POV-Ray : Newsgroups : povray.programming : isosurface intersection code rewrite Server Time
8 Oct 2026 18:40:21 EDT (-0400)
  isosurface intersection code rewrite (Message 1 to 6 of 6)
Subject: isosurface intersection code rewrite
Date: 11 Mar 2008 12:15:39
Message: <47d6be3b$1@news.povray.org>
as I was very interested in the isosurface intersection code I did a
complete rewrite of it based on the beta source. My new code moves all
the global and thread global structures and variables into classes and I
implemented some optimisations:
- Every isosurface now has a separate cache with multiple entries (speeds
up camera ray tests, shadow ray tests and reflection ray tests)
- Intersection points are interpolated, so much smaller accuracies are
sufficient
- An expensive optimisation that could speed up calculations when using
very slow functions (and slow down when using faster functions...)
- General code cleanup
Mostly due to the bigger cache raw isosurface performance (tested with
Christoph Hormann's SCC3 entry, all rays hit the isosurface, radiosity
off) is now about 25% bigger. The new code makes about 10% less function
VM calls. I did not do long tests but the new code is always faster... I
implemented almost (some statistics code is missing) all features of the
current beta. The results are not identical but the reason is
interpolation which leads to a higher quality!
If anyone is interested in the code I will post it on
povray.binaries.programming.
Lukas Winter
Subject: Re: isosurface intersection code rewrite
Date: 11 Mar 2008 13:02:11
Message: <47d6c923$1@news.povray.org>
	Are you kidding?  Of course we are *not*  ;-)
	- NC
Date: 12 Mar 2008 07:50:03
Message: <47d7d17b@news.povray.org>
Lukas Winter schrieb:
> Hi,
I am not sure how this is meant - the existing isosurface cache IIRC
speeds up subsequent rays missing the surface.
> sufficient
This is already in MegaPOV and i thought it also was in 3.7.
More details would be required on this.
Interpolating the intersection point should converge to the same result
as not doing so in all well defined cases.
-- Christoph
Date: 12 Mar 2008 11:57:18
Message: <47d80b6e@news.povray.org>
Am Wed, 12 Mar 2008 13:50:29 +0100 schrieb Christoph Hormann:
>> (speeds up camera ray tests, shadow ray tests and reflection ray tests)
The existing cache explicitely excludes shadow rays. It also does a poor
job when there are several isosurfaces in the scene. The reason is that
most of the time subsequent tests come in the same order, i.e. several
_different_ kinds of tests repeat in a certain order but the cache only
speeds up _similiar_ rays. So one cache entry overrides another and there
are a lot of cache misses that could have been avoided if the cache kept
older entries. On the other hand the cache should not be too big to avoid
expensive tests against very old entries. I usually use 2 or 3 cache
entries per isosurface.
>> sufficient
The isosurface code of beta 25 is nearly identical to that of 3.6.1.
There are some changes to make it thread-safe and the object is now a
class.
The code tries to move the point where it splits the current interval in
two intervals to a better place under some circumstances. But a speed-up
thanks to this is very rare.
True. But as we just do an approximation, self-shadowed areas will look
slightly different. In the current beta and 3.6.1 the transition between
shadowed and lit areas will always look grainy even with high accuracies.
With interpolation they look smooth.
Date: 13 Mar 2008 02:15:14
Message: <47d8d482$1@news.povray.org>
is this cache per thread or global?  The former would make more sense
since the rays are only correlated in a thread and not between several
ones.  Also it would make sense to exclude radiosity rays.
Sounds much like the sphere tracing technique to me - i once tried this
and it did not seem to be have a significant advantage to me.  Some more
on this can be found in stuff on:
http://graphics.cs.uiuc.edu/~jch/papers/?cat=implicit
If more information is known about the isosurface function things can be
different of course.
-- Christoph
Date: 13 Mar 2008 07:00:46
Message: <47d9176e$1@news.povray.org>
Am Thu, 13 Mar 2008 08:15:23 +0100 schrieb Christoph Hormann:
There is one cache per thread per isosurface via
boost::thread_specific_ptr. I figured out that the number of cache
entries should be kept smaller than (number of lightsources + number of
reflective textures on the isosurface). So only one cache entry is enough
for most simple scenes with non-reflective isosurfaces.
You are right. I did not know what this technique was called. The current
POV implementation finds a root on an interval [t_min, t_max] in a fixed
number of recursions. I tried to lower this number somehow but it did not
work out well.
