Hacking happily along at the POV-Ray code, I stumbled across this MS
Visual Studio 2005 C++ anomaly:
class A
protected:
void a() {}
class B : public A
protected:
void b(A* other)
this->a(); // (1)
other->a(); // (2)
While (1) compiles fine, (2) raises an error C2248, "'A::a' : cannot
access protected member declared in class 'A'"
What the F*** am I doing wrong here?
On 27.11.10 15:00, clipka wrote:
> Hacking happily along at the POV-Ray code, I stumbled across this MS Visual
> class A
> protected:
> void a() {}
> class B : public A
> protected:
> void b(A* other)
> this->a(); // (1)
> other->a(); // (2)
> While (1) compiles fine, (2) raises an error C2248, "'A::a' : cannot access
SP1 installed?
Am 27.11.2010 15:03, schrieb Thorsten Froehlich:
> SP1 installed?
Not sure; here's what the "about" window says:
Microsoft Visual Studio 2005
Version 8.0.50727.762 (SP.050727-7600)
Microsoft .NET Framework
Version 2.0.50727 SP2
Installed Edition: Standard
Microsoft Visual Basic 2005 77633-235-7976321-41904
Microsoft Visual C# 2005 77633-235-7976321-41904
Microsoft Visual C++ 2005 77633-235-7976321-41904
Microsoft Visual J# 2005 77633-235-7976321-41904
Microsoft Visual Web Developer 2005 77633-235-7976321-41904
Microsoft Web Application Projects 2005 77633-235-7976321-41904
Microsoft Visual Studio 2005 Standard Edition - ENU Service Pack 1
(KB926601)
This service pack is for Microsoft Visual Studio 2005 Standard Edition -
ENU.
If you later install a more recent service pack, this service pack will
be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/926601
Security Update for Microsoft Visual Studio 2005 Standard Edition - ENU
(KB971090)
This Security Update is for Microsoft Visual Studio 2005 Standard
Edition - ENU.
If you later install a more recent service pack, this Security Update
will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/971090
(KB973673)
Edition - ENU.
For more information, visit http://support.microsoft.com/kb/973673
VisualHG 1.0.8
Mercurial based source contol provider.
>> SP1 installed?
> Microsoft Visual Studio 2005 Standard Edition - ENU Service Pack 1 (KB926601)
> This service pack is for Microsoft Visual Studio 2005 Standard Edition - ENU.
Seems installed. Note that apparently there are several bugs related to
C2248 that were not fixed in VC 2005.
Thorsten
AFAIK it's not an anomaly in VS, but a quirk in the C++ standard.
Le 27/11/2010 15:00, clipka nous fit lire :
> class A
> protected:
> void a() {}
> class B : public A
> protected:
> void b(A* other)
> this->a(); // (1)
> other->a(); // (2)
Issue of C++, or on the chair ?
(1) is ok because B is an A, so can access the protected function.
(2) is not allowed because a() of A is protected, so can only be called
by the object itself (in a gross simplification).
Works as designed.
Actually that's not completely true. This is completely ok:
class A
protected:
void protectedFunctionOfA() {}
class B : public A
public:
void foo(B* other)
other->protectedFunctionOfA(); // ok
'protectedFunctionOfA()' is not being called by the object itself, yet
it's ok. However, the difference is that 'other' is of type B, in which
case it's allowed. However, if it was of type A, it would not be allowed:
void foo(A* other)
other->protectedFunctionOfA(); // not ok
Basically, B is allowed to call the function only if the object is
(known to be) of type B, but not if it's only known to be of type A
(by static typing, ie. even if the object behind the pointer is in
reality of type B).
Even if you did this, you would still get an error:
void B::foo()
A* ptr = this;
ptr->protectedFunctionOfA(); // not ok
(The compiler *could* deduce in this case that 'ptr' is really pointing
to an object of type B, but there are only so many cases where it could
prove it for certain, and this could change from compiler to compiler.)
Needless to say, gcc (and probably most other C++ compilers) will give
an error for that, so it just cannot be done. If you need to call the
protected section of the object, take a pointer of the derived type,
because that's what it has to be.
Le 27/11/2010 21:27, Warp nous fit lire :
I did write "in a gross simplification", didn't I ?
Or "just" make B a friend of A. Or in fact, only the needed function of
B can be a friend of A.
Now, I would question the design any way for such function b
(as it is bypassing the objects' boundaries), but sometimes it's simpler
than redesign everything.
class B;
class A
protected:
void a() {}
friend void B::b(); // more restricted than "friend B;"
class B : public A
protected:
void b(A* other)
this->a(); // (1)
other->a(); // (2)
Am 27.11.2010 21:01, schrieb Le_Forgeron:
> Works as designed.
Is that so?
Why should (2) be prohibited when (1) is not? After all, the practical
use of protected members is to hide implementation details from "alien"
code; but the code in (2) is not alien - it must rely on that
implementation detail called "a()" even if it just calls it on itself,
so why prevent it from calling it on some other object of type A?
I can see how this /could/ be intended, but I'm not so sure whether it
/is/ intended. At least it is unexpected for me, and makes life more
cumbersome than necessary.
Le 28/11/2010 18:28, clipka nous fit lire :
>> Works as designed.
> Is that so?
You should thinks "object oriented" as "public is what is available to
everyone, private is for myself only. Protected is a mixed path to allow
inheriting classes & friends to also have access to it.".
Whenever an instance X of an object has a reference to an instance Y
does not allow the methods of X to access the protected & private area
of Y, even if X & Y are from the same class.
Illustration with gun (protected method) & policeman (class):
Policeman X can use its gun (gun is protected, so other normal people do
not have access to it!)
Policeman X has to drive policeman Y (so X know about Y).
Nevertheless, Policeman X is not allowed to use the gun of Y directly.
X & Y are both Policemen, but each one keep his/her/its gun protected.
Or do you think the policeman from L.A. should be free to use the gun of
the policeman of N.Y. ? (free as: whenever, wherever, without even the
shadow of a control ?)
But with this logic, the example Warp posted should also be forbidden.
I didn't try it myself but if the behavior is as described in this
thread it would mean protected access is restricted as follows:
Type/Instance This Other
Parent Ok Fail
Same Ok Ok
Which I too find a bit odd.
Right, so you found a failure in the analogy when pushing it further
than intended.
I won't refine it, can you imagine policemen from the same specialised
activity sharing their gun ?
> Parent Ok Fail
> Same Ok Ok
Not so odd, if you consider that, from the point of view of knowing the
implementation, the failing case is just missing a friend to be ok;
Or turning it otherwise, the scope of calling other(B) when inside B is
ok, whereas the scope of calling other(A) when inside B is not.
(scope is different, hence the failure).
The sub-problem to forbid the warp's case would be if the called method
was a class method (not per instance, just per class)... it would
generate more problems.
Encapsulation principle: if you are the programmer in charge of B, you
do as you want with all the B, as long as it stays in B.
Protected:
* Can be data and method members
* Exactly same as private members for all practical purposes except
for the inheritance part
* These members are inherited by a child of the class in which they
are declared
* Their behaviour in the child class depends on how the inheritance
has been defined
* If the inheritance is private these are private in the child
class; if it is public these are public in the child class and if the
inheritance in protected these are protected in the child class thus
allowing further inheritance.
Private:
* Can be data or method members
* Are accessible ONLY thru other methods of the same class where
they are declared
* Cannot be accessed thru a class instance
* Will not be inherited
Those who would give up Essential Liberty to purchase
a little Temporary Safety, deserve neither Liberty nor Safety.
Benjamin Franklin
I'd say you can think of it like when B inherits A, B inherits the
protected section of A, and it thus becomes also B's own protected section.
B can access its own protected section, but not A's protected section.
The distinction comes into play when you have an object of type B vs. an
object of type A. B can access the protected section of the former (because
it is part of B's protected section), but not the protected section of the
latter (because now it's purely A's protected section, not B's).
(I'm not saying that this is a perfect design, or that it makes perfect
sense. I'm just describing the situation.)
If you know that the object behind the pointer is really of type B, you
can make a cast to B. If the object has RTTI you can make a dynamic cast
to test if the object is of type B. If it's not of type B, then you just
can't call its protected section.
