POV-Ray : Newsgroups : povray.programming : IPoint Server Time
11 May 2025 21:46:18 EDT (-0400)
  IPoint (Message 1 to 7 of 7)
Subject: IPoint
Date: 7 Jun 2023 04:00:00
Message: <web.6480385a29d3d13a6cf6dae3fc1cf70c@news.povray.org>
I tried to output the IPoint of each ray, but I found something was not right
I built the following small mesh2Object
orthographic
location <20.0, 54.949548, 0.0>
look_at <0.0, 0.0, 0.0>
right 100*x
up 100*y
light_source {
color rgb<1, 1, 1>
parallel
point_at <0.0, 0.0, 0.0>
#declare base_02 = mesh2 {
vertex_vectors {
3
<2.952163, 3.632734, -10.591118>,
<1.556791, 3.632964, -10.593109>,
<2.93827, 3.516272, -10.833504>,
face_indices {
1
<0,1, 2>,
union {
object {base_02
pigment { color rgb<1.0, 1.0, 1.0> }
finish {reflection {0.5} ambient 0 diffuse 0.015 specular 0.7 roughness 0.00085}
translate <0, 0, 3> //
rotate <0, 0, 0> //
Why is its IPoint
1.976229 3.602266-7.656250
2.419499 3.601889-7.656250
2.862769 3.601512-7.656250
I mean, obviously the z coordinate of the mesh2 Object is around -10, but how
does it intersect at -7.656250?
Subject: Re: IPoint
Date: 7 Jun 2023 04:40:00
Message: <web.64804131b3efc58b49d80446cde94f1@news.povray.org>
hi,
> vertex_vectors {
> 3
> face_indices {
> 1
> <0,1, 2>,
> union {
> object {base_02
> texture {
> rotate <0, 0, 0> //
> Why is its IPoint
hope I interpret correctly, but is -10 + (translate 3) not 7 ?  :-)
regards, jr.
Subject: Re: IPoint
Date: 7 Jun 2023 04:55:00
Message: <web.64804559b3efc586cf6dae3fc1cf70c@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> > vertex_vectors {
> > 3
> > face_indices {
> > 1
> > <0,1, 2>,
> > union {
> > object {base_02
> > texture {
> > rotate <0, 0, 0> //
> > Why is its IPoint
> regards, jr.
Thank you.I also found this mistake after sending this message. Sorry to bother
you with such a small problem
Subject: Re: IPoint
Date: 7 Jun 2023 05:15:00
Message: <web.648049a9b3efc5817bac71e8ffb8ce3@news.povray.org>
maybe because of translate <0, 0, 3>?
ingo
Subject: Re: IPoint
Date: 7 Jun 2023 06:05:00
Message: <web.6480559bb3efc58b49d80446cde94f1@news.povray.org>
hi,
no problem.  (I see such "slip ups" to mean that a (short) break, to have a
coffee or doing something else, is due.  ;-))
regards ,jr.
Subject: Re: IPoint
Date: 10 Jun 2023 05:21:05
Message: <64844081$1@news.povray.org>
yes, translate, but POVRay say :
-10.591118 + 3.000000 = -7.591118
and "225012156" wrote that z is equal to -7.656250
so a gap of 0.065132.
another subtlety ?
Kurtz le pirate
Compagnie de la Banquise
Subject: Re: IPoint
Date: 10 Jun 2023 08:10:00
Message: <web.648467d5b3efc581f9dae3025979125@news.povray.org>
> another subtlety ?
There are two vertices with z = -10.591118
and one with z = -10.833504
vertex_vectors {
3
So it's not completely vertical, which means the intersection point will be
farther back than -10.591118.  The z coordinate of the centroid of the
translated triangle lies at  -7.67195467, but maybe it's intersecting at one of
the other triangle centers.
- BE
