POV-Ray : Newsgroups : povray.text.scene-files : Crescent Moon in daylight : Crescent Moon in daylight Server Time
23 Mar 2026 12:11:00 EDT (-0400)
Date: 12 Jan 2011 03:12:45
Message: <4d2d627d@news.povray.org>
See Stephen's message in p.g.
// Moon in the sky:
#if (Moon)
#debug "Including the moon...\n"
#declare MoonMap =
   material {
            image_map {
               png   "PlanetMaps\MoonMap.png"
               map_type 1
               once
               interpolate 2
            scale <1,1,1>
            //rotate 90*x
         normal {
            bump_map {
               png   "PlanetMaps\MoonBump.png"
               map_type 1
               once
               interpolate 2
            scale <1,1,1>
            //rotate 90*x
            bump_size 1.0
         finish {
            ambient 0.0
            diffuse 0.5
      //rotate <20.0, 0.0, -25.0>
sphere { // Moon
  <0,0,0>,1
  material {
    MoonMap
  scale 80.0
  rotate -90*y
  translate <-300.0, 200.0, 1000.0>
// Sky
#declare BlueSkySphere =
           gradient y
           pigment_map {
            [0.0 rgb <0.6,0.7,1.0>*1.5 transmit 0.5]
            [1.0 rgb <0.437467, 0.824265, 1.0>*1.5 transmit 0.5]
         finish {
            ambient 0.9
            diffuse 0.0
#declare CosmosSkySphere =
            color rgbt <0,0,0,1>
         finish {
            ambient 0.0
            diffuse 0.0
#declare SkyShape = 2; // 1=plane; 2=sphere
#if (SkyShape = 1)
plane {
  y,0
  texture { BlueSkySphere }
  interior_texture { CosmosSkySphere }
  no_shadow
  no_reflection
  hollow
  scale <400.0, 1.0, 400.0>
  rotate <-90.0, 0.0, 0.0>
  translate  400.0*z
#else
sphere {
  <0,0,0>,1
  interior_texture { CosmosSkySphere } //using inverse puts the inside of
the sphere outside
  no_shadow
  no_reflection
  inverse // no need for hollow
  scale 400
#end //of Moon
