POV-Ray : Newsgroups : povray.programming : [RFC] Increasing Rendering Speed: Idea and Implementation Server Time
9 Oct 2026 18:46:19 EDT (-0400)
  [RFC] Increasing Rendering Speed: Idea and Implementation (Message 1 to 29 of 29)
Subject: [RFC] Increasing Rendering Speed: Idea and Implementation
Date: 1 Feb 2003 17:52:28
Message: <3e3c4faa@news.povray.org>
[POVRay developers, please make sure to read part 2.3.]
Okay, let's come straightly to the point:
Rendering complicated scenes can take ages, especially if you render
animations. While this is often acceptable for the final rendering, it
really has potential for improvement if you're just interested in
a preview during modelling.
Often, degrading quality (+Q0) is not an option because e.g. you need
the shadow to better view the object orientation in space, etc.
So, let's discuss a different idea (which I do not claim credit
for [1]):
The principle is to only render some pixels and calculate the color of
other pixels using interpolation.
I read some papers which indicate that (if done properly) speed can be
increased by an order of magnitude while nearly not affecting quality
(depending on the scene, of course). The stuff in question is called
Directional Coherence Map.   [ Wow. Sounds cool, right? ;) ]
My first question is: Is somebody working on that for POVRay?
Are there patches addressing this issue?
Being a passionate C/C++ programmer I thought that it is probably no
good idea to wait until the POV Ray team implements something like that.
So, I had a look at the source code myself two days ago.
Let's come to the points which have to be discussed:
1. (Mosaic) Preview:
The current mosaic preview adds rendering time because the pixels
rendered in the preview are not used in the final rendering.
So, I think, one could use a fixed-grid (e.g. 8x8) bilinearly
interpolated preview instead. This should be sufficient for a quick
view of the image before actually rendering it and would produce
nicer images than an 8x8 mosaic preview.
I implemented that and it works fine.
2. Actual image rendering:
The more interesting part.
The easiest approch is to render every 8th pixel in X and Y direction.
4 pixels ( (x,y), (x+8,y), (x,y+8), (x+8,y+8) ) build a block. If
these four pixel differ less (in color) than a specified threshold,
the whole 8x8 block is evaluated using bilinear interpolation.
Else, the block is divided into 4 blocks of size 4x4 requiring that
5 more pixels are rendered. Then, you subdivide into 2x2 and finally
you render all the left pixels.
This is what I implemented yesterday. To keep mem usage low, I am
using a buffer of 9 image lines. The pixels rendered during the
preview are stored in a separate width/8 x height/8 buffer and
being re-used. [Dumb algo? - Read 2.3.]
However, there are several issues:
2.1. First, the povray code structure:
Some easy modifications would have to made (better control when
plot_pixel() actually calls XPutImage() by adding a plot_flush(x,y,w,h)
function, etc).
More seriuos are:
Prune_Vista_Tree()
  I don't know if it is speed critical but it has to be called much
  more often, because 8x8 blocks are rendered sequentially which means
  that the Y coordinate changes freqently.
Do_Cooperate().
  Don't know when it should be called or if it can cope with the
  situation. Could someone enlighten me on POVMS? It seems to deal
  with "messages", "queues" and "objects" but I have no clue.
Current_Line_Number and Current_Line.
  These are global vars and the latter is hard to grep because of
  the similarity with the first one. I don't use them as I use my
  own line buffer (9 lines).
Field_Render_Flag:
  Seems to be some strange thing skipping odd or even lines.
  Probably not 100% incompatible but I currently see no reason for
  supporting it. Maybe anyone has arguments [explain why useful].
Antialiasing:
  Not supported but there is currently not much point in it as we
  are talking about rendering more quickly.
2.2. Evaluation order:
I am currently rendering a rough preview and then rendering the image
top to bottom, 8 lines at a time. This requires "only"
9*width*sizeof(COLOUR) bytes of buffer memory. 8x8 blocks are computed
sequentially.
The other idea would be to keep the whole image im memory and execute
the stages of the algorithm sequentially on the complete image. Nicer
to look at but requires much more RAM (6 Mb for 640x480). No
possibility to resume a half-done image.
2.3. The algorithm itself:
As you probably guessed, I only explained the first step of the
algorithm. After evaluating the 4 corer pixels one could render a
complete rectangle border (32 pixels). Then apply the directional
coherence map.
However, after having rendered the 4 corner pixels, the main problem
is to decide on how to go on. Using a checker plane, I currently get
ugly 8x8 alias effects; objects like thin cones can be skipped
completely (which is extremely annoing in animations).
One idea would be to save which object had most influence on the
color of the ray. If the 4 corner pixels come from different objects,
do not interpolate immediately.
Obviously, textures don't work well with the algorithm because they
behave like fine detail. [2] suggests applying them afterwards but
I doubt that this is feasible for povray. OTOH, you normally don't
use lots of textures if you render a preview.
MOST CRITICAL is the detection if there is more than one object
inside the 8x8 block. A routine doing a quick test on that would
come quite handy. Problems may occur with partial reflection or
interior (ior) etc. but returning (false) positives for some parts
of the scene is acceptable. Unfortunately, I am not familiar with
the innermost workings of the POVRay "engine" so help is appreciated.
[Hope someone is still reading this.]
Wolfgang
References:
[1] Baining Guo, Progressive Radiance Evaluation Using Directional
      Coherence Maps, SIGGRAPH '98 Proceedings
[2] Jörg Pütz, et al, Enhancements to Directional Coherence Maps
Source code of my patch is delivered on request and may be used
under the POV license as well as under the GNU GPL.
It is not limited to 8x8 blocks but I used that here for
simplicity. It is work in progress and far from complete but if
anyone wants to comment on it i'll be happy.
Subject: Re: [RFC] Increasing Rendering Speed: Idea and Implementation
Date: 1 Feb 2003 18:34:21
Message: <3e3c597c@news.povray.org>
  You should be really careful here. Read povlegal.doc carefully to see
if you can do this.
Date: 1 Feb 2003 18:46:27
Message: <3e3c5c53$1@news.povray.org>
In article <3e3c4faa@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
In simpler terms: It is a kind of adaptive antialiasing on pixel blocks.
None that I know about.
Yes.  I know it is intentional, but I do not know why.
> function, etc).
I assume XPutImage is some platform specific function.  I am not sure where
you are going here or what exactly you are talking about.  Please clarify.
> Do_Cooperate().
POVMS is a way to abstract the different output streams and render control
in a way more suitable for GUI platforms.  It has nothing to do with the
actual ray-tracing core.  In future releases of the POV-Ray 3.5.x the other
means of handling output will be gradually removed and replaced by a
POVMS-only system with default code for command-line versions.
Some code depends on them.  So be careful, things may fail in unexpected
ways.
> Field_Render_Flag:
It is an easy way to create animations for interlaced display devices (aka
televisions).
The object found is always on the intersection stack, so you can use that.
    Thorsten
Date: 2 Feb 2003 06:54:35
Message: <3e3d06fb@news.povray.org>
> if you can do this.
Please explain the problem.
I remember the paragraph
"WHY ISN'T POV-RAY OPEN SOURCE ?"
in povlega.doc,
What I stated in these 2 lines just wants to express that my patch
is covered by povegal.doc but there is no problem with my code if
POVRay goes GPL.
Date: 2 Feb 2003 06:56:23
Message: <3e3d0765@news.povray.org>
Kind of, yes.
But the algorithm doing the adaption should be more clever than the
current one and it is not about averaging supersample colors but
guessing colors from fewer samples.
One doesn't need a mosaic preview for the final rendering so there is no
problem with additional time, I think. However, for a quick preview
it would be nice to re-use the pixels like I do.
>> function, etc).
> where
Okay the problem is simple:
Calling plot_pixel() should display the pixel on the screen (SVGAlib, X11
or whatever). However, e.g. for X11, plot_pixel() just puts the pixel in
offscreen storage and actually flushes the buffer once a complete image
line was plotted (x coord == width-1) or some time elapses.
Now, the problem is that I do not render lines from left to right, one
at a time which breaks the simple update logic.
So, I would introduce a flush function which explicitly tells
the underlaying display routine to put some part on screen. For SVGAlib
this would be a no-op. This would require a trivial one-line patch
at two or three other positions where plot_pixel is used.
Nothing really complicated.
>> Do_Cooperate().
> other means of handling output will be gradually removed and replaced by a
Okay, but when should I call Do_Cooperate()? And what does the param
(int level) mean?
I always read something about "well documented" and "cleanly coded"
patches to POVRay, so please look at povray.cpp (!)
* FUNCTION
*   Do_Cooperate
* INPUT
* OUTPUT
* RETURNS
* AUTHOR
*   POV-Ray Team
* DESCRIPTION
* CHANGES
Sorry, but that's just [wasted] 312 bytes of source code telling
essentially nothing just make it harder to keep an overview.
[Don't want to start flame war and don't take that personally.]
> ways.
I'll check that.
>> Field_Render_Flag:
> televisions).
...and seems to do some sort of antialiasing?
I doubt it's worth the increased complexity for my patch, especially
as most people probably watch previews on their computer screen.
Maybe it can be added in the end.
...found in frame.h, struct istk_entry, struct istack_struct.
So, if I understand you correctly, then the object hit by the ray
is found on top of intersection stack (istk_entry.Object)
once the ray is completely traced?
- How can I get access to the stack head.
- What happens when the ray hits an object with 50% reflection?
  (Thus the color of the pixel is determined by 2 objects.)
  How can I tell looking at the stack?
The other point is that the algorithm would take most advantage if we
can determine (quickly) if all the rays in the complete 8x8 _BOX_ hit
the same object (without tracing the complete box). It's like shooting
a ray with a diameter > 0.
This way one can't leave out a horizontal 7 pixel thick cylinder which
could currently be completely missed.
How could one achieve that? It does not have to be 100% accurate,
meaning that false positives are allowed (i.e. if we traverse an object
with ior!=1).
Wolfgang
Date: 2 Feb 2003 07:25:33
Message: <3E3D0E3D.FFD75638@gmx.de>
> > if you can do this.
> in povlega.doc,
> POVRay goes GPL.
The thing Warp probably was trying to point out that there is no use in a
POV patch outside POV-Ray so the 'double licencing' is either not of any
use or tries to imply that POV-Ray with this patch can be distributed
under GPL which is not true.  It is very unlikely that POV-Ray will be
licenced under GPL anytime.
Another thing is that it would be more in the spirit of POV-Ray to make
the patch available without the necessity for a request.  Of course no one
forces you to publish your modifications at all but if you do they should
be freely available.
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 2 Feb 2003 07:56:20
Message: <3e3d1574@news.povray.org>
In article <3E3D0E3D.FFD75638@gmx.de> , Christoph Hormann
<offtopic>
In fact it will never be released under the GPL.  The GPL comes with a
political message that is not acceptable to all team members.  It certainly
isn't acceptable to me.
</offtopic>
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 2 Feb 2003 07:58:51
Message: <3e3d160a@news.povray.org>
No problem, I'm developing GPL software which can be downloaded by
anyone, so it is also "in my spirit" to make it available.
Just that it is highly experimental stuff...
So, I cleaned it up a bit.
The patch is available at
http://www.cip.physik.uni-muenchen.de/~wwieser/povray/
[Don't take the content of this "home page" seriously. Basically
SOMETHING had to be put there...]
Please note that it patches povray in a way that it will always
use my interpolated tracing -- no non-adaptive or adaptive tracing
unless you change the lines in povray.cpp.
Wolfgang
Date: 2 Feb 2003 08:10:26
Message: <3e3d18c2@news.povray.org>
In article <3e3d0765@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
Ah, but that is a platform specific problem.  So you should deal with
something like this in platform specific code and not add functions to
POV-Ray.  Just flush in plot_pixel or buffer calls to plot_pixel to flush
multiple pixels at once (in case you are concerned about performance).
> (int level) mean?
Look what the function does (it is really trivial) and then find out what
the macros inside do.  They are documented.
Well, guess how the code ended up in its current state ... you should really
think more about your argument before complaining.
It is there so it can be added when somebody finds the time.  You are free
to go through the whole source code and document everything if you want ;-)
No, it just "skips lines".  Read the documentation about this feature to
find out more.
Basically yes, check function Trace, variable Best_Intersection.
Beam tracing is not available in POV-Ray.
> with ior!=1).
Not at all in a ray-tracer.
    Thorsten
Date: 2 Feb 2003 10:20:10
Message: <3e3d372a@news.povray.org>
>> if you can do this.
  Your words seem to imply that your patched version of POV-Ray could be
published under the GNU GPL. As far as I know, that would be an outrageous
violation of the POV-Ray distribution license.
  If you didn't mean that, you should express yourself more clearly and
unambiguously.
Date: 2 Feb 2003 10:24:45
Message: <3e3d383c@news.povray.org>
  I suppose that it's because of the history of POV-Ray.
  Back when 2 megabytes of RAM was a whole lot of memory in high-end
home computers, keeping a whole image in memory was completely out of
question. Reusing the pixel values calculated during the mosaic preview
would mean that they would have to be stored on memory, which was unbearable
at that time (that's why POV-Ray only keeps a small buffer where it writes
the current pixels and then flushes it to the image file).
  With current computers there's no problem in keeping the whole image
in memory, so there's no such problem anymore. However, no-one has touched
that code since then, I suppose. :)
Date: 2 Feb 2003 10:36:44
Message: <3E3D3B0C.600ED6AA@gmx.de>
You have obviously never rendered a really large image...
Date: 2 Feb 2003 11:03:05
Message: <3e3d4138@news.povray.org>
>>> if you can do this.
> unambiguously.
As already pointed out, I meant that my code, when patched into POVRay
is covered by povlegal.doc, so no problem.
There is no way that I could change the license POVRay is covered by.
However, if somebody wants that, he may use the code of the patch
under the GPL (which in turn means that he is not using it together
with POVRay).
Or do you still see any problems?
Wolfgang
Date: 2 Feb 2003 11:19:09
Message: <3e3d44fc@news.povray.org>
IMO, this is impossible. Because refreshing the complete image is not
an option (it means 1.8Mb X11 network traffic for 800x600 at 32bpp) and
adding code on the platform specific side which keeps a list of modified
pixels, then calculates the minimum bounding box and then refreshing
adds really unneeded complexity. OTOH, adding a simple function which
tells the display that some lines (range y0..y1) are now completely
rendered would make things really easy.
>> (int level) mean?
Well, maybe we're talking of different source codes. Because for the
unix/linux/general source code, Do_Cooperate is essentially a no-op,
all info I can get is that there are 3 levels which differ on how
often they are called. No word about what they actually do or about
side effects, so I assume, there are none.
Unfortunately, I cannot test it because I have no windows box here.
It seems that calling it from time to time is sufficient, okay.
If I understood the innermost workings of POVRay, I may do that, yes.
BUT, in order to understand them, I need the comments... :)
Probably I'll add a desc for "level" in my patch.
>> with ior!=1).
Okay, I'll have a try on some other methods. One could test more than
the 4 edges of a block but use additionally 6 more along the left and
top side.
Would you please view and apply the following patch to POVRay,
in render.cpp:
/* NK phmap */
/* this function checks if 'object' is equal to 'parent' or is a child
 * of 'parent'
static int IsObjectInCSG(OBJECT *Object, OBJECT *parent)
  OBJECT *Sib;
  int found;
  if (Object == parent) return true;
  found = false;
  if(parent->Type & IS_COMPOUND_OBJECT)
    for (Sib = ((CSG *)parent)->Children; Sib != NULL; Sib = Sib->Sibling)
      if(IsObjectInCSG(Object, Sib))
-        found = true;
+        {  found = true;  break;  }
  return found;
IMO, there is no need to complete the for() loop once we set
found=true.
Wolfgang
Date: 2 Feb 2003 17:31:52
Message: <3e3d9c58@news.povray.org>
Thorsten Froehlich schrieb:
> <offtopic>
Which political message? Did I miss something?
Florian Pesth
Date: 2 Feb 2003 19:42:44
Message: <3e3dbb04@news.povray.org>
  I don't think you'll want a mosaic preview of a really large image
anyways?-)
Date: 2 Feb 2003 20:39:12
Message: <Xns9316D1EA064FDtomatimporg@204.213.191.226>
Christoph Hormann <chr### [at] gmxde> wrote in
news:3E3D3B0C.600ED6AA@gmx.de:
>>   image in memory, so there's no such problem anymore.
> Christoph
8192x8192*24bit color is only 200 MB. A 256MB simm is less than $100 US.
Date: 3 Feb 2003 05:10:22
Message: <clfs3vsmh2h0tr5g3qbq27lafk836kkjjc@4ax.com>
... when POST_PROCESS_PATCH is not applied yet ;-)
I use 3 computers for developing POV patches and one is portable 486 with 48
MB, just to be sure that neither memory or speed is wasted ;-)
ABX
Date: 3 Feb 2003 05:11:31
Message: <kvfs3vcjg54lpp2g0vaa3n7db5hl67n4ba@4ax.com>
On Sat, 01 Feb 2003 23:52:11 +0100, Wolfgang Wieser <wwi### [at] gmxde> wrote:
Sorry, that's not clear for me, is your addition supposed to be an final
output or just preview ?
ABX
Date: 3 Feb 2003 05:37:38
Message: <3E3E466E.D013EA1F@gmx.de>
> anyways?-)
I was not referring to the mosaic preview but to your statement:
I just want to make sure no one assumes this is correct per se.
BTW a reusable mosaic preview does not require the whole image in memory
but only up to 1/4 of it.
Date: 3 Feb 2003 05:44:39
Message: <35gs3voksgticmge4ruedmr1h46brgqmk5@4ax.com>
On Sun, 02 Feb 2003 12:56:04 +0100, Wolfgang Wieser <wwi### [at] gmxde> wrote:
Core code is not a patch. In principals it works as all raytracers. Raytracing
code and environment things are in core usually well isolated and do not
interfere. They exist for years and are well tested so you can be nearly sure
they are (perhaps not perfect but) well coded. The function/variable name
usually gives an answer what it does and quick search for this name gives an
answer when and why it is used.
Patches works otherwise. They are fresh, usually buggy in initial version and
developed by one person. They are developed for one state of core code and
therefore can be hard to port to other customized sources. All those
interested with your patch but working with own customized povray sources have
to solve set of conflicts between their patches and your. And that's why
"'well documented' and 'cleanly coded' patches" issue is so much important.
Look here http://megapov.inetart.net/manual/internals.html#markup
And all above does not mean I do not like comments. I also like well commented
sources to use for patching :-)
ABX
Date: 3 Feb 2003 08:02:29
Message: <3e3e6865$1@news.povray.org>
news:3e3d383c@news.povray.org...
If youre talking about the Radiosity Pretrace, this is done to "seed" the
rendering with some prestored ambient values. It is essential to getting a
good-quality radiosity rendering.
George Pantazopoulos
Date: 5 Feb 2003 14:11:27
Message: <3e4161de@news.povray.org>
Sorry if I was a bit confusing when using the word "preview".
I intend that the rendered/partly interpolated image is the final
image produced by POVRay. BUT you will most likely only use it as
feedback during design, most notably for animations (-> "animation
preview")
Because test-rendering animations always takes too long for me,
I want to try and implement something to achieve slightly less quality
in considerably less time.
Don't know how well it will work or how much savings that will
achieve. But do NOT use the patch I mentioned, it implements just
the first step and produces bad results.
BTW, I'll be VERY busy during the next 4 weeks, but come back
to that issue once I play around with POVRay again (i.e. some time
next month).
Wolfgang
Date: 5 Feb 2003 14:15:10
Message: <Xns931990D12B2D9tomatimporg@204.213.191.226>
ABX <abx### [at] abxartpl> wrote in
news:clfs3vsmh2h0tr5g3qbq27lafk836kkjjc@4ax.com:
True.
> with 48 MB, just to be sure that neither memory or speed is wasted ;-)
> ABX
My point was that times have changed.  I started using POV on a brand new
IBM 486 DX-2 66Mhz machine with 4MB of RAM.  Rendering anything at
8192x8192 would have been a feat.
I don't currently use mosaic since it does take longer.  If there was an
"option" to sacrifice memory for speed when using Mosaic then I would use
it all the time.  Leave the default setting to favor memory.  If it is
really a simple matter to provide Mosaic without a speed penalty then it is
at least worth considering as an option.
Date: 5 Feb 2003 14:49:11
Message: <3e416ab6@news.povray.org>
> next month).
And...
If somebody has a great idea for such an algorithm (deciding what to
render and what to interpolate in which way so that it saves a lot
of rendering time and does degrade quality only just a little) but
does not want to code it (or has no time), feel free to share your
ideas. If it sounds promising it's likely that I'll give it a try.
(Any working patch will be made public by me, of course.)
Wolfgang
Date: 6 Feb 2003 04:17:07
Message: <3E422B08.8070001@alphalink.com.au>
>> <offtopic>
>> certainly
The GPL as a set of rules and requirements is certainly a product or an
expression of a particular political belief, but by that alone you could
not claim that it has any more political message than a license that is
the product of a different political belief. However, the GPL goes
further than simply stating rules and requirements, from the preamble:
"The licenses for most software are designed to take away your freedom
to share and change it."
and also:
"Finally, any free program is threatened constantly by software patents."
are indicative of the general tone of that section. I do not have any
problems with the GPL as a license, but I can see that some people
would. I do have problems with some of the things that Richard Stallman
says, but these sentiments are not explicitly embodied within the GPL.
I don't see anything particularly political about the content of the
section "TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND
MODIFICATION". Certainly the particular rules may be unpalatable to some
people, but they are nothing more than rules.
I would be curious to know what it is in particular that team members
object to in the GPL, and wheather they may at some stage consider some
other OSI approved license.
Date: 6 Feb 2003 14:15:58
Message: <3e42b46e@news.povray.org>
In article <3E4### [at] alphalinkcomau> , Edward Coffey
The whole idea of the FSF and thus the GPL is to turn software development
and ownership of software into some kind of communism.  It seeks to strip an
elite group (programmers) from the right to make money from their creative
work and sole right to their work.  Instead the masses of uneducated wannabe
programmers are allowed to screw up the programs.
If that isn't political...
    Thorsten
e-mail: tho### [at] trfde
Date: 6 Feb 2003 20:08:40
Message: <3E430A0F.7090400@alphalink.com.au>
This is where my view differs from yours. Remove the phrase "and thus
the GPL" and I completely agree with that statement. The GPL is just
saying "I'll let you have the source code for this, but only if you do
likewise for anything you use the source in, if you don't like that,
feel free not to use the source in your program". It never claims to be
the one true license, the FSF does that. Certainly, the GPL does embody
some aspects of a certain political belief, but I don't think that means
that it is a political document in and of itself.
Again, I think this can be attributed to the FSF, but not specifically
the GPL, unless you are tarring all open-source licenses with the one
brush here. Any license which allows the users to redistribute the
software is obviously going to cut down on the authors revenue, but it
in no way strips the author of the right to choose different licenses
for different pieces of software (of course, the FSF does).
So the "bazaar" can't work, only the "cathedral" is acceptable? What
particular GPL licensed programs are you referring to, and in what way
are they screwed up? I don't see the Linux kernel as being particularly
screwed up. Sure, there are many patched versions vying for distributor
attention, indeed there are 11 different kernels on offer at the
www.kernel.org frontpage alone. But everyone knows that the canonical
stable release at the moment is 2.4.20, maintained by Marcelo, directly
appointed by Linus.
Date: 8 Feb 2003 17:52:56
Message: <3e458a47@news.povray.org>
Sorry, but your calculation seems to be correct.
POVRay internally stores the image (pixels, scan lines) as COLOUR and
converts them to RGB only for writing them to disk (or displaying).
All the code uses COLOUR. And that would require 1280MB of RAM for
a 8192x8192 image. The 200Mb are needed additionally for the pixmap
buffer...   [sizeof(COLOUR)=4*5=20]
So, how much is a 2Gb simm :p
Wolfgang
