POV-Ray : Newsgroups : povray.programming : An idea on radiosity Server Time
16 Apr 2026 15:34:39 EDT (-0400)
  An idea on radiosity (Message 1 to 3 of 3)
Subject: An idea on radiosity
Date: 29 Nov 2001 21:51:55
Message: <cjsd0usuu70sg6djd5scc73ou80ddgtscn@4ax.com>
It occurred to me today that it would be great if there were a tool
for merging several radiosity data files into one. One could then
gather radiosity information in several places in a scene, merge the
data and obtain radiosity data useable for anyplace in the scene. This
would be very useful for animations or for stills which show different
angles of the same scene. Also, I believe it would make tweaking much
easier because, instead of tuning up radiosity settings for just one
corner, one could place a spherical camera there, render with low rad
settings, then merge the data file.
So, what is the structure of the rad data file? Any specifics? Would
such a tool be hard to make?
Peter Popov ICQ : 15002700
Subject: Re: An idea on radiosity
Date: 30 Nov 2001 08:56:07
Message: <slrna0f3vo.vj7.ron.parker@fwi.com>
It's just ASCII records, separated by tabs and with a newline at the end
of each record.  Looking at the source, it seems like you should be able
to just merge them using your favorite implementation of cat (use COPY on
DOS-ish systems.)
So in DOS:
COPY RAD1.RCA + RAD2.RCA  RADMERGE.RCA
in Unix:
cat rad1.rca rad2.rca >radmerge.rca
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
Date: 30 Nov 2001 17:17:08
Message: <o41g0u0rloossvouv00i8pu3vljtdliv5b@4ax.com>
On 30 Nov 2001 08:56:07 -0500, Ron Parker <ron### [at] povrayorg>
>of each record.
You know... I never even cared to look into a rad file! D'oh!
>DOS-ish systems.)
Nah, that would be cat for me :)
You know, it just occurred to me that it could be done using load_file
and save_file in the same scene.
