POV-Ray : Newsgroups : povray.programming : Panorama 360 degree with POV-ray Server Time
15 Apr 2026 19:22:48 EDT (-0400)
  Panorama 360 degree with POV-ray (Message 1 to 2 of 2)
Subject: Panorama 360 degree with POV-ray
Date: 3 Jan 2009 09:45:00
Message: <web.495f79a1731833fc6d01541a0@news.povray.org>
I am looking for a way to create, from a file DEM (W020N90.DEM for example), a
360-degree panorama seen from a point of Lt Latitude (degree), Lg longitude
(degree) and H height (meter).
I saw that perhaps POV-ray has this possibility, but I do not know how I act as
an absolute beginner in this program.
The end result should be an image similar to that found at the link
www.lalpinistavirtuale.it/Panorami/img/example.jpg.
Thanks for your attention.
AlpVir
Subject: Re: Panorama 360 degree with POV-ray
Date: 3 Jan 2009 10:07:04
Message: <495f7f18@news.povray.org>
Hi, this is the wrong newsgroup for this topic, it is for
discussing the programming of POV-Ray itself. Appropriate
groups would be povray.newusers or povray.general.
Anyway, you need
1. A tool to convert DEM file to a supported image format,
    TGA or 16-bit PNG would be ok.
2. The height_field object to import an elevation
    map as a geometric object. This is common, you
    should find tons of sample scenes.
3. Change the camera from the normal perspective
    type to panoramic (see 3.3.1.2.6 in the docs).
