Subject: How to Build a GUI Extension to POV-Ray for Windows.
Date: 31 Jul 2002 20:46:17
Message: <3d4884d9$1@news.povray.org>
After a long break, I have started banging my head against the wall trying
to do this. At least this time I think I am making progress. I can at
least compile now without errors and only a hundred or so warnings. I have
been taking notes as I have been going along and I am posting them to here
as I go:
http://www.imp.org/visitors/guiext/cookbook.asp
Any comments, tips, or hints will be much appreciated.
Thanks
Tom
Subject: Re: How to Build a GUI Extension to POV-Ray for Windows.
Date: 1 Aug 2002 12:12:16
Message: <3d495de0$1@news.povray.org>
When I get some time in the next couple of days, I'll try to follow your
cookbook and see how far I get. I'm wanting to write a GUIEXT Java API, but
hadn't had the time to even research where to begin. It may be a week or
two before I get to it, but I'll let you know how far I get following you.
#macro Q(A,E,W)box{-A/2,A/2pigment{rgb 9*W}translate E*A+W/1000}#end#macro
M(D,E)#local A=1/pow(3,D);#if(D<3)#local C=D+1;union{M(C,1)M(C,x+y)M(C,x+z)
M(C,y+z)M(C,x+y-z)M(C,x+z-y)M(C,y+z-x)M(C,x-y)M(C,z-x)M(C,y-z)M(C,y-x)M(C,
x-z)M(C,z-y)M( C,x-y-z)M(C,y-x-z)M(C,z-x-y)translate A*E}#else
Q(A,E,x)Q(A,E,y) Q(A,E,z)#end#end union{M(0,0)rotate<45,145,0>translate
z*2}//Andrew
Date: 1 Aug 2002 14:46:51
Message: <3D49823B.3080204@comtrade.ee>
> as I go:
Some tips for compiling POV-Ray (or more correctly, MegaPov) with
Borland's compiler could be found in thread 'free borland' in this very
same newsgroup, dated 2001-04-17. Perhaps it will help, although it's
not related to GUI Extensions.
Date: 1 Aug 2002 18:38:42
Message: <3d49b872$1@news.povray.org>
Ok, I'm following your cookbook, and so far so good. I haven't tried a
compile yet, but I got the Borland compiler, and the POV 3.5 source.
There's a type under "Installing POV Source" item number 5. It says:
Copy the file FRAME.H from C:\POVSRC to C:\MYGUIEXT
I think it should read.
Copy the file FRAME.H from C:\POVSRC\SOURCE to C:\MYGUIEXT
At least that's what it is for the 3.5 source.
x-z)M(C,z-y)M(C,x-y-z)M(C,y-x-z)M(C,z-x-y)translate A*E}#else Q(A,E,x)Q(A,E
,y)Q(A,E,z)#end#end union{M(0,0)rotate<45,145,0>translate z*2}//Andrew
Date: 2 Aug 2002 12:11:33
Message: <3d4aaf35@news.povray.org>
Ok, I got the guidemo.c compiled and installed into POV-Ray, pretty cool.
I used the following compile arguments with bcc32.exe
bcc32 -WD -O2 -Vx -Ve -X- -a8 -b- -k- -vi -tWD -tWM- -q -lD"" -laa -lTpd -lx
-lGn -lGi -eguiext.pge *.c
Which I got from this web page:
http://www.textpad.com/support/tips/borlandtip.html#dll
Then I modified the PVENGINE.INI file and added followling line. The
guiext.pge is just the temporary name I working under, I'll change it as per
the license agreement when I get to a release point.
ExtDll16=u:\source\com\unpuzzled\d3\guiext\guiext.pge
under the [GUIExtensions] header...
So the file ended up looking like this.
[GUIExtensions]
UseExtensions=1
ExtDll15=D:\Program Files\Moray For Windows\MorayCtrl.DLL
Started up POV and to my amazement there it was...
Now I just have to figure out how to implement what I really want it to
do...
Date: 3 Aug 2002 12:02:36
Message: <3d4bfe9c$1@news.povray.org>
"Andrew Wilcox" <awi### [at] unpuzzled com> wrote in message
news:3d4aaf35@news.povray.org...
<snip>
Wow! Thanks. I just started down playing with the compiler/linker switches
last night at
the airport. Lot's of activity, but little progress. I will update the the
instructions on the
web page this weekend with your findings.
> do...
I know! That problably will make the initial compile look like a walk in
the park.
Thanks
Tom
test post
I cannot do an (*Instance->Request)(RequestGetVars, &ExternalVars) ; in the
following method. I assume its because POV hasn't fully initialized Instance
yet. I need to know the Instance.HomePath so that I can read my .ini file
and initialize Instance.Enabled correctly.
What do I do?
Is there some place else I can set Enabled after POV has initialized the
DLL? Or do I just have to know the directory where POV is installed,
without being able to ask POV itself?
Thanks in advance,
Andrew Wilcox
"Tom Galvin" <tom### [at] dataforge nospam com> wrote in message
news:3d4884d9$1@news.povray.org...
Subject: Re: Trouble persisting Enabled state. Need Help.
Date: 5 Aug 2002 14:20:55
Message: <3d4ec207@news.povray.org>
news:3d4e8265$1@news.povray.org...
> What do I do?
You could ask windows for the path to your DLL. Or you could store the state in
the registry instead of an INI file (IMO this is the best choice, POV uses an
INI file because it predates Windows 9x ; you don't have to follow our example).
Alternatively you can look at HKCU\Software\POV-Ray\CurrentVersion\Windows\Home.
Note that v3.1 of POVWIN uses HKLM for this key. If both version are installed,
the HKLM one will point at v3.1, and the HKCU will point at v3.5. But there will
also be an entry in HKLM\Software\POV-Ray\v3.5\Windows\Home pointing at the v3.5
install (provided that the person who installed it had admin rights).
-- Chris
Date: 5 Aug 2002 15:31:06
Message: <3d4ed27a@news.povray.org>
Could I put in an HKCU\Software\POV-Ray\GUIEXT\<myguiext> key? Or should I
use a completely different path all together?
The registry would be easier to access anyway, than a file.
You should use a completely different path, like
HKCU\Software\<my (company) name>\<myguiext>
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 5 Aug 2002 23:38:15
Message: <3d4f44a7$1@news.povray.org>
news:3d49b872$1@news.povray.org...
I followed your advice for the compiler options and I was succesful in
getting it running!!! Yea!!!
With the 3.5 source FRAME.H is no longer required, but I updated the line
for 3.1 source.
I updated the cookbook with your suggestions. I will not have much time
until next week to
do anymore coding/testing/headbanging but will definately welcome any more
comments you
are willing to share and will incorporate them into the cookbook most
ricki-tik.
Thanks to Ron and Chris for lending a hand as we learn how to program for
this.
Tom
Date: 7 Aug 2002 17:55:17
Message: <3d519745$2@news.povray.org>
If you want to suspend the warnings about args no used from BCC, put the
following #pragma before each method where these warnings are declared.
#pragma argsused
Man, makes compiling and debugging a little less painful. :-)
Also there's a news group for help with the command line tools.
http://info.borland.com/newsgroups/cppnewsdesc.html#cppide
Look at borland.public.cpp.commandlinetools.
That's where I found the tip above.
Andrew Wilcox
Date: 8 Aug 2002 14:15:32
Message: <3d52b544$1@news.povray.org>
Here's the code I wrote to save the Enabled status of my GUIEXT.
There are two methods SavePrefs(InstanceStruct) and
LoadPrefs(InstanceStruct).
You need to define REGKEY_ROOT near the top of your guiext.c file.
I put mine near the #define AUTHOR, and #define EMAIL.
Something like:
#define REGKEY_ROOT "Software\\MyCompany\\MyGUIEXT\\"
This is the key under HKCU where the registry keys will be placed.
I catch the error codes, but right now nothing is done with them.
What should I do if an error occurs during this process? Just ignore it?
Set Enabled false? Popup a error dialog to the user? What's the desired
POV error handling approach for GUIEXTs?
void SavePrefs(InstanceStruct *Instance) {
LONG error;
DWORD dispositionValue;
HKEY guiextHKey;
DWORD value;
error = RegCreateKeyEx( HKEY_CURRENT_USER, // Parent hKey.
REGKEY_ROOT, // Path to child.
0, // reserved
"", // Type of node to create,
ignored if entry already exists..
1, // Behavior options
(volatile/non-volatile).
KEY_ALL_ACCESS, // Requested access to key.
NULL, // Security structure that we
don't have.
&guiextHKey, // The child's hKey.
&dispositionValue // Whether the entry was
create or simply opened.
value = Instance->Enabled ? 1 : 0;
error = RegSetValueEx( guiextHKey, // HKey to set the value on.
"Enabled", // The name of the value under the
hkey to set the value on.
0, // reserved.
REG_DWORD,
(BYTE*)&value,
4
if(error != 0) {
error = RegCloseKey(guiextHKey);
Instance->Enabled = TRUE;
SavePrefs(Instance);
} else {
Instance->Enabled = (DWORD)*data;
void LoadPrefs(InstanceStruct *Instance) {
LONG error;
HKEY guiextHKey;
DWORD type;
DWORD length;
char data[4];
0, // reserved
don't have.
&dispositionValue
error = RegQueryValueEx( guiextHKey, // HKey to set the value on.
0, // reserved.
&type,
data,
&length
DWORD WINAPI MenuSelect (IDataStruct *InstanceData, WPARAM Code)
InstanceStruct *Instance = (InstanceStruct *)
InstanceData->InstanceID ;
ExternalVarStruct ExternalVars;
switch(Code) {
case CM_ENABLED :
Instance->Enabled = !Instance->Enabled ;
CheckMenuItem (InstanceData->hMenu, CM_ENABLED +
InstanceData->FirstMenuItem, Instance->Enabled ? MF_CHECKED : MF_UNCHECKED)
SavePrefs(Instance); // *** Here's where SavePrefs goes.
return(0) ;
// READ THIS FROM AN INI FILE ! it should be persistent.
//Instance->Enabled = TRUE ;
LoadPrefs(Instance); // *** Here's where LoadPrefs goes.
Date: 8 Aug 2002 18:40:35
Message: <3d52f363$1@news.povray.org>
Could someone in the know explain the concept of
DisplayPlot;
DisplayPlotRect
WinPrePixel;
WinPostPixel;
WinAssignPixel;
I can log these events out to a file, so I see the order in which they are
called for each pixel as it is rendered. I looked (briefly) at the windows
source code, but it wasn't obvious to me, how these are useful to a GUIEXT.
Do these allow me to somehow change the final colour that is assigned to an
individual pixel, or make a modification to the colour POV has calculated?
Could someone give me an example of why a GUIEXT would catch these events.
I understand WinSystem, BufferMessage, and DragFunction. I'll probably ask
about ParseToolCommand later, since I don't forsee any need to mess with the
parser for my work.
And I want to again say thanks for the help Chris and Ron it is very very
much appreciated.
Date: 12 Aug 2002 14:28:25
Message: <3d57fe49@news.povray.org>
news:3d52f363$1@news.povray.org...
> DisplayPlot;
Called when a pixel is plotted to the display. Not called if running with -d.
> DisplayPlotRect
called as above, except for mosaic preview.
> WinPrePixel;
called before each pixel is plotted or written to a file, regardless of -d. you
can change the color info here (before the pixel is rendered).
> WinPostPixel;
ditto, but afterwards (you can change it as well).
> WinAssignPixel;
this gives you the actual color data that is finally written to the output file.
-- Chris
