POV-Ray : Newsgroups : povray.programming : Povray output depthmap Server Time
19 Nov 2026 13:16:10 EST (-0500)
  Povray output depthmap (Message 1 to 1 of 1)
Subject: Povray output depthmap
Date: 4 Dec 2013 09:53:20
Message: <529f41e0$1@news.povray.org>
I'm trying to use POVRay to generate test data for computer vision
algorithms and among other things I need the depth information of the
scene. With MegaPOV there was a function which lets you do it, but
MegaPOV won't work with POVRay 3.7 and I would prefer to use the 3.7
generation because of the multicore support.
I already hacked up the code so I can ouput depthmap and camera
parameters, but I'm missing the "integration" (using commandline
switches, determining automatic filenames for animations etc.) I find it
quite hard to understand the "big picture" in terms of architecture, who
sends which messages, who receives them, where is certain data
located/computed (like filenames) so it would be nice if somebody could
help me out.
I guess having depthmaps is interesting for other people too, so a
commandline parameter / config file option that outputs depth along with
the image would be a nice addition to POVRay.
Right now I have the following:
An additional image_depth in ViewData (frontend/renderfrontend.h)
The imge_depth is initialized in RenderFrontend::CreateView() inside the
if(obj.TryGetBool(kPOVAttrib_OutputToFile, true)) condition.
I changed the TracePixel::operator() so that it returns depth
information and in TraceTask::SimpleSamplingM0() i create a
vector<Colour> pixelsDepth where the depth is stored (in the red channel
of the colour)
I call GetViewData()->CompletedRectangle(rect, serial, pixelsDepth, 1,
finalTrace) which creates additional messages for the frontend.
In the ImageMessageHandler::DrawPixelBlockSet() the depth information is
written to vd.image_depth
Then I make an additional call to
vhi->second.render.HandleMessage(sceneData, vhi->second.data, ident, msg)
in RenderFrontend::HandleRenderMessage() inside the
if(ident == kPOVMsgIdent_Done) block, i.e. when the image is finished.
In RenderMessageHandler::HandleMessage() I have an additional
case kPOVMsgIdent_Done and there I write the image_depth data to disk, I
use a static filename since I couldn't figure out how to access the
outputfilename.
Also I have code in Scene::SendDoneMessage() to write camera parameters
to disk.
It would be nice if somebody could help me integrating this stuff into
the POVRay system architecture.
cheers
