turbulence 3
        scale <3,.8,.8>*1.3
        rotate <5,10,30>
<-65,
5, -73>}
object{startrail}
corner...
height_field
  tga
seperately!
    finish {
        ambient 0.3
        diffuse 0.7
        reflection 0.15
        brilliance 8
        specular 0.8
        roughness 0.1
    normal {
        bumps -0.5
     scale <25, 3, 25>
//Begin Steve's Contribution.
//I know it is really ugly code, but it is an old formula that I
modified
//to fit the situation.  (It took me awhile to figure out what i wanted
to add)
#declare Element=sphere{<0,0,0>, 0.5}
#declare Side = 135.0;
#declare Angle = ((12-2)/12)*pi;
#declare a = 0.0;
#declare b = 0.0;
#declare c=1.0;
#while (c<=12)
       #declare Point = <a,0,b>;
       #declare a = a+Side*sin((pi/2)-(2*pi-Angle));
       #declare b = b+Side*sin(2*pi-Angle);
       #declare Angle = Angle + ((12-2)/12)*pi;
       object{
              Element
              translate Point
               pigment {rgb <1,0,0>}
               finish {
                       ambient 0.2
                       diffuse 0.3
                       specular 0.8
                       reflection 0.7
                       roughness 0.0001
                       metallic
       #declare c=c+1;
#declare c=1.0;
#declare a = 0.0;
#declare b = 0.0;
#while (c<=12)
       #declare d=c;
       #declare a2=a;
       #declare b2=b;
       #declare Angle2=Angle;
       #while (d<12)
              #declare Point2 = <a2,0, b2>;
              #declare a2 = a2+Side*sin((pi/2)-(2*pi-Angle2));
              #declare b2 = b2+Side*sin(2*pi-Angle2);
              #declare Angle2 = Angle2 + ((12-2)/12)*pi;
              cylinder{Point, Point2 ,0.5
                       finish {
                              ambient 0.1
                              diffuse 0.2
                              specular 1
                              reflection 0.8
                              roughness 0.0001
                              metallic
              #declare d=d+1;
       #declare c=c+1;
//END Steve's section
plane
  z, // backplane
        hexagon
        color rgb 1
        color rgb 0.5
        color rgb 0
        rotate 90*x
Date: 11 Jan 1999 04:04:22
Message: <3699BE5C.E9462BBA@imerir.asso.fr>
I think there's no problem !
Go ! Go ! Go !
                        David GEMELLI
Spider a écrit:
> let me ask here...
> //Spider
Subject: Re: a little game (Bob Hughes)
Date: 11 Jan 1999 15:44:01
Message: <3697F61A.F3E07FBF@melbpc.org.au>
Bob Hughes wrote:
> //bobs part one
> <snip>
> reflection .25
Hi Bob.
    I am having trouble rendering your part of A Little Game.
    POV-Ray stops during parsing with an error message to the affect that
    "Interior" is an unknown command.
    I am using POV-Ray 3.01, and I could not find it in the POV-Ray help files.
Regards Alex
  ,-._|\  Alex McMurray
 /  Oz  \ ale### [at] melbpcorgau               Melbourne PC User Group.
 \_,--.x/ P.O. Box 215 Melton. Vic.  3337                     Australia
       v
Date: 11 Jan 1999 15:51:27
Message: <369A63D4.B92672EB@pacbell.net>
Alex McMurray wrote:
> Bob Hughes wrote:
> > //bobs part one
> > <snip>
> > reflection .25
> Hi Bob.
> Regards Alex
>        v
  Interior is a new function of Pov v3.1. You should consider upgrading
to the most recent version as it has many new and very useful features.
To get past this for now just comment out the interior statement.
Move what you can into the finish statement to render the scene with
your additions and then remove them afterwards to repost the scene
here.
I presume this will be acceptable with the rest of the participants as
well. Most everyone else is already usin g v3.1 so it shoudn't cause
anyone else problems. Remeber that if your object uses halo's
or atmoshphere it won't work for people using v3.1 as these features
have been discontinued.
Ken Tyler
Date: 12 Jan 1999 07:09:33
Message: <369B3B08.C86D2939@pacbell.net>
Stephen Lavedas wrote:
>   union{
>   #declare A = 0;
>   #while  (A<10)
>      #declare A=A+1;
>   #end
>   rotate 45*y}
Hey who indented my while loop ? Stephen was that you ? Just couldn't
stand it could you :)
Ken Tyler
Date: 12 Jan 1999 07:10:48
Message: <369B3AEE.8F4204FA@bahnhof.se>
Might have been me.
I happened to indent all the file, until I re-read it, and realised it said, DON'T
change
others work... Well, I make mistakes :-)
//Spider
> >   union{
> >   #declare A = 0;
> >   #while  (A<10)
> >      #declare A=A+1;
> >   #end
> >   rotate 45*y}
> Ken Tyler
Date: 12 Jan 1999 11:25:14
Message: <369B776A.66B8361A@virginia.edu>
I confess.  I was running through the code fixing the mailer line breaks
and I couldn't help myself.  Please forgive me:)
Steve
> >   union{
> >   #declare A = 0;
> >   #while  (A<10)
> >      #declare A=A+1;
> >   #end
> >   rotate 45*y}
> Ken Tyler
Subject: Re: a little game (George Erhard)
Date: 10 Feb 1999 19:38:32
Message: <36c22688.0@news.povray.org>
Hello George
I've been following "a little game" as I think it is a great way to discover
PoVRay.
All was fine untill Your extra file I have aftermuch head scratching enabled
my win95 version to output *.tga files. But I still get an error message
saying 'Illegal character in input file, value is 2' !!!
Can any body enlighten me as to what I have missed or done wrong?
Am new to this program and am in awe .
I hope to contribute when I feel less humbled.
ross williams
Date: 13 Feb 1999 18:40:47
Message: <36C60D7F.2C0B8B69@virginia.edu>
The first thing I would check is to make sure the lines haven't been
wrapped until they aren't commented out anymore (I know for a fact it
happened to my code). Also, you don't say exactly, but make sure that
you are removing the heightfield code from the source and making it into
a new source file.  If you can't get it to work, email me and I'll send
you my version with the files separated and working (no line wrap
problems)
Steve
Ross Williams wrote:
> Hello George
> PoVRay.
> ross williams
Date: 7 Apr 1999 19:20:34
Message: <370BD8F4.36F82138@pbi.net>
Wow.  Here I've been so distracted by WORK that I haven't kept up with this.  Me
bad.
Um.. what Steve said.  Problem with these newsreaders is, they tend to wrap long
lines, which will FUBAR the code very efficiently.   Also, I broke the rules (what
rules? :)  by adding in a secondary file to generate the heightfield... but then
again, people are doing that all the time with POV.  Get used to it. :)
Oh, also, it doesn't matter if your system can't interpret a TGA file directly, it
doesn't have to.  If you tell POV that the HF source is TGA format, it will handle
it.
> problems)
> Steve
> > Hello George
> > PoVRay.
> > ross williams
Date: 13 Aug 1999 00:16:19
Message: <37b39c13@news.povray.org>
In article <370B127F.BD267967@imerir.asso.fr>, gemelli david <gem### [at] imerirassofr>
>with
>post
>relation
This is like the continuing stories (they will start one up once in a while in
the interactive fiction newsgroups). You may start something that could be
done as a monthly project. Obviously some additional rules (based on some
things I've seen) would have to be setup, like limiting either features or
versions of POV to use (i.e. 3.01 halos vs 3.1 media). Some limits on line
length or something might have to be done (that or move this to
povray.binaries.scenes).
PHIL
-----[ to reply, the domain name is "concentric.net" ]-----
Spelling mistakes brought to you courtesy of the
Allentown Public School System.
