Jake McDowell <McN### [at] techie com> wrote:
> dSpline(blah),
You don't need a comma there.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
>> dSpline(blah),
Alternatively you could move the comma so that it comes before the
dSpline(blah) and remove the hard-coded one after the 80.
polygon {
80
#declare blah=80;
#while(blah>0)
,dSpline(blah)
#declare blah = blah-1;
There are some situations where commas are required and that trick
doesn't work (I can't think of a situation off hand, but I've met one in
the past). In such a case you could process the first or last item
outside the loop
polygon {
80,
dSpline(80) // out of loop, no comma
#declare blah=79;
#while(blah>0)
,dSpline(blah)
or put an #if statement round the comma.
polygon {
80,
#declare blah=80;
#while(blah>0)
dSpline(blah)
#if (blah > 1) , #end
Mike Williams
Gentleman of Leisure
>>> dSpline(blah),
> polygon {
> 80
> #declare blah=80;
> #while(blah>0)
> ,dSpline(blah)
> #end
> outside the loop
> polygon {
> 80,
> #declare blah=79;
> #while(blah>0)
> ,dSpline(blah)
> #end
> polygon {
> 80,
> #declare blah=80;
> #while(blah>0)
> dSpline(blah)
> #end
w00t !!! yes ! you rock... can you tell i'm not quite used to the
povray way of doing things ? :]
thank you a load... your information/help here is tremendously valuable
to me... i knew there was a simple way of doing this !
Why do it the hard way when you can simply omit the comma?
Omitting the comma happens to work for this particular case, but there
are similar situations where commas are required. It might be useful to
be prepared.
Mike Williams
Can you cite an example?
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
At least commas are necessary in parts of function parser. Below example does
not work without commas.
#local Params=2;
#local F=array[5];
#local F[0]=function(a){0};
#local F[1]=function(a,b){0};
#local F[2]=function(a,b,c){0};
#local F[3]=function(a,b,c,d){0};
#local F[4]=function(a,b,c,d,e){0};
#macro Do(c)
//#if(c>0),#end /* <-- uncomment this line to make it working */
c
#local f=F[Params-1];
#local my_f=function{f(#local C=0;#while(C<Params)Do(C)#local C=C+1;#end)};
ABX
In article <3f2e1de4@news.povray.org>, Warp <war### [at] tag povray org>
Anything that has an expression starting with an operator, such as "-x".
polygon {Foo
Foo
-Foo2
Bar
The point list will be interpreted as "Foo - Foo2, Bar".
This kind of error can be very difficult to track down. I *always* use
commas, and always use logic which puts them where they are needed.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
> polygon {Foo
> Foo
> -Foo2
> Bar
I was talking about lists of parameters created with #commands (#whiles
etc).
Anyways, if you want to be sure, you can simply write (-Foo).
In article <3f2eb776@news.povray.org>, Warp <war### [at] tag povray org>
> etc).
And this is still relevant in that case:
#if(Foo)
-Point
#else
Point
Or you could just use the comma where the syntax specifies one.
>etc).
I recall my discovery from beta testing times when lack of commas still is
parsed fine but behaves wrong:
http://news.povray.org/bp925u4upa1gl9kih2pikg4qusf0lr03kg%404ax.com
ABX
Well, if you think "#if(whatever) , #end" is less obfuscated than "(-Foo)",
then be my guest.
In article <3f2f794b@news.povray.org>, Warp <war### [at] tag povray org>
> then be my guest.
In some cases, it can be. Usually, I'll use the other method...a single
entry outside the loop.
Maybe a parameter list structure could eventually be added to the macro
language...you would just append entries to the list, and ignore the
comma issue entirely.
#declare ParamList = param_list {< 1, 2, 3>, < 4, 5, 6>}
ParamList.append_value(< 1, 3, 5>);
polygon {ParamList.count
ParamList
Or for the original example:
#declare Blah = 80;
#while(Blah > 0)
ParamList.append_value(dSpline(Blah));
#declare Blah = Blah - 1;
ParamList
In article <3f245b5c@news.povray.org> , Jake McDowell <McN### [at] Techie com>
wrote:
> I need to render a fairly complex polygon, somewhat similar to a
> lopsided figure eight or bowtie, in a scene i am working on.
This is the wrong group for this question. This group is for discussion of
the POV-Ray source code. General questions about using the POV-Ray scene
description language should be asked in either povray.general or
povray.newusers.
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
