POV-Ray : Newsgroups : povray.programming : About Intersection points Server Time
9 Oct 2026 21:18:59 EDT (-0400)
  About Intersection points (Message 1 to 17 of 17)
Subject: About Intersection points
Date: 7 Nov 2002 23:26:00
Message: <3dcb3cd8$1@news.povray.org>
Hi, all
    I want to get the (x,y,z) values of all Intersection points. The
following is what I added into the Intersect_Mesh() function in mesh.cpp
file:
    found = intersect_bbox_tree(Mesh, &New_Ray, Ray, len, Depth_Stack);
// return(intersect_bbox_tree(Mesh, &New_Ray, Ray, len, Depth_Stack));
  if (found == true)
   ofstream output;
   output.open("C:\\Documents and Settings\\Wu Yang.WORK\\My
Documents\\project\\out.dat",ios::out|ios::app);
   if (Ray->Initial[0] == 20)
    output << Ray->Initial[0] << " " << Ray->Initial[1] << " " <<
Ray->Initial[2] << " "
     << Mesh->Data->Vertices[0][0] << " " << Mesh->Data->Vertices[0][1] << "
" << Mesh->Data->Vertices[0][2] << " "
     << Mesh->Data->Vertices[1][0] << " " << Mesh->Data->Vertices[1][1] << "
" << Mesh->Data->Vertices[1][2] << " "
     << Mesh->Data->Vertices[2][0] << " " << Mesh->Data->Vertices[2][1] << "
" << Mesh->Data->Vertices[2][2] << " ";
    output.close();
    Is it right?
Thanks a lot
Wu Yang
Subject: Re: About Intersection points
Date: 8 Nov 2002 00:06:03
Message: <chrishuff-487836.00060008112002@netplex.aussie.org>
In article <3dcb3cd8$1@news.povray.org>,
> file:
>   if (found == true)
>    ofstream output;
>     output.close();
>     Is it right?
Well, this only affects meshes, it won't give you all intersections,
only mesh intersections. You open and close the file for every
intersection, this is going to be slow. You also don't return the value
you put in "found", you need to do that. And finally, you never touch
the intersection point information, you write out the ray origin and
triangle vertices. Your messages haven't been very clear in the past,
maybe this is what you really want, but the "intersection point" is
where the ray hits the object, the "origin" is where it the ray comes
from ("Initial" in the ray struct).
http://tag.povray.org/
Date: 8 Nov 2002 01:00:24
Message: <3dcb52f8$1@news.povray.org>
Thank you for your reply.
Which variable represent the intersection point? Thanks
Best Regards
Wu Yang
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> > file:
> >   if (found == true)
> >    ofstream output;
> >     output.close();
> >     Is it right?
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
Date: 8 Nov 2002 01:28:56
Message: <3dcb59a8$1@news.povray.org>
Another question,
Is the triangle I write out the triangle hitted by the ray? Thanks
Best Regards
Wu Yang
> > file:
> >   if (found == true)
> >    ofstream output;
> >     output.close();
> >     Is it right?
Date: 8 Nov 2002 09:32:52
Message: <chrishuff-894025.09325208112002@netplex.aussie.org>
In article <3dcb59a8$1@news.povray.org>,
> Another question,
Why would it be? You always write out the same vertices. The way you are
doing it, they might not even belong to the same triangle. Do you
understand the code you wrote at all?
You really don't seem to know C or C++, I strongly suggest you find a
good C++ book and read it. Look in povray.off-topic, there is a
discussion going on right now about good C++ books.
Date: 8 Nov 2002 10:03:08
Message: <chrishuff-BE9AFB.10030708112002@netplex.aussie.org>
In article <3dcb52f8$1@news.povray.org>,
Depth_Stack holds this information for all the intersections with the
ray.
Date: 8 Nov 2002 10:47:55
Message: <3dcbdcab@news.povray.org>
Is Depth_Stack->istack->IPoint the (x,y,z) value of a intersection point?
Thanks
Best Regards
Wu Yang
> ray.
Date: 8 Nov 2002 12:12:07
Message: <chrishuff-2B8D34.12115808112002@netplex.aussie.org>
In article <3dcbdcab@news.povray.org>, "Wu Yang" <wya### [at] cswrightedu>
It is one of them, if there are any on the stack. (What else would it
be?)
Date: 8 Nov 2002 15:29:25
Message: <3dcc1ea5@news.povray.org>
I think there are maybe more than or less than one intersection point in the
stack, and they are the intersection points with the same ray, and what I
need is Best_Intersection->IPoint in Trace() function(render.cpp file). Is
it right? Thanks.
Best Regard
Wu Yang
point?
> be?)
Date: 8 Nov 2002 15:59:33
Message: <chrishuff-8B5451.15592408112002@netplex.aussie.org>
In article <3dcc1ea5@news.povray.org>, "Wu Yang" <wya### [at] cswrightedu>
> it right? Thanks.
What you need is to buy and read a good C++ book or take a good course
in C++, and then take the time to actually figure out what the POV-Ray
source code does before trying to make any changes.
If you then have a problem, state the entire problem and your goal
clearly at the very start, not some useless "is it right" garbage that
keeps everyone guessing as to what you are really doing. There really is
a category of "stupid" questions, and most of yours fit in it...you
could most likely easily figure out the answer yourself, if you knew the
language the source code is written in.
And finally, *READ THE REPLIES*. I don't know why some people just
ignore it when people give them the answer, or worse, ignore the answer
and go off on a wild goose chase...
Now: where is Trace() defined? What does that code say it does? It says
nothing about meshes, does it? The Trace() function is called to compute
the color seen along a ray, adding this code there won't catch all
intersection tests, but it will catch any kind of intersection, not just
ones with meshes. I can't tell you how to do it, because you haven't
said *what* you are trying to do, or what your goal is.
Date: 8 Nov 2002 16:17:27
Message: <3dcc29e7@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote:
> There really is
  There's a saying that says "there are no stupid questions".
  Of course this saying has a more figurative meaning than literal meaning.
It means that each person asks questions in the best way they can, according
to their knowledge and experience, and it's important to understand that.
  From the point of view of a very experienced person, a question made by
an extremely inexperienced one might sound trivial or even stupid, but one
has to understand who is making the question - a complete newbie - and avoid
feeling sense of superiority and disrespect.
  Of course it might be that the person who has a rather big goal for his
experience and is asking these newbie questions does not seem to listen
to even the most benevolent answers, given with the best intentions, and
that may sometimes be very irritating, but still we should continue
understanding the position of such person: Without the necessary experience
he is struggling with the problems he is finding and probably very confused
about everything.
  The worst thing we can do in a situation like this is disrespecting this
kind of person. We should try to help in any way we can.
  (I know, I have been guilty of this kind of disrespect as well, but I'm
trying to learn my lesson...)
Date: 8 Nov 2002 21:07:13
Message: <3dcc6dd1$1@news.povray.org>
What I want is all the intersection points hitted firstly by the ray, not
just those with the mesh object. The reason I found it in mesh.cpp is that
the object I designed is only made up by mesh object. Yes, Trace() function
is called to compute the color seen along the ray, but there is a variable
called Best_Intersection and I think this variable is the intersection point
I want.
I really appreciate for all of your replies, your replies are very very
helpful to me. Maybe sometimes I can not express my question very clearly
and make you feel a little boring. Sorry about that. I will try my best to
make my question more clearly. Thanks a lot.
Best Regards
Wu Yang
the
I
Is
> > it right? Thanks.
Date: 8 Nov 2002 22:01:54
Message: <chrishuff-6D3036.22014508112002@netplex.aussie.org>
In article <3dcc6dd1$1@news.povray.org>,
By which rays? Every single intersection test ever made by the tracer
while rendering, or just the ones from the camera?
> The reason I found it in mesh.cpp is that the object I designed is
> only made up by mesh object. Yes, Trace() function is called to
> compute the color seen along the ray, but there is a variable called
> I want.
It is the nearest intersection Trace() finds. However, because Trace()
is used to compute the color, there will be intersection tests that do
not reach your code, because they don't call Trace(). I think Trace() is
only used for the primary camera rays, reflected rays, and refracted
rays, not for the trace() language function, shadow rays, or anything
else that needs to trace a ray but doesn't need to compute the color
seen along it. I don't know what you want to do with the data, so I
can't make any better suggestions. If you would just tell us what you
are doing, you would get much better help.
Boring isn't the right term, "frustrating" is better. Trying to figure
out what you want from vaguely worded questions and trying to understand
why you are modifying these odd places in the code, especially when you
ignore repeated questions about what you are trying to do.
Date: 9 Nov 2002 01:20:55
Message: <3dcca947@news.povray.org>
I want to compute the distance between the camera and the intersection
points made by camera rays and objects.
Best Regard
Wu Yang
not
> > I want.
clearly
to
Date: 9 Nov 2002 12:24:27
Message: <chrishuff-B89E79.12242009112002@netplex.aussie.org>
In article <3dcca947@news.povray.org>, "Wu Yang" <wya### [at] cswrightedu>
If you don't need POV 3.5 and can take the data in the form of an image,
MegaPOV had a "depth" post process filter. You can also do tricks with
fog or textures to get a depth buffer. Use black textures and white fog,
so things get white with distance (or white textures and black fog, for
the opposite gradient), or texture everything with a spherical texture
centered on the camera and scaled large enough to contain the scene.
Otherwise:
Trace_Primary_Ray() in vbuffer.cpp and Trace() in render.cpp both return
the distance to the nearest intersection if there is one, or BOUND_HUGE
if there wasn't one. Look at the trace_pixel() function, you need to
save the results of Trace_Primary_Ray() and Trace().
If you can use depth data in an image and don't need the rendered image,
you could put the depth values in the rendered image by changing Color,
but it would be better to modify those two functions to skip the texture
and atmosphere calculations instead, it would be much faster rendering.
This won't work with focal blur, that would be a bit more work, but
probably isn't needed. You would have to decide what kind of depth
information you wanted there: minimum, maximum, midpoint of those,
average...
Date: 9 Nov 2002 12:52:44
Message: <1fldsiy.vlk33wyvge0cN%cassio@free.fr>
> in C++,
Please excuse my ignorance, but what is C++ ?
Stephane
Date: 9 Nov 2002 13:04:22
Message: <chrishuff-8EE04E.13041609112002@netplex.aussie.org>
In article <1fldsiy.vlk33wyvge0cN%cassio@free.fr>,
It's the language POV is written in. An extended version of C,
basically, but I don't know how much that means to you...if you don't
know what C++ is, you probably don't know what C is. If you want to
patch POV, you have to have at least a good grasp of C, C++ would be
better.
