Someone please correct me if I'm wrong...
There are no flags on the basic objects (e.g. Sphere) that differentiate one
from another. The only way to tell one from another is the method pointers
attached to the objects when they're initialized. Or to look at it another
way, you can poke them and see which way they run, but they don't have
nametags.
Related question...is there a body of documentation about POV-Ray internals
that I have yet to find? The documentation about how to use it is quite
extensive, and includes some overview of the ray-tracing process. I was
wondering if anyone had collected anypointers or FAQs about the internals
for those of us who want to venture there?
Thx,
Marc M. Adkins
> nametags.
Correct.
There is no need for nametags because the memory representation of objects
in the world/scene is write-only for the parser.
(With the exception of #declare/#local which allow to give a name to
a template object which might be later instancied with object{...} )
Nametags are only usefull in modelers.
Same goes for a Class identifier: it is not useful because it is done
by the method pointer.
Non Sine Numine
http://grimbert.cjb.net/
Puis, s'il advient d'un peu triompher, par hasard,
Ne pas être obligé d'en rien rendre à César,
Vis-à-vis de soi-même en garder le mérite,
Bref, dédaignant d'être le lierre parasite,
Lors même qu'on n'est pas le chêne ou le tilleul,
Ne pas monter bien haut, peut-être, mais tout seul !
internals
You may want to have a look at ftp://ftp.ru.com/pub/gamos/povpro/
Although that is a 3.02-based work, it does allow for examining scene
internals, and that did not change much since then. At least, should serve
as a good starting point...
