POV-Ray : Newsgroups : povray.programming : toFloat.h missing Server Time
19 Nov 2026 13:16:10 EST (-0500)
  toFloat.h missing (Message 1 to 19 of 19)
Subject: toFloat.h missing
Date: 16 Sep 2015 13:51:23
Message: <55f9ac1b$1@news.povray.org>
So I'm trying to compile the source with VS2015, and the very first
error I find is that the file "toFloat.h" is missing.
I cannot find this file anywhere in the source; is it meant to be
auto-generated somehow?
Subject: Re: toFloat.h missing
Date: 16 Sep 2015 16:45:00
Message: <web.55f9d3ee13fa3f6a4ed434990@news.povray.org>
That file isn't even /referenced/ anywhere in the source.  Could there be a
problem with your VS setup?
Date: 16 Sep 2015 18:10:49
Message: <55f9e8e9@news.povray.org>
povray\libraries\ilmbase\Half\half.cpp:
   #if defined (OPENEXR_DLL)
   __declspec(dllexport) half::uif _toFloat[1 << 16] =
       #include "toFloat.h"
   __declspec(dllexport) unsigned short _eLut[1 << 9] =
       #include "eLut.h"
   #else
   const half::uif half::_toFloat[1 << 16] =
   const unsigned short half::_eLut[1 << 9] =
       #include "eLut.h"
   #endif
So it looks like I could get around this by using the OpenEXR library,
correct?
Date: 16 Sep 2015 18:11:53
Message: <55f9e929@news.povray.org>
> correct?
Oh geez, brain fart. Either path references "toFloat.h"
Date: 18 Sep 2015 12:26:53
Message: <55fc3b4d@news.povray.org>
Am 17.09.2015 um 00:11 schrieb Benjamin Chambers:
>> correct?
"toFloat.h" file is part of the "ilmbase" library (just like
"half.cpp"), which in turn is indeed a part of the OpenEXR library.
("ilm" is an acronym for "Industrial Light & Magic", the company that
originally developed the OpenEXR file format and still maintains the
library.)
What's special about "toFloat.h" (and also "eLut.h") is that these two
files are not part of the library's source file package, but are created
as part of the build process (presumably because their contents are
platform-specific).
Make sure that the project conversion from VS2010 to VS2015 has kept the
build dependencies and custom build steps intact; rebuilding the "Half"
project should automatically trigger a rebuild of the "eLut" and
"toFloat" projects first; those projects should in turn cause those
files to be created in the "libraries/ilmbase/Half" directory (unless
the respective file already exists and is up to date), which should be
accompanied by the build log output "Generating <filename>...".
Date: 18 Sep 2015 14:07:04
Message: <55fc52c8$1@news.povray.org>
Thanks! This seems to be what the problem is. Here is the output from
building toFloat:
1>------ Rebuild All started: Project: toFloat, Configuration: Release
x64 ------
1>  toFloat.cpp
1>  openexr_toFloat.vcxproj ->
C:\Users\benja\Source\Repos\povray\windows\vs10\build\toFloat\x64\Release\toFloat.exe
========== Rebuild All: 1 succeeded, 0 failed, 0 skipped ==========
And for eLut:
1>------ Rebuild All started: Project: eLut, Configuration: Release x64
1>  eLut.cpp
1>  openexr_eLut.vcxproj ->
C:\Users\benja\Source\Repos\povray\windows\vs10\build\eLut\x64\Release\eLut.exe
I'll take a look at the VS2010 project files, and see if I can set up
the VS2015 projects accordingly.
Date: 21 Sep 2015 03:03:31
Message: <55ffabc3$1@news.povray.org>
I posted some instructions a (long) while back on how to get it to work
on VS Express, I had the same issues initially so some of those steps I
posted might help you out.
Date: 22 Sep 2015 09:49:37
Message: <56015c71$1@news.povray.org>
I read through that before I started, and many of the changes you detail
no longer apply. However, I'm referring to it often as I work.
I forked a new branch today focused on getting it to compile in VS2015.
That way, I can keep all of my work separate.
Date: 24 Sep 2015 12:28:58
Message: <560424ca@news.povray.org>
> building toFloat:
> x64 ------
> 1>  toFloat.cpp
Now this is interesting. I've been over the XML for the project files,
and they APPEAR to be set up correctly to generate the header files.
However, the custom build step never runs.
I'll keep poking around in it and see what I can do.
Date: 24 Sep 2015 15:04:36
Message: <56044944@news.povray.org>
Oh, btw, I totally forgot: There's a third file that is created by the
OpenEXR build process on the fly,
"libraries/openexr/IlmImf/b44ExpLogTable.h", so make sure to take care
of that one as well.
Date: 24 Sep 2015 15:22:06
Message: <56044d5e@news.povray.org>
Am 24.09.2015 um 18:29 schrieb Benjamin Chambers:
Just a hunch:
- Could it be due to the fact that (at least in the vs2010 projects) the
information for the respective custom build step is split across two
separate <CustomBuildStep> tags?
- Could it be that the custom build step does run after all, but doesn't
work properly because it contains an output redirection and the VS2015
build system somehow fails to handle this properly?
Date: 24 Sep 2015 15:34:49
Message: <56045059$1@news.povray.org>
On 9/24/2015 1:22 PM, clipka wrote:
> Just a hunch:
Manually combining the tags in the project file had no effect.
Removing the redirect still doesn't run the custom build step.
I've posted in the MSDN forums, asking if anyone knows why it wouldn't
run, but haven't received an answer yet. In the meantime, I'll manually
generate the header files, but this is something that needs to be sorted
out eventually...
Date: 24 Sep 2015 15:44:51
Message: <560452b3$1@news.povray.org>
As far as this is concerned, while testing with VS2010 I just noticed
that the description ("Creating toFloat.h..." or whatever) isn't
actually printed to the build output even if the custom build step
obviously runs (as demonstrated by toFloat.h reappearing after having
been deleted).
A hint that the custom build step was run seems to be a log file
generated in "build\toFloat\x64\Release" (in case of building for x64),
named "toFloat.write.1.tlog".
If you can't get the Custom Build Step mechanism to do the job, you
might want to try the Post-Build Event mechanism instead, though IIRC
there was /something/ undesirable about it.
Date: 24 Sep 2015 17:55:44
Message: <56047160$1@news.povray.org>
> been deleted).
I've tried both, actually, and neither one indicates in the log file
that the step was run, nor do they generate the header file.
Date: 24 Sep 2015 18:18:00
Message: <56047698$1@news.povray.org>
Am 24.09.2015 um 23:55 schrieb Benjamin Chambers:
>> been deleted).
That's certainly strange. It does build the .exe that's supposed to
generate them, right?
Date: 24 Sep 2015 19:11:52
Message: <56048338@news.povray.org>
>>> been deleted).
Yes, and I ran it from the command line to generate the necessary headers.
There may be something odd with my specific installation causing this issue.
Date: 27 Sep 2015 19:25:56
Message: <56087b04$1@news.povray.org>
I finally got the custom build step to generate the header as needed.
I'm not sure which change made it, but what I did in the end to was to
create a new project file, set it to run after link (instead of
manifest), and set an Additional Dependency of $(TargetPath).
We'll see as I work with the other header-generating projects which
change (or combination of them) was necessary.
Date: 29 Sep 2016 04:30:01
Message: <web.57ecd0a813fa3f6a285e69020@news.povray.org>
please Benjamin can you share your MSVC15 Project ?
I got same error plus some related to boost so if you have a working solution
for MSVC2015 on windows x64 I'll like to try it
regards
Stéphane
Date: 29 Sep 2016 13:03:17
Message: <57ed4955$1@news.povray.org>
Am 29.09.2016 um 10:28 schrieb Phane:
> Hi,
I would recommend trying a more recent version; The incompatibilities
with VS2015 have been ironed out in the master branch, and the VS2010
projects should build fine after auto-conversion.
