POV-Ray : Newsgroups : povray.text.scene-files : bounding box calculator : bounding box calculator Server Time
17 Mar 2026 04:00:23 EDT (-0400)
Date: 27 Oct 2019 11:05:01
Message: <web.5db5b0ff51c96acafeeb22ff0@news.povray.org>
hi,
as part of some stuff I'm playing with, I noticed that the bounding box of the
"Boy's Surface"[1] contains a lot of .. air.  :-)  after reading up on things, I
wrote a macro which "scans" an object's BB to find the actual dimensions (using
'inside()' tests), and print out information about how much "slack" is found[2]
between object and bounding box face(s).
[1]
<http://news.povray.org/povray.general/thread/%3Cweb.5b1bb8bbb1f83992458c7afe0%40news.povray.org%3E/>
[2] v basic still.  only distinguishes three scenarios: up to 1% space all
around, up to 5%, and over 5%.
I've tested the code with a handful of different objects, and so far, so good.
perhaps someone else will find use(s) for it too.  it is a work in progress
though, and it would be nice if one or two wanted to be "guinea pigs", beta
test, and help find bugs/problems, suggest improvements.
there is no documentation apart from a few header lines in the .inc, but the
macro is easy to use:
  macro Bounder(object, optional resolution)
where object is some object identifier, and the resolution an integer, or a
3-vector of ints, giving the number of "probes" per POV unit.
the simplest usage example is something like:
-----<snip>-----
#version 3.8;
global_settings {...}
#declare O = cylinder {...};
#include "bounder.inc"
Bounder(O,)
-----<snip>-----
uses the default resolution <50,50,50>.
the cut'n'paste stuff below shows the before and after for the 'boy-file.pov'
(with minimal adaptations, and renamed), with timings.  the difference is that
for the second run I'd added a 'clipped_by {box {}}' calculated from the values
in the "diff" lines, and a 'bounded_by {clipped_by}', as suggested in the docs.
enjoy, jr.
-----<snip>-----
the 'povparse' command is a BASH alias, shown here in case it's of interest to a
Linux user, useful when only the '#debug' output matters:
  alias povparse='nice -n 19 povray -w32 -h32 -D -F -GS -GR +i'
Script started on Sun 27 Oct 2019 12:16:05 GMT
jr@crow:1:bounder$ time povparse bta.pov
Persistence of Vision(tm) Ray Tracer Version 3.8.0-alpha.10013324.unofficial
==== [Parsing...] ==========================================================
----------[Bounder info]------------------------------------------------
  resolutions (per POV unit): <20, 20, 20>
     object "as is" (BB) min: <-6.000000, -6.000000, -6.000000>
     object "as is" (BB) max: <5.000000, 5.000000, 5.000000>
     object aligned (BB) max: <11.000000, 11.000000, 11.000000>
    axis 'X' scan resolution: 220
             probes per face: 48400
         scan axis increment: 0.05000000
          face col increment: 0.05000000
          face row increment: 0.05000000
                           -: ...scanning...
Parsing 140263K tokens
              total # probes: 3000800
    axis 'Y' scan resolution: 220
                           -: ...scanning...
Parsing 289350K tokens
              total # probes: 3049200
    axis 'Z' scan resolution: 220
                           -: ...scanning...
Parsing 432765K tokens
            diff lower bound: 1.95000000,2.00000000,1.95000000
            diff upper bound: 0.95000000,0.95000000,0.95000000
  object bounding box has at least 5% "slack".
==== [Rendering...] ========================================================
Rendered 1024 of 1024 pixels (100%)
POV-Ray finished
real 1m37.487s
user 1m36.884s
sys 0m0.041s
Script started on Sun 27 Oct 2019 12:18:31 GMT
jr@crow:4:bounder$ time povparse bt2.pov
     object "as is" (BB) min: <-4.100000, -4.100000, -4.100000>
     object "as is" (BB) max: <4.100000, 4.100000, 4.100000>
     object aligned (BB) max: <8.200000, 8.200000, 8.200000>
    axis 'X' scan resolution: 164
             probes per face: 26896
                           -: ...scanning...
Parsing 4616K tokens
              total # probes: 161376
    axis 'Y' scan resolution: 164
                           -: ...scanning...
Parsing 9246K tokensParsing 13950K tokens
    axis 'Z' scan resolution: 164
                           -: ...scanning...
Parsing 18627K tokensParsing 23261K tokens
            diff lower bound: 0.05000000,0.05000000,0.05000000
            diff upper bound: 0.05000000,0.05000000,0.05000000
  object bounding box is (near) optimal.
POV-Ray finished
real 0m5.896s
user 0m5.236s
sys 0m0.006s
Download 'bounder.inc.txt' (9 KB)
