POV-Ray : Newsgroups : povray.programming : How do I use the new INI and command line option system in POVRay 3.5? Server Time
9 Oct 2026 21:18:42 EDT (-0400)
  How do I use the new INI and command line option system in POVRay 3.5? (Message 1 to 5 of 5)
Subject: How do I use the new INI and command line option system in POVRay 3.5?
Date: 23 Oct 2002 21:00:29
Message: <3db7462c@news.povray.org>
After waiting over 24 hours with no response, I'm trying again.
I am hacking the old PVMPOV patch for POVRay 3.1 to POVRay 3.5.  There
appears that there is a large change in the way INI and command line
options set the underlying variables.
Does anyone have any pointers or examples?  The documentation for it is
nonexistant (afaik).
Thanks
Lee Begg
Subject: Re: How do I use the new INI and command line option system in POVRay 3.5?
Date: 24 Oct 2002 04:44:42
Message: <3db7b2fa@news.povray.org>
In article <3db7462c@news.povray.org> , Lee Begg <lln### [at] paradisenetnz>
Like all other parts of the POV-Ray source code, you have to go through it
and find out yourself.
    Thorsten
e-mail: tho### [at] trfde
Date: 24 Oct 2002 05:17:58
Message: <3db7bac0@news.povray.org>
That is what I have been doing.  There is no central place of this code... I
think I see bits of it across atleast 5 files.
I guess I will muddle though it... but I would have thought that either the
POVRay developers would be helpful, or atleast some patch developers might
expalain how they when about it.
>     Thorsten
What do you do in terms of POVRay development?  Are you upset because you
are in the same boat (trying to figure out what to do with only the code to
help?)
Regards
Lee
Date: 24 Oct 2002 06:07:38
Message: <3db7c66a@news.povray.org>
In article <3db7bac0@news.povray.org> , Lee Begg <lln### [at] paradisenetnz>
Not really.  There is a structure to it.  First you add a new kPOVAttrib_xxx
constant in povmsgid.h, then you enter the constant and its option names in
either or both of the tables Ini_Parser_Tab and/or Cmd_Parser_Table, where
as you may guess from the existing order, order matters.  Unless you need
kUseSpecialHandler optin.cpp will then do the parsing for you.  Now you only
have to receive the message in povmsrec.cpp and turn it into the internal
state.  To be able to send the data, extract it from the internal state in
povmsend.cpp .  That is all.
Well, as the whole code is not documented, that is how it works when
"learning" POV-Ray.
> help?)
No, I wrote that code :-)  There are many places that are not documented,
not just this part (also this part is documented, just not publicly).  One
just has to get used to it.  And occasionally a change may break something
else.  One gets over this setback and fixes the problem; and moves on.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 24 Oct 2002 07:22:47
Message: <3db7d801@news.povray.org>
>> code... I think I see bits of it across atleast 5 files.
> kPOVAttrib_xxx constant in povmsgid.h, then you enter the constant and its
> option names in either or both of the tables Ini_Parser_Tab and/or
> only have to receive the message in povmsrec.cpp and turn it into the
> internal
Thanks.
That was exact what I was after.
>> the POVRay developers would be helpful, or atleast some patch developers
>> might expalain how they when about it.
> "learning" POV-Ray.
>> to help?)
Well... I guess I should be a bit more careful with my code (across 3 open
source products)  :-)
I can understand that.  Perhaps there should be a page on the website with
gems like this one.
>     Thorsten
Thanks again.
Expect a PVMPOV patch in the next week or so  :-)
Later
Lee Begg
