POV-Ray : Newsgroups : povray.programming : Location of Noise() and VScale() in source? Server Time
11 Oct 2025 05:11:29 EDT (-0400)
  Location of Noise() and VScale() in source? (Message 1 to 4 of 4)
Subject: Location of Noise() and VScale() in source?
Date: 19 Apr 2019 19:45:00
Message: <web.5cba5d793a7caf464eec112d0@news.povray.org>
I was just poking around in the turbulence code, and it references
Noise ()
and
VScale ()
I was wondering where those were located.
I tried
find -type f -exec grep -H ' Noise(' {} \;
But it's not in pattern, texture, normal, or fnintern (that I see)
Subject: Re: Location of Noise() and VScale() in source?
Date: 19 Apr 2019 23:35:00
Message: <web.5cba922955627606284a685a0@news.povray.org>
> Noise ()
> and
> VScale ()
> I tried
Hello Bill
There's a definition of Noise here:
https://github.com/POV-Ray/povray/blob/master/source/core/material/noise.h#L196
In which file did you see VScale ?
BTW: Have you ever tried Midnight Commander ?
I find it very easy to use when searching through a lot of files.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 20 Apr 2019 08:20:00
Message: <web.5cbb0e56556276064eec112d0@news.povray.org>
"Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmailcom> wrote:
> Hello Bill
Hi TOK, long time no see   :)
Hope you're doing well.
excellent.
I think with fresh eyes, I see that Noise is a call to PortableNoise - so maybe
that will let me trace the code  :)
inline DBL Noise(const Vector3d& EPoint, int noise_generator) { return
PortableNoise(EPoint, noise_generator); }
VScale is called from the Turbulence function in texture.cpp
[I don't actually do any real C++, but it looks like "const TURB *Turb" is
declaring use of a constant named TURB which comes from - a class (?) or a
struct (?) or an internal private part of another part of the code called "Turb"
and "dereferences" that with the * ?
Similar later on with "int Octaves=Turb->Octaves;", Lambda and Omega.
I have only the most tenuous grasp of the dot . and arrow -> operators at this
point.]
DBL Turbulence(const VECTOR EPoint, const TURB *Turb, int noise_generator)
 int i;
 DBL Lambda, Omega, l, o, value;
 VECTOR temp;
 if (noise_generator>1)
  value = (2.0 * Noise(EPoint, noise_generator) - 0.5);
  value = min(max(value,0.0),1.0);
 } else {
  value = Noise(EPoint, noise_generator);
 l = Lambda = Turb->Lambda;
 o = Omega  = Turb->Omega;
 for (i = 2; i <= Octaves; i++)
  VScale(temp,EPoint,l);
   value += o * (2.0 * Noise(temp, noise_generator) - 0.5);
 else
  value += o * Noise(temp, noise_generator);
  if (i < Octaves)
   l *= Lambda;
   o *= Omega;
 return (value);
and it resides in /source/backend/math/vector.h
inline void VScale(SNGL_VECT a, const SNGL_VECT b, SNGL k)
 a[X] = b[X] * k;
 a[Y] = b[Y] * k;
 a[Z] = b[Z] * k;
Nope.  I honestly haven't had the energy and the ability to focus on meticulous
things like this for a while - just so much IRL.
Work, the Plague, car repairs, etc........................................
But I keep hanging on by my fingernails   ;)
I'll take a look at M.C. and see what it's like - thanks for the tip!
Date: 20 Apr 2019 11:59:39
Message: <5cbb41eb$1@news.povray.org>
Am 20.04.2019 um 14:19 schrieb Bald Eagle:
(Technically, `Noise` _may or may not_ be a call to `PortableNoise` -
that depends on how the binary is compiled, and possibly also the
features of the CPU it is actually run on. But since it is always a call
to either that function or an optimized variant that gives the same
results (the infamous "optimized noise generator"), this distinction is
only relevant when making changes to the function.)
My, that's some old code there!
`VScale(a,b,c)` was a function that implemented uniform linear scaling
of a vector back in the days when we used the C-style 3-element array
type `VECTOR` to store vectors. That type has been superseded by the
class type `Vector3d`, which provides operator overloading for the same
purpose, and instead of `VScale(a,b,c)` we would now write `a=b*c`.
(Also, the `Turbulence` function now resides in `noise.cpp`.)
