POV-Ray : Newsgroups : povray.text.scene-files : Example constraining media inside an isosurface shape. : Re: Example constraining media inside an isosurface shape. Server Time
6 Apr 2026 06:43:02 EDT (-0400)
Date: 8 Jan 2016 13:13:23
Message: <568ffc43$1@news.povray.org>
On 1/8/2016 1:09 PM, Mike Horvath wrote:
> On 1/7/2016 11:52 PM, William F Pokorny wrote:
>> An example of constraining media inside an isosurface using the function
>> used to define the isosurface. Code in answer to a question asked in the
>> "Spiral tube?" thread in povray.general.
>> Bill P.
> I don't understand the parameters of the helix shape. From the docs:
> P0 : Number of helixes - e.g. 2 for a double helix
> P1 : Period - is related to the number of turns per unit length
> P2 : Minor radius (major radius > minor radius)
> P3 : Major radius
> P4 : Shape parameter. If this is greater than 1 then the tube becomes
> fatter in the y direction
> P5 : Cross section type
> P6 : Cross section rotation angle (degrees)
> What is the "Shape parameter", "Cross section type" and "Cross section
> rotation angle"? Are these explained in the docs?
> Mike
Also, the way the shape gets sliced at the edges is really ugly. Is
there any way to make a straight cut perpendicular to the curve?
Mike
