POV-Ray : Newsgroups : povray.text.scene-files : 3D Text with Sphere_sweeps : 3D Text with Sphere_sweeps Server Time
12 Mar 2026 20:10:48 EDT (-0400)
Date: 20 Jun 2022 06:35:00
Message: <web.62b04c62ac40b3a1cf03b124607c1b34@news.povray.org>
Some notes:
The MakeCharacter () macro uses the following variables:
Coordinate [] is an array containing <x, y> spline coordinates plus a diameter
multiplier. The actual format is <x, y, multiplier>.
NPoints indicates the number of spline points in the Coordinate [] array.
HeightFactor adjusts the scale of the character without changing the diameter.
BaseRadius is the default sphere_sweep diameter.
UseLastMinsAndMaxs is useful for making multiple parts of a character to be
unioned together.
It's fairly easy but a little tedious to make characters with this macro. What
worked for me was to make a bitmap image of the characters with a paint program
then mark locations along a path following the center of the character strokes.
The <x, y> coordinates of the marks can then be typed into Coordinate [] array
entries and if necessary the diameter multipliers can be adjusted. With a little
practice one can achieve acceptable results. Don't forget that the first and
last locations aren't actually plotted since the macro uses the b_spline
sphere_sweep method.
Happy raytracing!
Kind regards,
Dave Blandston
Download '3dtext.pov.txt' (11 KB)
