POV-Ray : Newsgroups : povray.programming : Realtime POV-Ray Server Time
8 Nov 2026 10:31:53 EST (-0500)
  Realtime POV-Ray (Message 1 to 16 of 16)
Subject: Realtime POV-Ray
Date: 22 May 1998 04:27:49
Message: <6k3cuo$mai$1@oz.aussie.org>
Now that is a subject line to make everybody curious, isn' it? ;-)
Well, here is an idea of mine, that I thought could come handy for our
MovieProject (http://www.algonet.se/~jhubert/MovieProject ), or for any
animation.
I was thinking about the POB (Pov Binary Format) by Thomas Baier (his
homepage: http://ourworld.compuserve.com/homepages/thbaier/ ).
To those who don't know of it: He wrote a custom version of POV-Ray that
reads a POV-file as usual and while parsing it, it writes all objects it
finds into a chunk-based binary format, that can be read by other
applications *much* easier than the very complex POV-Ray text format.
Anyway, what I was thinking about was this:
Changing this version of POV-Ray, so that instead of writing an object
description into a binary file, it creates an OpenGL version of this object
and when the whole scene is parsed, the OpenGL objects would be shown,
instead of the rendered picture. Since OpenGL is quite fast, actually the
parsing speed would be the limiting factor. OpenGL is quite cross-platform
too, so such a version could even be made usable on many platforms.
I didn't think about a version that can really do *everything* and all
objects, but more of a version that can do the most important POV-Ray
primitives in OpenGL. No special textures, lighting etc., everything in one
color (or two or three...), so that one would get an OpenGL preview of the
scene.
Since that would be very fast (limited only by the parsing speed), you could
use it very much for animation previews. Animation in realtime!
You have an animated character and want to check it's movements before the
real render, or you have a scene with objects flying around and want to see
how they are synchornized, that sort of stuff.
I have a bit of OpenGL experience from my TreeDesigner project
(http://www.algonet.se/~jhubert/TreeDesigner ), and was thinking about
programming such a "Realtime Previewer", but I don't know how soon I might
find the time.
So I thought I put it up here, maybe somebody else is interested in doing it
faster than I will be able to?
Johannes -:- MovieProject Coordinator
Subject: Re: Realtime POV-Ray
Date: 23 May 1998 05:32:14
Message: <6k650e$rno$1@oz.aussie.org>
Johannes Hubert wrote in message <6k3cuo$mai$1@oz.aussie.org>...
 <cut etc>
I thing that's a great idea.. I thought of a simular thing for the pov2mdl
filter to have a povB2mdl so that way you could get a wireframe preview of
an object written on pov code.
But don't look at me for the codeing thou.... I haven't the experience, yet.
I'm working on it slowly.
Fran,
Date: 23 May 1998 11:15:00
Message: <6k6p6p$sl3$1@oz.aussie.org>
Fran & Melissa wrote in message <6k650e$rno$1@oz.aussie.org>...
yet.
Actually, I have followed up on my own idea, made some changes, and already
begun with a test version. It looks promising!
I will not create a custom version of POV-Ray. The parsing time for each new
frame would be to long anyway, to make it really "real-time".
Instead I found this solution:
I use Thomas' already existing custom version to create POB-files for the
whole animation: One binary POB file for each frame.
I then read those POB files and show them via OpenGL as a real-time
animation, plus the ability to control the animation (slower, faster, back,
etc.) so that one can really study it.
The turnaround time should be quite good:
Make some changes to your POV-Script, then you have a waiting time equal to
the sum of the parsing times for all frames, but after that, you can view
your animation in OpenGL. That is a lot faster than waiting for the render,
and then maken a FLI or whatever out of the frames.
But don't expect too much: The fancy POV-Ray stuff will not be supported: No
Textures, Halos, complicated Objects like Quadrics, Surface of Revolution
etc. I will try to implement some sort of placeholder for unsupported
objects though. No CSGs either, that is: Union/Merge/Intersections simply
show all objects in them, Difference shows only the first or optionally all
too.
It is really thought for quick preview of animations, not for a real view of
the model (you can always render for that, can you ;-)
And: Since NT is my home, and MFC is my hobby, it won't be portable: Windows
only, sorry!
Johannes.
Date: 1 Jul 1998 04:40:24
Message: <3599E7DE.93FA14EB@numerik.uni-kiel.de>
How about doing stuff like this in Java using Java3D?
I should make life quite easy, is getting more and more portable and has
some hardware-accelaration as well (uses OpenGL on Solaris, AFAIK)
Axel
Date: 12 Jul 1998 09:37:06
Message: <35A8AD91.68A98390@algonet.se>
If time permits (which is very unlikely at the moment), maybe... Or
maybe somebody else wants to do it?
Johannes.
Date: 4 Aug 1998 12:21:22
Message: <35c726f2.0@news.povray.org>
How are you doing? I'm very interested in the project. Is it possible to
render a single scene and move the camera. I don't have much OpenGL
experience, but as far as I remember that should be quite easy, or am I
wrong?
Tobias
Date: 4 Aug 1998 13:57:03
Message: <35c73d5f.0@news.povray.org>
Tobias Ritzau wrote in message <35c726f2.0@news.povray.org>...
>wrong?
Yep, it isn't too hard.
I got as far as to a first version which supports spheres, cones, cylinders,
boxes and torii. My ISP is down at the moment, but once I have access again,
I will upload a page where you can download the stuff if you are interested.
Sourcecode too, if you are interested in further developing it.
Bye,
Johannes.
Date: 27 Aug 1998 06:56:32
Message: <35E52CEF.19D1@ida.utb.hb.se>
Hi Johannes!
He he...this is exactly what I have been thinking of lately....a kind of
parser that "quitely" parses the scene and when getting a valid input(
valid code), previews the scene in OpenGL. This would be best to have
built into the official Windows POV-Ray version, and accessed through a
single toggle-button: "Preview mode" and "Trace mode".
This way you could work in "realtime", and you wouldnīt have to press
alt+G to parse the scene. The parser only previews when the code is
vaild. Like this:
[I start coding]
sphere
   <0,0,0>
   0.5
   [the previewer doesnīt show anything yet, as the sphere isnīt
finished.]
   texture{pigment rgb<1,0,0>}
   [the previewer still doesnīt show anything yet, as the sphere isnī
t
finished.]
[now the sphere is finished, and the previewer shows a red little
sphere, beautifully shaded in OpenGL! :)]
Now, for example, imagine that I move to the radius value (0.5) with the
arrow keys. When backspacing over the 5 in the 0.5 value, the sphere has
no size, and is therefore not vaild code. The previewer doesnīt show
anything anymore. But, since I only deleted the "5" to replace it with a
"3" and change the radius to 0.3( since I could see in the preview that
the sphere was too big! :) ) - the previewer shows a preview again as
soon as Iīve typed in "3" after the "."
What do you think folks? Wouldnīt this be cool?
Working with the best raytracer available would be a lot faster! :)
- Mikael.
Date: 27 Aug 1998 10:34:05
Message: <35e5604d.0@news.povray.org>
On Thu, 27 Aug 1998 11:54:55 +0200, SA9### [at] idautbhbse
>vaild. Like this:
<description omitted>
So if my sphere had a radius of .3625, would it reparse and rerender as I
deleted the 5, then the 2, then the 6, and finally reparse and decide not to
render when I deleted the 3?  Doesn't that seem like a lot of parsing?
Remember, some people have posted their experiences with scene files that
take _hours_ to parse.
I think if there's gonna be an opengl preview, it has to be done when the
user asks for it, not automatically.
Date: 27 Aug 1998 13:07:34
Message: <35E583DA.5579@ida.utb.hb.se>
 I
ot to
at
A lot of parsing, yes, but this mode would probably be of most help when
creating (smaller) scenes from scratch, not when importing mesh files
thatīs 5 Mb in size. The whole idea is to instantly get an idea of what
the scene looks like when coding, much like you can in programs like 3DS
and such.
he
Mmmm...thatīs exactly why this feature should be controlled by a
toggle-button that switches between "trace mode" (traditional) and
"preview mode".....
The "Mode tree" should maybe look something like this:
	  		      Parser
           "Standard mode"  -       - "Preview mode"
			     Automatic -         - Manual
Mikael Carneholm
Dep. of Computer Science
University of Boras, Sweden
http://www.studenter.hb.se/~arch
sa9### [at] idautbhbse
Date: 29 Aug 1998 12:02:02
Message: <35e81769.5627586@news.povray.org>
On 27 Aug 1998 09:34:05 -0500, par### [at] my-dejanewscom (Ron Parker)
>>This way you could work in "realtime", and you wouldn´t have to press
>>vaild. Like this:
Of course there's nothing that says parsing/preview can't run in a
seperate thread, and be cancellable. So for each digit you delete in
the above example a parse is started - but if there's a parse already
in progress the existing parse is restarted (or cancelled first) so
you only ever have the "current scene" being parsed.
Modern PC's ought to be able to handle this without significantly
affecting typing speed - unless Windoze gets any slower and/or
bloated.
Cheers,
Cliff Bowman
Why not pay my 3D Dr Who site a visit at
http://www.geocities.com/Area51/Dimension/7855/
PS change ".duffnet" to ".net" if replying via e-mail
Date: 2 Sep 1998 11:47:11
Message: <01bdd5be$eec91520$8c00a8c0@shindo>
SA9### [at] idautbhbse wrote in article <35E### [at] idautbhbse>...
> Hi Johannes!
<sniped : description of POVRay OpenGL preview mode that would
automatically update as you typed in script code>
> What do you think folks? Wouldn´t this be cool?
	Yep, this would be very cool, and guess what, it's already on it's way !
You may have read some of my previous posts about the modeler I'm working
on, well this is one of the features I plan to include ! Unfortunately It's
going to be one hell of a long time before it's anywhere need finished (I
had a major rethink about the structure and implementation of it recently,
so things have been put back a very long way)
	Anyway, watch this space...
Scott Hill
Sco### [at] DDLinkscouk
Software Engineer (and all round nice guy)
Company homepage : http://www.ddlinks.demon.co.uk
"The best trick the devil ever pulled was convincing people he didn't
exist..."
								- Verbal Kint.
"the Internet is here so we can waste time talking about nothing in
 particular when we should be working" - Marcus Hill.
Date: 4 Sep 1998 00:58:32
Message: <35EF6577.B5741A05@fan.net.au>
Im learning GLIDE and C and have currently got a small 3d rendering library
happenen.
My problem is lack of data, since I need to witr my own file import filter I was
considering trying to implement a simple POV importer.
If anyone would be willing to share some code, (not that I have anything anyone
would probably want in return), it could save me alot of hassle tryiong to write a
pov file parser.
(I have never wirtten anything like a this before). If anyone can help me out with
either
thoery or code.. (How do I 'Parse' a file?) it would be greatly appreciated.
When I master GLIDE, and know C well enough to venture into Windoze Apps (I
currently only program console apps due to simplicity) I hope to migrate to OpenGL.
Any advise on importing 3D data or witing a simple modleing app would be great too..
(Thanks for your time since I realise this is not an entirely POV related post.)
Date: 4 Sep 1998 01:47:34
Message: <35ef7041.2302805@news.povray.org>
On Thu, 03 Sep 1998 21:11:32 -0700, "K. Tyler" <tyl### [at] pacbellnet>
wrote:
>You do know don't you that the entire source for povray
>is available at their web site:  http://www.povray.org
You do know that POVLEGAL says you can't rip off the parser
from the povray source for your own purposes, right?
Date: 4 Sep 1998 12:43:05
Message: <01bdd7fe$425e8e40$8c00a8c0@shindo>
Jason Krah <jkr### [at] fannetau> wrote in article
<35EF6577.B5741A05@fan.net.au>...
library
> happenen.
filter I was
anyone
to write a
> pov file parser.
	If you find anything, will you let me know, too ? This is the one part of
my modeller I'm not looking forward to writing.
	In the mean-time, as Ken suggested, take a look at the POV source code
(this is what I'll be doing), just remember to also read POVLEGAL and don't
directly rip off the parser code.
Scott Hill
exist..."
								- Verbal Kint.
Date: 5 Sep 1998 02:11:30
Message: <35F0C7F5.CC8B0883@bellsouth.net>
Besides the PovRay source, there are two other things I have found that
might help
both of you.
The  POB-SDK by Thomas Baier
http://ourworld.compuserve.com/homepages/thbaier/pob_sdk.htm
ParPov by Christian Vogelgsang
This is a C++ library that can parse pov files and give you C++ objects.
Its first application is his program pov2rib utility for converting Pov
to renderman rib files.
http://www9.informatik.uni-erlangen.de/~cnvogelg/pov2rib/index.html
> pov file parser.
> either
