POV-Ray : Newsgroups : povray.text.scene-files : foreach macro : Re: foreach macro Server Time
13 Mar 2026 02:10:14 EDT (-0400)
  Re: foreach macro
Date: 28 Apr 2021 09:48:29
Message: <608967ad$1@news.povray.org>
On 4/27/21 7:56 PM, William F Pokorny wrote:
> On 4/27/21 6:52 AM, jr wrote:
>> hi,
> Played a few minutes with this just now and you can get your original
> code to run if you change the tail m_l10 macro to:
> #macro m_l10(i_,n_)
> #end
> Parse_String is involved in what's happening, but it's not clear to me,
> why - some scope issue maybe as it comes after the last "call" to m_l10.
OK.
Not 100% sure, in that I've not proven it by making all the
'parse_fore.tmp' names unique, but I believe we are reading (or I
suspect continuing to read) via a now back in scope #include to a common
file with updated, and longer contents written in the previous deeper
scope(1).
If in your include we add two lines to 'empty' the included file after
including / dynamically interpreting the intended string:
#macro fore_exec(s_)
   #local fn_ = "parse_fore.tmp";
   #fopen fp_ fn_ write
   #write (fp_,s_)
   #fclose fp_
   #include fn_
   #fopen fp_ fn_ write  // Making file empty here fixes issue too
   #fclose fp_
The code runs OK.
You ask, "So, this is an issue to which the strings.inc's
Parse_String() macro has always been exposed too?" Yes, I suspect so
though I've not gone back to older versions of POV-Ray to try and
reproduce the issue.
Is it worth further chasing and changing, if this is how v3.8 works
today? I vote NO.
I'm thinking the practical fix is our 'Parse_String()'s should always
empty the file just included.
We should remember too the Parse_String() method is a hack; It's bad
practice to be writing and reading the same file name from multiple
scene 'scopes' or invocations of POV-Ray.
(1) - POV-Ray re-reads files by file positions while working with macros
and includes. What I think you hit on in changing the tail macro name
and finding the code working, was changing to a macro name with the same
(or shorter) length as (all) the earlier ones in the recursion. Meaning
the file position markers didn't change (with respect to the file
contents) in a way causing additional characters to be read from the
'common' parse_fore.tmp file name. This theory can be tested by, say,
changing the m_l10 name to say ml10 - should run?
Bill P.
