POV-Ray : Newsgroups : povray.programming : Perl Interface Server Time
9 Oct 2026 02:47:15 EDT (-0400)
  Perl Interface (Message 1 to 2 of 2)
Subject: Perl Interface
Date: 10 Mar 2005 01:39:52
Message: <422febb8@news.povray.org>
I seem to recall seeing mention of such a thing someplace, but I can't
find it any more.
If it doesn't exist, I'll probably start hacking.
That being the case, here's a question I hope can be answered. Does a
'while' loop in SDL save anything on the processing side?
ie, If I have a scene with 100 boxes, does POV-Ray prefer that I have a
loop or that I have 100 boxes, or doe it not matter.
I imagine it doesn't matter.
In a while loop the file is quicker to read, however it needs to parse
the loop which is processor time.
With 100 boxes the file takes longer to read, but there is no looping
that needs to be taken care of.
Experts?
Subject: Re: Perl Interface
Date: 10 Mar 2005 15:15:43
Message: <4230aaef@news.povray.org>
  It doesn't matter.
  Parsing 100 boxes is theoretically slightly faster because povray
doesn't have to parse "#while", "#declare" and "#end" 100 times
(which it has to do if you use a loop), but I suppose that the
difference in time is not that much.
  I don't think it takes longer to read.
  POV-Ray doesn't cache the input. When it has to jump in the file, it
just seeks it and continues reading from the new position.
