POV-Ray : Newsgroups : povray.programming : how to write the reflected ray to a file? Server Time
9 Oct 2026 21:18:44 EDT (-0400)
  how to write the reflected ray to a file? (Message 1 to 4 of 4)
Subject: how to write the reflected ray to a file?
Date: 10 Oct 2002 13:46:46
Message: <3da5bd06$1@news.povray.org>
Hi, all
   I want to write the reflected ray to a file and I tried to cout the
New_Ray to the screen by adding "cout << New_Ray.Direction;" into the
Reflect() function and rebuild the project. But it is no use. When I execute
the pvengine.exe, nothing appears on the screen. Could you please give me
some advice about how to write the reflected ray to a file.
Thanks a lot
Best Regard
Wu Yang
Subject: Re: how to write the reflected ray to a file?
Date: 10 Oct 2002 14:01:21
Message: <3DA5C14B.6000206@starman.ee>
Wu Yang wrote:
> Hi, all
If you want to write to file, then write to file :-)
If you write to standard output, then it could not be seen (at least
with pvengine.exe), as it is Windows application and Windows
applications usually do not display text, written to standard output.
So you have to create ofstream to write to file.
Other possibility is to redirect standard output to file. For this start
pvengine from command line as follows:
pvengine.exe 1>output
this will redirect all text, written to standard output stream, to file
output.
Date: 10 Oct 2002 14:26:29
Message: <3da5c655$1@news.povray.org>
Thanks a lot
Wu
"Vahur Krouverk" <vkr### [at] starmanee> wrote in message
news:3DA### [at] starmanee...
> Wu Yang wrote:
> > Hi, all
execute
me
> output.
Date: 10 Oct 2002 17:18:25
Message: <Xns92A3ECD796A48raf256com@204.213.191.226>
Vahur Krouverk <vkr### [at] starmanee> wrote in
in witch place should i put to open() and close() file ?
(I want some code run after start rendering, and after aborting/finishing
it)
