POV-Ray : Newsgroups : povray.programming : Compiling 3.7 RC7 with Visual Studio Express 2012 Server Time
19 Nov 2026 13:16:10 EST (-0500)
  Compiling 3.7 RC7 with Visual Studio Express 2012 (Message 1 to 13 of 13)
Subject: Compiling 3.7 RC7 with Visual Studio Express 2012
Date: 5 Jun 2013 08:03:09
Message: <51af28fd$1@news.povray.org>
There are a few steps I needed to take to get this to work correctly.
This isn't necessarily the best way or the only way, it's simply what I
did to get it working.
1. Open the solution in the windows\vs10 folder with VS Express 2012
2. Choose “Update” to update all the projects
3. Open the configuration manager, uncheck the Build option for cmedit,
codemax and console (you'll need to do this for the combination of
debug/release and 32bit/64bit that you want to build)
4. Do a find&replace on all files to replace “boost::shared_ptr” with
“shared_ptr”
5. Do a find&replace on all files to replace “shared_ptr” with
“boost::shared_ptr”
6. Open syspovconfig.h from the VFE\vfewin project and fix line 122
(gets messed up with steps 4 and 5), it should read #include
<boost/shared_ptr.hpp>
7. Open msvc.h from the VFE\vfewin project and delete the #error on line
164 and copy the #defines from the previous #elif in its place (and you
can change the 10’s to 11’s if you want)
8. For the toFloat, eLut and b44ExpLogTable projects under OpenEXR
Libraries; open the project properties and under Custom Build Step set
Execute After to BscMake
9. Open unordered_map.hpp from the Generic POV-Ray\povbackend project
(it’s under External Dependencies) and add the following #define
BOOST_NO_0X_HDR_INITIALIZER_LIST at line 11
It should build now.
Subject: Re: Compiling 3.7 RC7 with Visual Studio Express 2012
Date: 17 Jun 2013 21:05:42
Message: <51bfb266$1@news.povray.org>
> “shared_ptr”
> “boost::shared_ptr”
Doesn't step 5 just reverse step 4? What do you gain by doing this?
Todd
Date: 18 Jun 2013 03:13:22
Message: <51c00892$1@news.povray.org>
>> “shared_ptr”
>> “boost::shared_ptr”
It makes sure all mention of "shared_ptr" is prefixed by "boost::". It
was just the first way of doing it that came into my head when I opened
the Find&Replace window in VS. There's probably a way to do it in one
step with a regex or something (which would remove the need for step 6).
Date: 16 Jul 2013 23:08:26
Message: <51e60aaa$1@news.povray.org>
Am 18.06.2013 03:05, schrieb Todd Carnes:
>> “shared_ptr”
>> “boost::shared_ptr”
It effectively replaces "shared_ptr" with "boost::shared_ptr", but
without any already existing "boost::shared_ptr" getting converted to
"boost::boost::shared_ptr"
Date: 25 Jun 2015 14:25:00
Message: <web.558c470a527de37e6d0f10450@news.povray.org>
> [... step 1-9 ...]
Just tried it with VS2013. Still doesn't build, you need a few more steps for
that. Here's the stuff you need in addition to the earlier steps:
10. Fix msvc.h:
  #elif _MSC_VER >= 1800 && _MSC_VER < 1900
 #define COMPILER_VER                      ".msvc13"
 #define METADATA_COMPILER_STRING          "msvc 13"
  #else
11. Search for 'using std::min'. Above the 'namespace', add '#include
<algorithm>'.
Build, done.
Date: 25 Jun 2015 17:43:39
Message: <558c760b$1@news.povray.org>
Am 25.06.2015 um 20:23 schrieb atlaste:
>> [... step 1-9 ...]
> 10. Fix msvc.h:
>    #else
> <algorithm>'.
> Build, done.
Thanks for sharing.
I presume you're not actually trying to build RC7 anymore, but some
newer version, right?
Date: 10 Jul 2015 15:40:00
Message: <web.55a01ead527de37e6d0f10450@news.povray.org>
Yes, latest version.
I'm now in the process of simply forking it and making the changes there;
otherwise this story will repeat itself every time. I hope to check it in
somewhere today.
Date: 10 Jul 2015 17:35:01
Message: <web.55a039f3527de37e6d0f10450@news.povray.org>
> somewhere today.
Actually it turned out to be quite a bit more complicated than this
description... :-(
It now works, I've also added a new camera just for the fun of it. I've also
changed a ton of boost::tr1 to std; that's how it should be anyways if you're
using 'using' throughout the solution.
Latest version fork can be found here: https://github.com/atlaste/povray . I'll
make a pull request, hopefully they'll pick it up.
Date: 11 Jul 2015 00:18:18
Message: <55a0990a$1@news.povray.org>
Am 10.07.2015 um 23:32 schrieb atlaste:
> I've also
Wait... what?
There's not a single "boost::tr1" in the code.
If you're referring to the "boost/tr1/*.hpp" include files, and/or the
use of namespace "tr1::" where C++11 now has the same functionality as
"std::", - by all means leave them be:
(1) POV-Ray is /not/ written in C++11; it is written in C++03/TR1.
Consequently, the TR1 functionality should /not/ be accessed via the
namespace where it resides in C++11, but via the original "tr1::" namespace.
(2) This is a deliberate decision, aimed at providing maximum
portability. To my knowledge, all contemporary C++11 compilers also
still support the "tr1::" namespace.
(3) The use of "boost/tr1/*.hpp" instead of the corresponding TR1 header
files is also deliberate, in order to provide compatibility with pre-TR1
C++03 compilers. The boost/tr1 header files are stubs that pull in
either the compiler's own TR1 headers (if available), or map boost's
implementations of the same functionality into the "tr1::" namespace.
Likewise, it can be expected that future versions of those header files
will also pull in from "std::" of any C++11 compilers that cease to
natively support the "tr1::" namespace.
Date: 13 Jul 2015 13:45:01
Message: <web.55a3f7f7527de37e6d0f10450@news.povray.org>
> Wait... what?
Well, yes and no. There a bunch of 'using' statements in the code, that are the
root cause of the issues I had yesterday. I cannot recall the details to be
honest - then again, I also didn't plan for fixing compiler errors for hours on
end. My original intention was to leave it all alone; until my latest port
yesterday that worked just fine here.
Unfortunately, yesterday something changed that made it impossible for me to do
the above 'tricks', due to name conflicts in boost::tr1:: and std:: . Deliberate
or not, the fact is that it didn't work anymore.
I guess that a better solution would be to use a #define with a namespace based
on the compiler; still, I didn't really feel like making such a huge change
yesterday.
If you browse through my changes, you'll notice that I I haven't changed the
boost libraries themselves and only changed a handful of things. From the top of
my mind:
- std::smart_ptr
- std::vector
- std::bind, std::placeholder::_*
All of these are well supported iirc, and I've checked the features that are
used for incompatible use. Still, if you know a better solution than my
solution, please be my guest.
Date: 14 Jul 2015 06:46:59
Message: <55a4e8a3$1@news.povray.org>
>> [... step 1-9 ...]
Thanks for that, it prompted me to load up the latest source into VS
Community Edition 2013.
> 10. Fix msvc.h:
>    #else
> <algorithm>'.
I needed to add the #include to ImfHeader.h too otherwise I got lots of
errors about std::min and std::max.
Date: 31 Jul 2015 12:16:45
Message: <55bb9f6d$1@news.povray.org>
Am 13.07.2015 um 19:41 schrieb atlaste:
> yesterday.
I'm sure that's the right way to go though.
> my mind:
> - std::smart_ptr
I guess you mean std::shared_ptr, right?
> - std::vector
No, they're not; they're entirely C++11 specific (except for
std::vector; dunno where you found something else; but let's please keep
the "std::" out of the code for that one, as it's too frequently used.
Also, I don't know about std::placeholder; never heard of it before).
Date: 13 Nov 2015 17:12:29
Message: <5646604d@news.povray.org>
Am 05.06.2013 um 14:03 schrieb scott:
> “shared_ptr”
> “boost::shared_ptr”
Just wondering whether anyone is still using Visual Studio Express 2012
and might want to try building the current master branch?
If so, I'd love to know whether you can get away now with performing
only steps 1-3, 7 and 9.
