POV-Ray : Newsgroups : povray.programming : POV-Ray 3.5 for AmigaOS Server Time
9 Oct 2026 02:47:19 EDT (-0400)
  POV-Ray 3.5 for AmigaOS (Message 1 to 37 of 37)
Subject: POV-Ray 3.5 for AmigaOS
Date: 1 Jun 2004 22:37:54
Message: <40bd3d82$1@news.povray.org>
I've become interested in porting POV-Ray to AmigaOS 3.1+ but I'm a bit
concerned that I'll be either break some legalities or be re-inventing
the wheel because somebody else is doing it. If not, is there any
dissent if I port POV-Ray 3.5 unofficially to the AmigaOS and link this
to my main page?
The following link is not linked off the main site:
http://<broken link>/amiga/povray.shtml
Respectfully,          "Leave it to the coward to make a religion
Dan P            of his cowardice by preaching humility."
                                    - George Bernard Shaw
Subject: Re: POV-Ray 3.5 for AmigaOS
Date: 2 Jun 2004 13:42:00
Message: <40be1168$1@news.povray.org>
> the wheel
	Probably both would not be a problem, but the best remains
checking povlegal.doc and google  :-)
	The status shows you're currently fixing the code to work
with gcc/g++ 3.3.  Could you mention precisely what you have/had
to fix ?  Since the source code of POV-Ray 3.6 will be released
within a few weeks and that it is know to compile with gcc 3.3.x
and 3.4.0 on various platforms, it'd be worth waiting a bit longer
before tweaking a two-years-old code.
	As mentioned on the www.povray.org/beta page, the UNIX
source distribution will be beta-tested, most likely starting this
month.  If you are willing to test it, I'd be glad to see what the
reworked build system could give on the AmigaOS  :-)
	- NC
Date: 2 Jun 2004 19:10:09
Message: <40BE5E5C.7080001@yahoo.com>
Nicolas Calimet wrote:
>> I'll be either break some legalities or be re-inventing the wheel
Absolutely -- didn't seem that anyone else was interested (this scares
me, actually, because AmigaOS 4 is coming out and it looks da bomb) and
povlegal.doc will be my bible for a while (to whom do I pray, though?)
>     - NC
Instead of messing around with the configure, I just started to build
the Makefile from scratch (I wanted to understand how the files
interrelated and, as a way to do that, I rolled up my sleeves and dug
into the code -- sometimes I'm not lazy enough, maybe, for my own good).
I didn't realize that it was made for gcc (actually, I should have; I
was thinking, when I was driving home salivating about getting to work
on it, that the "configure" script should have been a clue). I was also
compiling with g++, not gcc; didn't even think to change that, if that
was what was up.
Aside from a lot of warnings that arose because of implicit casting from
a double to a long or int (which I resolved using (int) floor() just
because I'm very, very strict about treating warnings as errors) I found
that, in the file "povmsgid.cpp", the enumerations were assigned to
static strings surrounded by single quotes, which is something I have
never seen before -- first, I thought enums had to assign to ints, and
second, I thought single quotes were for characters, not strings). The
compiler agreed on both counts and gave me quite a lashing about
what-for about it. So, I created a PERL script to grab each of those
strings and generate a file with defines called "povtypes.h" and made
those defines with unique IDs starting from 1000. Then, I went to
"povmsgid.cpp" and got rid of those double-quotes and dealt with the
strings like '****' by making it 'AAAA' and 'NULL' by making it 'NuLL'.
When that compiled, I started tracing the include hierarchy and building
the Makefile. Sore fingers later, and a lot of clean-compiles and
thank-Gods later, I still waswondering what the "goal" of those defines
was and if there is something fundamental that I'm missing about the
whole affair that is going to bite me in the cheeks later.
So, it looks like, from what you are saying, I should just unpack the
thing and enter in the goodies to make the configure script work
properly with an AmigaOS entry. Probably the best thing to do, but my
goal was just on getting it to work first and dig in and understand it
and then prettify later and stress-test it with the provided test suite.
After it is running on command-line, it just seems silly not to start
building a GUI around it, like Windows or Mac has. I mean, this /is/
that Amiga after all.
Here's a screen-shot of my directory listing so far:
http://<broken link>/images/amipovfiles.jpg
Since, aside from those warnings, that really seems to be the only thing
it complained about, would someone venture to clue-me-in on what happens
with povmsgid.cpp? Is there some program in-between that turns those
happy 'strings' into numbers?
I'm really excited -- 3.5 on the Amiga will do great things for the
Amiga and excite a lot of new POV-Ray users. I just want to make sure
I'm Kosher in this pickle. In fact, I'm willing to put in the effort to
coordinate an official version with you guys if you think I'm sane
enough to help with it. I dream of seeing povray.programming.amiga happen...
Date: 2 Jun 2004 22:51:24
Message: <40be922c$1@news.povray.org>
<snip />
At first, I thought to think myself an idiot, but then I thought and
thought and realize -- it wasn't obvious and I was lucky to figure it
out. When I ran "sh configure", it failed because it couldn't find a
"/tmp" directory. It occurred to me how the AmigaOS uses the assign
command and did this:
mkdir tmp
assign tmp: tmp
sh configure
It is configuring now rather happily. g++ is notoriously slow on the
Amiga, so I'm going to let it run for a while. That's not the fault of
the Amiga but, instead, the build for the OS. The emulator I'm running
is running full-speed and runs many programs faster than Windows XP. I
have an Amiga 3000T coming soon to do testing on a real Amiga.
Pending compile...
Date: 2 Jun 2004 23:22:43
Message: <40be9983$1@news.povray.org>
Dan P wrote:
> <snip />
> Pending compile...
So far so good. Now I have to compile all those "POV-Ray Absolutely
Needs these Libraries" libraries. I have a good feeling about this...
Date: 3 Jun 2004 00:44:44
Message: <40beacbc$1@news.povray.org>
Dan P wrote:
> Dan P wrote:
>> <snip />
>> Pending compile...
Installed libjpeg6b -- successful
Still requires tiffio.h -- the documentation does not note that this is
a required library. I'll download it, but this is something you might
want to note in the README.
Using tiff library from http://www.libtiff.org/build.html#Other
Subject: Milestone! Compiled!!!
Date: 3 Jun 2004 01:37:52
Message: <40beb930$1@news.povray.org>
Milestone! After porting libtiff to the Amiga (I'm thinking of
contributing it to Geek Gadgets) and removing the version number from
the output for the PNG library (must have an old library that did not
include the function -- will look into it) and setting the define to say
that there is no X Display (this isn't X-Windows!), I've managed to
successfully compile and install POV-Ray 3.5 on the Amiga! I have yet to
run the tests, but this m68k executable should work. When I get my
3000T, I'll make sure to run tests on a native platform.
Next step: Make an icon, have it spawn a shell that lets the user just
type 'povray' without having to do any special setup, package the proper
files using lharc, and link it to the web-site. Then, I'm ambitious
enough to learn programming Intuition to port over the interface from
Windows/Mac to the platform. Seems like it is a great way to learn it
since it is really just a text editor with some special menus and a
window display that captures the output and displays it progressively.
If an when I get to a point where you are thinking me serious enough to
do an official distribution, know in advance that I'm willing to do what
it takes to bring POV-Ray 3.5 officially to the Amiga. I have a dream:
to see povray.programming.amiga be a newsgroup where the ten or so
people who use it find a home :-) With the other effort, AmiZilla, Amiga
just might come back. It should. It is the operating system we all
actually want today. I'm going to bet the last Amiga team said something
similar.
Here is the latest screenshot:
http://<broken link>/images/amipovray2.gif
I haven't actually compiled a scene yet (I'm so excited to get to this
point!) There are lots of warnings in the code, so I'm a little worried
about some of it. I'll feel a lot better when it passes all the tests.
PS: I used the actual 'configure' script to compile this, so yes:
gcc/g++ works! There were minor Amiga-specific tweaks I had to made, but
nothing that a more seasoned Amiga programmer would even notice.
Subject: Bah.
Date: 3 Jun 2004 01:59:31
Message: <40bebe43$1@news.povray.org>
Bah. It looks like it is trying to free an invalid memory block on my
test file. It could be a bug in the linked ixemul library, but
intuitively, I doubt it. Looks like I have some tracing to do. That's
okay; things that are easy aren't worth doing. If there is anything this
effort may yield to the team, it is at least a different perspective on
the code that might help make it more stable.
Screenshot:
http://<broken link>/images/amipovray3.gif
Those warnings bug me, so I'm going to fix them. As a rule, I use
floor() and cast it to an int when I'm going from a double to an
integer. I think that is the default behavior anyway so I'm going to add
the necessary code to make it compile cleanly (at least, on this platform).
Subject: Re: Bah.
Date: 3 Jun 2004 09:21:18
Message: <40bf25ce$1@news.povray.org>
In article <40bebe43$1@news.povray.org> , Dan P <dan### [at] yahoocom>
Argh!  Don't do something like that, it is plain wrong!  If you compiler
issues nonsensical warnings, the right thing to do is to disable them, not
to destroy your source code!
    Thorsten
e-mail: tho### [at] trfde
Date: 3 Jun 2004 09:27:14
Message: <40bf2732$1@news.povray.org>
In article <40B### [at] yahoocom> , Dan P <dan### [at] yahoocom>
You should really learn to know the difference between a warning and an
error.  A warning is not an error and as such, it is very likely the machine
informing you about something possibly unintentional is wrong.
> I found
Get a book about C or C++ programming...
Argh - lkjxfsliaejkisddjhfsuikufdfkljhfkljapsdauojsdl - my brain hurts when
I even read about somebody doing pure nonsense this!
    Thorsten
Subject: Re: Bah.
Date: 3 Jun 2004 12:13:10
Message: <40bf4e16@news.povray.org>
> integer.
  By doing that you will be slowing down the code.
  This: "int i = some_double;" is equivalent to this:
"int i = int(some_double);".
  However, you are adding an additional 'floor()' call which will
slow down the conversion needlessly.
  It will also probably give a different result with negative numbers.
Date: 3 Jun 2004 12:17:25
Message: <40bf4f15$1@news.povray.org>
> never seen before [snip]
	Answer is much shorter than you think: yes you're running into
big trouble messing up with the code like this.
	Search google for "multicharacter constant" and look through
the gcc manpage for the -Wno-multichar warning option.
	- NC
PS: you should really-really wait for the 3.6 UNIX source code  :-)
Date: 3 Jun 2004 12:20:07
Message: <40bf4fb7@news.povray.org>
  And since when 'abcd' has not been an int?
> and
  No, 'a' is not a character, it's an integer. 'ab' is also an integer.
  Just try: std::cout << 'ab' << std::endl;
> The compiler agreed on both counts
  If enumerated types can only be assigned with integers (which is true)
and 'abcd' is not an integer (which is false), then the compiler would
give you an error. However, the compiler did not give you an error and
thus the compiler is disagreeing with you.
  What for? What is the current code doing wrong?
  They are not strings. Learn C, will you?
Date: 3 Jun 2004 12:24:37
Message: <i2kub0tdgh8u03tonel42bks0skjtb1epi@4ax.com>
On Thu, 03 Jun 2004 18:17:24 +0200, Nicolas Calimet <pov### [at] freefr> wrote:
No need for google. Searching this in povray.programming is enough.
ABX
Date: 3 Jun 2004 12:25:00
Message: <40bf50dc$1@news.povray.org>
	Aouch !  Thorsten's got broken(*) !!
	It's Armaggedon right before the 3.6 release !!!
	HELP !!!!
	- NC
(*) sounds like a top-ten hit in pop music  :-)
Subject: Re: Bah.
Date: 3 Jun 2004 19:15:19
Message: <40bfb107$1@news.povray.org>
>>integer.
That makes sense.
Date: 3 Jun 2004 19:17:48
Message: <40bfb19c$1@news.povray.org>
Warp wrote:
<lots of crap that drains another's enthusiasm />
Right; this is what I expected when I posted to this group. That initial
post threw me off. I thought maybe you and TF weren't listening. Okay,
listen; I didn't know about the MultiCharacter constant thing. There's a
lot I didn't know about. So, kiss my ass.
Subject: Re: Bah.
Date: 3 Jun 2004 19:20:18
Message: <40bfb232$1@news.povray.org>
>     Thorsten
Warnings warn you of when your code may behave differently on other OS's
as well. I'm not saying that is true in this case -- it makes sense not
to call another function there if we don't have to -- but I didn't think
it was "nonsensical".
Oh, and if your code was so damn good, TF, it wouldn't have crashed
using a straight-up clean compile on this OS so step-off.
Date: 3 Jun 2004 19:29:23
Message: <40bfb453$1@news.povray.org>
<snip />
You know what? I've decided against doing this port after all. I've got
other plans. With this kind of attitude, and any of you who think this
is a way to act as a team, you all can kiss my ass, not just Thorsten.
The last thing I need is to deal with premadonnas like you.
I'm out.
Date: 3 Jun 2004 19:43:17
Message: <40bfb795@news.povray.org>
> There's a lot I didn't know about. So, kiss my ass.
  When you don't know, the first thing to do is to ask, not to go and
"fix" someone else's code and make a post with a tone of voice which
sounds like you know better than the original code and that the current
code sucks.
  So, it should be: "Hey, there's some odd code which I don't understand
and which looks wrong to me. Is it wrong?" "No." "Ah, ok, never mind."
  Not: "Hey, there's some odd code which looks wrong to me so I went
and fixed it, even though I don't really understand what's going on."
  If you don't understand how a code works and why it is done as it is
done, ask.
Date: 3 Jun 2004 20:33:36
Message: <40bfc360@news.povray.org>
Program ended abnormally on 03/06/2004 19:29, Due to a catastrophic Dan P
error:
> <snip />
> I'm out.
Calm down.  Try to get over their tone and listen to their advise, it's usually
pretty good.  Warp and Thorsten can be abrasive at times, but that's why we like
'em.  ;-)
FWIW, I've suffered worse from Thorsten, and I lived to tell the tale.
Subject: Re: Bah.
Date: 4 Jun 2004 02:33:30
Message: <40c017ba@news.povray.org>
     int i = (int)some_double;
http://tth.vaboofer.com/Cette/
Date: 4 Jun 2004 03:01:31
Message: <40c01e4b@news.povray.org>
In article <40bfb795@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> code sucks.
> done, ask.
Exactly!!!
    Thorsten
Subject: Re: Bah.
Date: 4 Jun 2004 03:17:25
Message: <40c02205@news.povray.org>
In article <40bfb232$1@news.povray.org> , Dan P <dan### [at] yahoocom>
Given what you have done to the code and probably the makefile, this is
hardly surprising!  Get a clue, then start to mess with the source code, not
the other way around.  As it stands, you wasted tons of your time to "fix"
something that you simply did not understand.
Making fairly random changes all over the code is not the correct approach
to try to fix a problem in a program.  A debugger is!
> but I didn't think it was "nonsensical".
It is because you assume you know so much better than the original authors
and that those tens of individuals were all so stupid that we needed you to
come along and fix our code.  Did it occur to you that this is not likely?
    Thorsten
PS: You are not the first person to not understand what a multicharacter
constant is, it has been discussed in this group before, so I will add a
note to that file to help all those people understand.  Never expected
something like this would be necessary <sigh>
Date: 4 Jun 2004 05:23:11
Message: <5ue0c0t2co2h2hla6q8ds007gvotd4ksc1@4ax.com>
I think I started at the same point as you so I think I have some reference.
Note, nobody said "kiss our ass if you do not know what multicharacter is." I
didn't know multicharacter issue too when I started reading 3.5 sources. And I
went through fixing warnings too, but I never asked for favour to my ass
because it's clear that before bothering some team about used rules you have
to understand them before you start to fix them. Even unofficial port is not
welcome by community if it is done wrong, that's clear. There _is_ experience
in POV Team Members, think about them like about teachers. You ask teacher:
"hello, I want to make another unofficial nuclear power plant by playing with
atoms in my room". Teacher answer "Doing it this way is wrong and it's
illegal, there are some rights and conventions. My brain is hurt because of
your will". "Then kiss my ass" you answer to your teacher. Childish.
ABX
Date: 4 Jun 2004 05:57:40
Message: <40c04794@news.povray.org>
        Maybe the usual problem in such cases is the staight "No." answer.
Giving a slightly more informative answer could in the end save a lot of
time, which is otherwise "wasted" answering complaints as in this thread.
        Well, I also know that time is precious, especially at the moment.
        - NC
Subject: Re: Bah.
Date: 4 Jun 2004 09:55:08
Message: <40c07f3c@news.povray.org>
  Well, POV-Ray is compiled with a C++ compiler currently. May as well use
the C++ way.
Date: 4 Jun 2004 09:58:54
Message: <40c0801e@news.povray.org>
  That "No." was only symbolic, for shortness. Of course it meant a
proper negative answer.
Subject: Re: Bah.
Date: 4 Jun 2004 13:14:59
Message: <40c0ae13$1@news.povray.org>
> the C++ way.
    Ah OK, sorry. I'm not a C++ expert, I'm to old for this modern
    technology :)
Subject: Re: Bah.
Date: 4 Jun 2004 17:51:23
Message: <40c0eedb@news.povray.org>
> > the C++ way.
>     technology :)
  There's a reason for the new syntax. It has to do with abstract types
(classes and template parameters). However, I don't think anyone is
interested in another C++ lecture of mine... :P
Subject: Re: Bah.
Date: 10 Jul 2004 18:06:43
Message: <40f06873$1@news.povray.org>
On the contrary, I like reading them =)
Wouldn't the real C++ way be something like
reinterpret_cast<int>(some_double)
Or something like that? Not sure what type of cast it would be.
 - Slime
 [ http://www.slimeland.com/ ]
Subject: Re: Bah.
Date: 10 Jul 2004 18:46:12
Message: <40f071b3@news.povray.org>
The "correct C++ way" would be to use static_cast<int>().
This is because reinterpret_cast<>() will not change the binary
representation while doing the cast (and is hence meant for potentially
dangerous casts). Since casting a double into an int does require
a change in the binary representation (usually 8 byte floating point
into 4 byte integer), reinterpret_cast<>() cannot be applied.
The compiler should give an error in this case.
Wolfgang
Subject: Re: Bah.
Date: 10 Jul 2004 21:33:59
Message: <40f09907@news.povray.org>
> representation...
Yeah, that's why I said "Not sure what type of cast it would be."
My point was, isn't "something_cast<int>()" the C++ way instead of "int()"?
 - Slime
Subject: Re: Bah.
Date: 11 Jul 2004 05:23:51
Message: <40f10727@news.povray.org>
  static_cast is actually the only "clean" casting type. All the three
other casts are more or less ugly casts which usually shouldn't be
used in well-designed code. Usually if you need to use the other casts,
it's a sign that there's a flaw in your design (even though there are
a few exceptions, but as a rule of thumb).
  static_cast performs a cast between compatible types. Although
casting between compatible types does not usually need an explicit
cast (implicit casting is usually ok), it's usually recommended to
do the cast explicitly when the cast is done from a "larger" type
to a "smaller" one (eg. from int to char, or from double to int, etc).
It can be thought as a kind of "documentation" which says "yes, I really
want to cast even at the risk of losing significant digits".
  static_cast should fail (ie. give a compiler error) if the cast is
performed between inompatible types (for example trying to convert
an int to a pointer).
  There's actually one situation more where static_cast can be used:
When downcasting a base-class type pointer to a derived-class type.
The compiler will not complain about this, but it's a bit dangerous
because you must be sure that the base-class type pointer really points
to the derived-class type you are casting to or else malfunction will
follow. There are a few cases where this is ok, but usually if you need
to downcast at all, you should use dynamic_cast instead.
  dynamic_cast converts between class pointers, but it checks at runtime
that the cast is valid. If the cast is invalid, it returns a 0 pointer.
This is usually done for downcasting a pointer and checking that it
succeeded.
  Usually, though, if you need to downcast, it's a sign of bad OO design.
  const_cast casts a const pointer to its non-const version. If you need
to use it, there's a flaw in your design. (The only place you should be
forced to use it is when having to use someone else's library which is
badly designed.)
  reinterpret_cast casts between incompatible types (eg. from an int to
a pointer or between pointers to completely unrelated types). Usually
only needed if you are making low-level hacker code, usually not needed
for high-level OO code.
Subject: Re: Bah.
Date: 11 Jul 2004 05:35:40
Message: <40f109ec@news.povray.org>
  Sometimes the latter cast is necessary.
  Consider this:
template<typename Type1, typename Type2, typename TypeConverter>
void foo(Type1 v)
    Type2 v2 = TypeConverter(v);
  Now, 'TypeConverter' can be an inner type (eg. 'int'), an abstract
type (eg. a user-defined class), a function or a class instance (for
which the 'operator()' is defined).
  For example, you could call the above function like this:
int convertDoubleToInt(double d)
    return some_complex_conversion_from_d_to_int;
    foo<double, int, convertDoubleToInt>(xyz);
  In this case foo() makes a convertDoubleToInt() function call.
  However, of you do it like this:
    foo<double, int, int>(xyz);
what foo() will do is a cast (that is: "int v2 = int(v);").
  Since specially in template functions a xyz() call can be many things
(function call, operator() call, typecast), that's the reason why the
'type(value)' casting is necessary.
Subject: Re: Bah.
Date: 11 Jul 2004 16:56:06
Message: <40f1a966@news.povray.org>
In article <40f10727@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> succeeded.
I don't think one can generalise that using dynamic_cast suggests a bad
design somewhere.  Without dynamic_cast a less-static binding of objects
would not be possible at all.  The only real problem with dynamic_cast is
that it has a (by newbies unexpected) runtime overhead that cannot be
predicted very well...
    Thorsten
Date: 15 Jul 2004 01:55:06
Message: <40f61c3a@news.povray.org>
I would like to see a port to amiga
good on yous :)
