I'm working on some C code that generates radiosity sample data. I want to
have more than 1600 samples available. I have posted an image at pbi that
I'm referring to in this post.
Firstly, this piece of code creates a random distribution on a sphere
(without bunches near the pole):
/*---------code snippet----------*/
#define RANDOMVALUE ((float)rand()/(float)(RAND_MAX))
for (i = 0; i < SAMPLESAMOUNT; i1++) {
float costheta = RANDOMVALUE*2-1; // -1 <= costheta <= 1
float phi = 2 * PI * RANDOMVALUE; // 0 <= phi <= 2*pi
float squareroot = sqrt(1-costheta*costheta);
x[i1] = cos(phi) * squareroot;
y[i1] = sin(phi) * squareroot;
z[i1] = costheta;
/*----------end of code snippet-------*/
Secondly I have some code that moves the samples a bit around in order to
divide the samples more evenly. This way there won't be local gaps or
bunches in the distribution. The resulting distribution is visible in the
upper row (part A and B at pbi).
After that I have moved the samples again with this piece of code:
/*----------code snippet---------*/
for (i = 0; i < SAMPLESAMOUNT; i++) {
float phi = .5 * PI;
float theta = .5 * PI;
float q = sqrt(x[i]*x[i]+y[i]*y[i]);
if (x[i1] != 0) { phi = atan(y[i1]/x[i]); }
if (x[i1] < 0) { phi = PI + alpha; }
if (q != 0) { theta = atan(z[i]/q); }
theta = PI*.5*sqrt(theta/(PI*.5)); //this line actually moves the
samples
x[i] = cos(phi)*cos(theta);
y[i] = sin(phi)*cos(theta);
z[i] = sin(theta);
/*----------end of code snippet--------*/
Finally I order the samples and write them to disk (see C and D in the image
at pbi). By ordering them, the set also is distributed the right way when
only the first few samples are being used. (Think of count 35 etc etc etc.)
Additional graphs:
E: statistical data derived from the 1600 samples from POV-Ray 3.5
F: the properties of the data generated by my code.
And now my question:
IS MY DISTRIBUTION CORRECT?
I'm wondering this because the pink line (x*x+z*z) in part E of the picture
isn't completely straight. Especially the second half at the upper right
(sample 1000 and higher) is bent.
Apache
Subject: Re: >1600 radiosity samples: right costheta distribution?
Date: 4 Jan 2003 05:04:34
Message: <3E16B1B2.B3B1CBB9@gmx.de>
First of all there is no 'correct' distribution, you can only try to
measure the quality of your sample set and compare it to others. One
measurement of quality would be to measure the distance of each point to
its nearest neighbor - if this is very similar for all samples the
distribution is quite good (a non uniform distribution is more difficult
of course).
The images in p.b.i don't tell much. First of all the side views don't
hide the back side so you can't see how evenly the samples are
distributed. The 'A' picture looks quite good but a view from above does
not tell that much. Also i don't understand the diagrams at all, what do
they show?
BTW 'cos theta' distribution means the density of samples is proportional
to the angle to the normal vector. This will result in a quite uniform
appearance when viewed from above. Your 'C' sample does not look like
that.
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 4 Jan 2003 05:16:55
Message: <3e16b497$1@news.povray.org>
Doesn't really matter anymore, because I'm already pretty sure that the
thing works correctly. I'll post a new rad_data.cpp with a larger set of
samples shortly.
Date: 4 Jan 2003 07:05:48
Message: <3e16ce1c@news.povray.org>
I think the C distribution does not correspond to the existing rad_data. If
you want to verify, take your 1600 samples, compute their theta, and draw a
frequency graph
You can try this :
create a regular distribution in a disc, move your points evenly (how to you
do that part by the way ?), then just project the disc on the hemisphere,
and voila
M
Date: 4 Jan 2003 10:09:26
Message: <3e16f926@news.povray.org>
Maybe this might interest you : 2 years ago, Stephane Marty (who
created Virtualight) issued a POV-Ray patch whoch allowed users
to select amongst 8 samples distribution shemes for radiosity.
http://perso.wanadoo.fr/albedo/patchedpov.html
If you download and read the HTML docs, you will see samples
of the availiable distributions.
Fabien.
Date: 4 Jan 2003 10:21:22
Message: <3e16fbf2@news.povray.org>
Probably coincidence but 1st glance at "C" reminded me of the spirals
you get in the Golden-Ratio involving (sqrt(5)-1)/2.
Alf
Date: 4 Jan 2003 12:07:27
Message: <3e1714cf$1@news.povray.org>
"Apache" <apa### [at] yahoo com> wrote...
[clip]
etc.)
The code you posted looks like it is on the order of O(n), unless the code
you posted is missing a "for" loop (maybe on the variable "i1"). I would
have expected the code that "moves the samples a bit around in order to
divide the samples more evenly" to be at least O(n^2).
If it realy is O(n), which would be great, couldn't you simply generate an
appropriate distribution each time, removing the need to order them. If the
algorithm produces evenly spaced samples for small counts, this would also
ensure that small sample counts look their best.
-Nathan
Date: 4 Jan 2003 12:28:29
Message: <3e1719bd@news.povray.org>
The cod that I posted is O(n), and the code that "moves the samples a bit
around" is O(n^2) indeed. And so is the code that orders the stuff. However,
I'm still trying to get a better ordering. Or I could precalculate tons of
sets for count 1, count 2, ..., count 3199, count 3200. It takes some time
and space, but renderings with low counts will have less artifacts then.
Let's say that a*quality+b*resources-c=0 :-)
Date: 4 Jan 2003 12:32:30
Message: <3e171aae$1@news.povray.org>
Oh, that won't work out as I thought is would, because in many cases
POV-Ray doesn't use as much samples as it is told to do with count when
there are more errors allowed. So every set has to be ordered anyhow. But I
still think that seperate sets can decrease artifacts.
Date: 4 Jan 2003 12:41:54
Message: <3e171ce2$1@news.povray.org>
I was thinking the same.
Date: 4 Jan 2003 12:44:50
Message: <3e171d92$1@news.povray.org>
Projecting the disk onto the hemisphere requires "blowing up" the set of
samples in order to prevent samples "sticking" nearby the edge of the
sphere/disk. The surface near the center of the disk grows more than the
surface near the edge, so near the center the samples move farther away.
That results in an uneven distribution.
Date: 4 Jan 2003 12:46:25
Message: <3e171df1@news.povray.org>
When viewed from above (+z), a cos theta distribution should look like
uniformly spaced points on a disc. (This isn't hard to show with a little
math.) But neither of your +z views look that way.
Anders
#macro E(D)(#if(D<2)D#else#declare I=I+1;mod(pow(.5mod(I 6))*asc(substr(
"X0(1X([\\&Q@TV'YDGU`3F(-V[6Y4aL4XFUTD#N#F8\\A+F1BFO4`#bJN61EM8PFSbFA?C"
I/6 1))2)<1#end)#end#macro R(D,I,T,X,Y)#if(E(D))R(D-1I,T,Y/2X)R(D-1I,T+Y
/2Y/2X)#else box{T T+X+Y pigment{rgb E(2)*9}}#end#end R(10,5z*3-1v*2u*2)
Date: 4 Jan 2003 12:52:20
Message: <3e171f54@news.povray.org>
I'm not sure your understood the projection
sample points evenly on disc (x,y)
then build (x,y,z) with same x,y and z=sqrt(x*x+y*y)
(and we do want an uneven distribution with more points near the center)
M
Date: 4 Jan 2003 12:52:29
Message: <3e171f5d$1@news.povray.org>
The set that POV-Ray uses currently doesn't look like that either. (see my
post, pbi "Re: >1600 radiosity samples: right costheta distribution?"). "My"
distribution has very similar properties to that of POV-Ray, except for the
ordering that I still have to fix.
Date: 4 Jan 2003 13:17:44
Message: <3E172548.FE1C1706@gmx.de>
You are obviously doing something wrong, i just rendered it and it look
totally different here (it looks indeed uniform although not extremly high
quality).
Date: 4 Jan 2003 13:19:05
Message: <3e172599@news.povray.org>
I'm nuts ....... I rerendered it and it turned out to be some perspective
distortion :-)
"Apache" <apa### [at] yahoo com> wrote in
news:3e16ad01$1@news.povray.org
Maybe just make a scene that needs >1600 samples, build i.e. 5000 samples
array, re-compile POV and make few renders involwing old and new
distribution
"Nathan Kopp" <pov### [at] nkopp mailshell com> wrote in
news:3e1714cf$1@news.povray.org
> generate an appropriate distribution each time, removing the need to
> order them. If the algorithm produces evenly spaced samples for small
> counts, this would also ensure that small sample counts look their
> best.
Why not generate array of arrays ?
array for count=3, count=4, count=5 etc... ?
taht would be much faster then generating in real-time, and will not use to
much memory
Date: 4 Jan 2003 15:31:31
Message: <3e1744a3$1@news.povray.org>
to
> much memory
Uh, it won't? Just the tables for up to 1600 samples would require 3.7 MB in
packed format, and we want to go well beyond that!
Anders
Date: 4 Jan 2003 17:54:02
Message: <3e17660a$1@news.povray.org>
And that's exactly what I'm planning on.
Date: 5 Jan 2003 00:28:53
Message: <3e17c295@news.povray.org>
That's exactly what came to my mind, too.
I tweaked my old sunflower-testscene to generate the points on
a hemisphere like Mael described in his post.
I quite like how it came out. It looks evenly distributed when viewed
from above with orthographic view and it scales good with increasing
number of points.
I posted the anims in p.b.a
comments are welcome,
Thies
Date: 5 Jan 2003 06:14:02
Message: <3e18137a$1@news.povray.org>
My box is currently calculating a set of 6400 samples. It seems it will take
quite some time, but whenever it's finished, I'll let you know.
The ordering is very good, so with very low samples the distribution is very
good. If the count is set to 6400, the distribution is equal to the golden
ration distribution. (See Thies Heidecke's post in this conversation.)
Apache
Date: 5 Jan 2003 06:29:22
Message: <3E181712.681F60D1@gmx.de>
You should note that this is a regular distribution, therefore will be
likely to generate regular artefacts under certain circumstances. Using
regular distributions has been tried before, see for example:
Date: 5 Jan 2003 08:34:21
Message: <3e18345d$1@news.povray.org>
I found out the distribution isn't as good as I thought. I think the problem
is in the ordering, which is more complicated than I had expected ;-)
"Anders K." <and### [at] kaseorg com> wrote in
news:3e1744a3$1@news.povray.org
>> much memory
> MB in packed format, and we want to go well beyond that!
MB or KB ? I thought that each record is 3 doubles ?
3*4*8*1600 = 150 kB
3*4*8*1600*1600/2 = 117 MB for array like :
(x), // count=1
(x,x), // count=2
(x,x,x), // count=3
(x,x,x,x,x.....) // count = 1600
117 MB is too big in fact... so maybe generate only support every 10-th
copunt above 300 ?
so count can be : 1,2,3...299,300, 310,320,330...
and every 20-th >600 600,620,640...
in that way array for count=3000 could be about hmm 50 MB i estimate ?
It can be downloaded as separate file from ftp://
Date: 5 Jan 2003 19:02:44
Message: <3e18c7a4@news.povray.org>
I don't feel quite comfortable with the program taking so much memory
just for a huge table.
Perhaps a better (and more memory-saving) method should be developed?
Date: 6 Jan 2003 04:23:29
Message: <3e194b11$1@news.povray.org>
hmm sorry, the correct is z=sqrt(1-x*x-y*y)
I tried it for the halton distribution (see on
http://195.221.122.126/samples/samples.html)
M
Warp <war### [at] tag povray org> wrote in news:3e18c7a4@news.povray.org
How about allowing only some fixed count numbers, like :
1..50 increment by 1 - 1,2,3
50..100 inc by 10 - 50,60,70
100,300 inc by 20
300..1000 inc by 50
1000..5000 inc by 200
Date: 6 Jan 2003 08:35:57
Message: <3e19863d@news.povray.org>
That sounds more like a kludge than a solution. :)
I was thinking more like storing only some of the points and interpolating
the rest on the fly or whatever.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
Warp <war### [at] tag povray org> wrote in news:3e19863d@news.povray.org
but why :) ? I realy doubt if someone will see difference beetween
1043 and 1044 conut...
> of course).
I do not think that would be a good measurement. In the following
example, the distance to the nearest neighbour is EQUAL for all points
(it is always 1 because the points are paired), while I expect you to
agree
that this is not a good distribution. (The example fills a rectangle,
not a
hemisphere, but that is irrelevant.)
Even if you ,,disallow'' the unevenness depicted here, you are bound
to get grid artefacts, which can be a real killer, if the sample grid
interacts with some object grid in the scene in a moir'e way.
Proposal for quality measurement: Density. Given a subset A of the
space you want to fill, the density is the quotient of the number of
samples inside A and the size (here: area) of A. The density should
not differ much for different A. As we intend a discrete distribution,
we have to restrict the quality measurement to A of a suitable minimum
size.
Mark
Date: 10 Jan 2003 05:30:38
Message: <3E1EA0CD.ACEF6B4D@gmx.de>
> > of course).
> agree
> not a
You are right, this is not a very good measurement. None the less with
some change it is suited for comparing distributions. From all
distributions with N points the one with the largest minimum distance
between two points could be considered as the best.
A different measurement would be calculating the sum of the inverse
distances of every point to all other points. All this sums together
should be low for a good distribution.
> size.
The problem is that this would not detect anisotropy.
One important point about radiosity sampling is that the mathematically
best distribution is not necessarily the best for high quality radiosity
results. As you already mentioned regularity artefacts are a major
problem. The halton distribution Mael implemented seems to work quite
well at high count values although it is surely not the best in terms of
mathematical quality measurements.
Without having tried I would suspect this to favor grids.
Another aspect are boundary effects. Take, for simplicity, a
one-dimensional
example: 4 points in the unit interval. In the optimum one point will be
at 0
and another at one. Because of symmetry the other two will be at x and
1-x.
The function you want to minimze then is 4/x+4/(1-x)+2/(1-2x). The
optimum
due to common sense is x=1/3 while this does not minimize the function:
Its derivative at 1/3 is 9, while it would be 0 at the minimum.
This does not matter though, if the distribution is calculated on a
boundary-less space, such as a torus, and then mapped to the space we
are interested in.
What is anisotropy?
Mark
Date: 6 Feb 2003 08:34:01
Message: <3e426449$1@news.povray.org>
Ive done such tables in my renderer, storing normal coordinates in float format (not
the double).
Made tables from 4 (4x4) to 32 (32x32) [ as you can see Ive iterated through N
generating NxN samples) and it occupies much less
space
Tabulated ray directions were calculated by computer simulated annealing.
A few variants of distributions: uniform, pure cosine and a few variants of
degenerated BRDFs.
Each variant occupies something like 140KB for full series of samples 4x4, 5x5,...
32x32.
Samples were distributed perfectly, leaving some place to add some noise ("perfect"
Poisson discs).
There is really no need for having tables for 4,5,6,7,8.....4096 samples, just because
from Monte Carlo theorem of reconstruction 2-times increase in samples lowers the
noise sqrt(2).
