POV-Ray : Newsgroups : povray.programming : Re: Type checking Server Time
8 Nov 2026 10:31:53 EST (-0500)
  Re: Type checking (Message 1 to 1 of 1)
Subject: Re: Type checking
Date: 9 Jul 2002 08:56:36
Message: <3d2add84@news.povray.org>
In article <fplliu8r1n8ljmk87pqt34s549kumg2m5k@4ax.com> , W„odzimierz ABX
Skiba <abx### [at] babilonorg>  wrote:
> On Tue, 9 Jul 2002 08:27:31 -0400, "cadman"
> <REM### [at] povraycouk> wrote:
>> The docs state that when using a #read directive into an already #declare'd
>> variable, POV will perform type checking.  I.e. I read that to mean that the
>> following shouldn't work:
>> #declare MyString="Hi mom!"
>> #fopen f "MyFile.txt" read
>> #read (f,MyString)
>> if Myfile.txt contains the text "<1,1,1>" (with no quotes)
>> But it does.  Is this a bug, or something I'm doing wrong?
> Can't verify this currently but perhaps this is connected with type checking
> when array entry is readed since you can't have different types in one array ?
> ABX
In any case, this is the wrong group for this discussion.  This group is for
discussion of the POV-Ray source code, not the documentation or usage of
POV-Ray.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
