POV-Ray : Newsgroups : povray.text.scene-files : Stepped function offset (attempt #2) : Re: Stepped function offset (attempt #2) Server Time
8 Apr 2026 05:11:17 EDT (-0400)
Date: 25 Jan 2020 13:40:00
Message: <web.5e2c8a8ada480183f86f6e3a0@news.povray.org>
Mike Horvath <mik### [at] gmailcom> wrote:
> I have created the attached scene.
> It works well, except the pigment function needs to be offset at the
> beginning and end of the gradients "CSolid_HSLSphere_Saturation" and
> "CSolid_HSLSphere_Lightness". The end result is supposed to look like this:
> https://commons.wikimedia.org/wiki/File:HSLSphere.svg
> Can someone clue me in on how to do this? Thanks.
Hi Mike
Perhaps the code below will help you advance.
Tor Olav
http://subcube.com
https://github.com/t-o-k
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.7;
global_settings { assumed_gamma 1.0 }
#include "functions.inc"
#declare AngleFn = function { f_th(x, 0, z) + pi };
#declare D = 2*pi/6;
#declare H = D/2;
#declare SectorFn =
    function(s) {
        0
        + select(s - (0*D    ), 0, select(s - (1*D - H), 0, 0))
        + select(s - (1*D - H), 0, select(s - (2*D - H), 1, 0))
        + select(s - (2*D - H), 0, select(s - (3*D - H), 2, 0))
        + select(s - (3*D - H), 0, select(s - (4*D - H), 3, 0))
        + select(s - (4*D - H), 0, select(s - (5*D - H), 4, 0))
        + select(s - (5*D - H), 0, select(s - (6*D - H), 5, 0))
        + select(s - (6*D - H), 0, select(s - (6*D    ), 6, 0))
#declare Colors =
    array[7] {
        color rgb <1, 0, 0>,  // Rd
        color rgb <1, 0, 1>,  // Mg
        color rgb <0, 0, 1>,  // Bu
        color rgb <0, 1, 1>,  // Cy
        color rgb <0, 1, 0>,  // Gn
        color rgb <1, 1, 0>,  // Ye
        color rgb <1, 0, 0>   // Rd
#declare C = 1/6;
#declare G = C/2;
#declare SectorPigment =
        function { SectorFn(AngleFn(x, y, z))*C }
        color_map {
            [ 0*C     Colors[0] ]
            [ 1*C - G Colors[0] ]
            [ 1*C - G Colors[1] ]
            [ 2*C - G Colors[1] ]
            [ 2*C - G Colors[2] ]
            [ 3*C - G Colors[2] ]
            [ 3*C - G Colors[3] ]
            [ 4*C - G Colors[3] ]
            [ 4*C - G Colors[4] ]
            [ 5*C - G Colors[4] ]
            [ 5*C - G Colors[5] ]
            [ 6*C - G Colors[5] ]
            [ 6*C - G Colors[6] ]
            [ 6*C     Colors[6] ]
#declare Rmaj = 9;
#declare Rmin = 1;
torus {
    Rmaj, Rmin
    pigment { SectorPigment }
#declare R = 7;
#declare RND = seed(7352);
#for (N, 0, 1000)
    #declare X = R*(1 - 2*rand(RND));
    #declare Z = R*(1 - 2*rand(RND));
    #if (f_r(X, 0, Z) < R)
        #declare Angle = AngleFn(X, 0, Z);
        #declare Sector = SectorFn(Angle);
        sphere {
            <X, 0, Z>, 0.2
            pigment { Colors[Sector] }
    #end // if
#end // for
    location 24*y
    look_at 0*y
light_source {
    100*<-1, 3, 2>
    color rgb <1, 1, 1>
