POV-Ray : Newsgroups : povray.programming : Another call to arms Server Time
12 Mar 2026 19:33:39 EDT (-0400)
  Another call to arms (Message 1 to 8 of 8)
Subject: Another call to arms
Date: 4 Jun 2021 16:13:28
Message: <60ba8968@news.povray.org>
Hi folks,
there's other stuff that needs to be done, which should be easy to
delegate, at least partially:
During my absence, I gather other people have stepped up and done some
error diagnosis and coming up with fixes. At least Bill's name has come
up a couple of times.
Now, if we want those fixes to make their way into official POV-Ray,
some steps need to happen - all essentially boiling down to getting the
information to a place and into a format where it can be more easily
managed:
(1) Information on errors not yet diagnosed, currently spread across
countless threads on multiple newsgroups, needs to be collected in one
central place, where the status of each issue can be easily tracked and
updated, and the error itself easily referenced.
Before I went hiding, the ideal place for that was the Issues section on
GitHub (https://github.com/POV-Ray/povray/issues).
If you want to help me help you help us all and get those bugs fixed, I
guess that's still the best place. I don't currently have the energy to
dig through old threads and sift the information out there, but I guess
some of you folks could help out with that.
Ideally, the prcess of collecting that information would involve
"distilling it down" to a simple test case, with a minimalistic scene
and concise description. Plus a link to the newsgroup thread for reference.
(2) In a similar vein, information on errors already diagnosed, but
still without a suggested solution, also need to be collected and
"distilled".
Again I would suggest the issues tracker on GitHub. I'd recommend to put
the description of symptoms into the issue description proper, and add
the diagnostic findings as a comment.
(3) For errors that have been diagnosed, and for which a solution has
already been found, it might need to be wise to also add them to the
issue tracker. More importantly, however, the solution has to be placed
in a place and into a form that makes it easy to "import" it into the
POV-Ray codebase.
Before I went hiding, the ideal format for that would have been a Git
Pull Request.
I'm aware that might not be everyone's favorite format, but maybe you
folks can team up, with someone producing diffs and someone else
bringing them into Git? (I myself am terrible at working with diffs, so
don't expect me to touch them except with a 10 foot stick.)
A single pull request per issue would be preferable, and changes should
be based on a recent version from the master branch.
Two important things I'd like to note:
(A) Make sure to coordinate with others, in case there's more than one
person to pick up this gauntlet.
(B) Be prepared for feedback that may sound rejecting - it is generally
not meant that way. Whoever will review the error report or proposed
solution _will_ be thankful for the time and effort you're putting into
it. And they _will_ be even more thankful for any _additional_ time and
effort you might be willing to give in case they find a snag with the
proposed solution. Software developers just generally tend to not be
very good at conveying such sentiments.
Am I scaring you away already?
I hope I'm not.
I'm grateful for anyone willing to put time and effort into this, so
that POV-Ray v3.8 gets the bugfixes it deserves. Every little bit helps.
Subject: Re: Another call to arms
Date: 4 Jun 2021 19:05:00
Message: <web.60bab15b1f94f4ce79819d986cde94f1@news.povray.org>
hi,
> Hi folks,
> POV-Ray codebase.
I can provide three patches if thought useful.  the following clipped from the
build script:
# note p.bugreports: WFP 13.8.2020 "alpha.10064268 undef behaviour".
patch --verbose -p0 < ${CWD}/patch20200813
# note p.general: WFP 19.9.2020 "povray vs uberpov am3".
patch --verbose -p0 < ${CWD}/patch20200919
# note p.beta-test: WFP 21.4.2021 cf ingo, dict copy.
patch --verbose -p0 < ${CWD}/patch20210421
(I think there's at least one more "already fixed" for which I didn't make one)
regards, jr.
Date: 5 Jun 2021 03:54:34
Message: <60bb2dba@news.povray.org>
Am 05.06.2021 um 01:03 schrieb jr:
> build script:
Probably.
Beware that when collecting patches, it is my understanding that they
only work if the file in question hasn't been changed otherwise, so it
would be important to note what version of POV-Ray they were designed for.
In this particular case, it seems rather evident though that it would be
alpha.10064268.
Date: 5 Jun 2021 04:03:29
Message: <60bb2fd1$1@news.povray.org>
Am 04.06.2021 um 22:13 schrieb clipka:
> managed:
By the way, one thing that makes this all the more helpful, is that
newsgroup messages posted during my hiatus until somewhen in 2020 are
currently cumbersome to access for me, as the news server refuses to
tell me what's written in them.
(No, re-scanning the headers doesn't solve the problem, it only makes it
worse. Which is why in a few select newsgroups I have lost any trace of
messages between late 2018 and early 2020 entirely, even the header
information.)
Date: 5 Jun 2021 05:10:00
Message: <web.60bb3e681f94f4ce79819d986cde94f1@news.povray.org>
hi,
> > build script:
> Probably.
yes.  I do use version specific sub-directories, so stuff is always kept
together.
note that I have not included another, older patch for alpha.10064268.  from
19.2.2019, correcting missing 'std::' prefixes (but you released a newer version
for that).
regards, jr.
Download 'cl-patches.tar.xz.dat' (1 KB)
Date: 5 Jun 2021 06:10:00
Message: <web.60bb4cb41f94f4ce79819d986cde94f1@news.povray.org>
> for that).
<http://news.povray.org/povray.beta-test/thread/%3C5c6b8351%241%40news.povray.org%3E/>
(forgot..)
regards, jr.
Date: 6 Jun 2021 18:00:00
Message: <web.60bd44a51f94f4ce1f9dae3025979125@news.povray.org>
I can make a very small scene to demonstrate the issue with the radial pattern,
although I think the extant thread is kinda self-explanatory, and WFP agrees
with the proposed mathematical solution.
All the other things have to deal with source code I haven't looked through or
would likely be able to competently suggest code solutions for.
So here is a list of what I have found / can remember:
creating an array of arrays, and then trying to access an uninitialized element
of that data structure.
https://news.povray.org/5b83c8ab%241%40news.povray.org
A declare without the leading # works
http://news.povray.org/povray.general/thread/%3Cweb.5d8f1cd3fe1f4a21e462584c0%40news.povray.org%3E/?mtop=428173&moff=5
radial pattern
http://news.povray.org/web.5dabcdf0e43f3c684eec112d0%40news.povray.org
suggested fix (coded in SDL function syntax)
#declare Angle = function (XX,ZZ) {atan2 (XX, ZZ)-(pi/2)}
#declare Adjusted = function (XX,ZZ) {select (Angle(XX,ZZ),  Angle(XX,ZZ)+tau,
Angle(XX, ZZ))}
#declare FreqPhase = function (XX, ZZ, F, P) {mod ((P*tau+Adjusted (XX, ZZ))*F,
tau)/tau}
#declare Radial = function (XX, ZZ, F, P) {select (XX*ZZ,  FreqPhase
(XX,ZZ,F,P), 0, FreqPhase (XX,ZZ,F,P))}
project some light through an image
map
http://news.povray.org/povray.advanced-users/thread/%3Cweb.5d101e19377950ae4eec112d0%40news.povray.org%3E/
blend_gamma typo
http://news.povray.org/povray.beta-test/thread/%3C6022887b%241%40news.povray.org%3E/
Icosahedron include
http://news.povray.org/povray.binaries.images/thread/%3C87muh7xgh9.fsf%40munyer.com%3E/?ttop=429414&toff=50
dictionary crash
http://news.povray.org/povray.general/thread/%3CXnsAD0BC42BCF8Aseed7%40news.povray.org%3E/?mtop=433766
normals
http://news.povray.org/povray.binaries.images/thread/%3C5f830726%40news.povray.org%3E/
spiral patterns
https://news.povray.org/5f6c87f2%241%40news.povray.org
no_image
https://news.povray.org/povray.general/thread/%3Cweb.5e7944321f97b21e393d37fe0%40news.povray.org%3E/?ttop=430126&moff=8
cutaway_textures
https://news.povray.org/web.5e3385d55a7390894eec112d0%40news.povray.org
There may be a few others.
Date: 9 Jun 2021 07:05:00
Message: <web.60c09f691f94f4ce1f9dae3025979125@news.povray.org>
Don't know enough about the details, but am placing this here due to the
potential issues with the current implementation of parse_string
http://news.povray.org/608967ad%241%40news.povray.org
RL slowing me down, so input and output maybe be sparse.
