Would it be possible to simulate photons with the wave model of light? I'm
not a programmer, but I think this can be done. Also, are there any
physical situations where light acts as a particle? The only two I know are
the Photoelectric Effect and Blackbody Radiation.
__________________
Yours truly,
RAY
It would be quite difficult and heavy to simulate. Analytically it would
be probably impossible, and even numerically it would probably require quite
a lot of calculations.
> Also, are there any
For the effects which photons are used for, ie. caustics, it doesn't
matter how you model it. The result will be the same. Modelling them as
particles, that is, as rays, is just a lot easier and faster.
The situations where light acts like particles are such that they are
not visible to the eye and thus not useful in practice. One such situation
is when a photon can collide with a free electron, deviating its course
(I don't remember the name of this effect).
There are situations where the wave-nature of light is visible to the
naked eye, for example some interference effects. However, as I said, this
is just too difficult to model and seldom useful as well.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
"Warp" <war### [at] tag povray org> wrote in message
news:3c90ba08@news.povray.org...
>One such situation
Compton Scaterring
This is the Young double slit experiment. Check out this web site:
http://members.tripod.com/~vsg/interf.htm
Maan
On Wed, 13 Mar 2002 20:05:22 -0600, "RAY" <PCH### [at] yahoo com>
Frequency and phase, and thus interference, can be calculated quite
easily using the wave propagation equation. All you need is to convert
the rgb color of a ray into spectral data <g>
As of wave effects such as diffraction, I suppose the right answer
would be "no."
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
quite
> > Also, are there any
I meant to say visible.
So there are no visible reasons for POV to calculate photons as particles,
as waves are more realistic for photons?
I have found equasions for the wave aspect of light, with some functions
out of a Calculus/Physics book you can calculate photons with light's wave
aspect, correct?
Didn't you read what I wrote?
For caustics, which photons are used for, it doesn't matter how you model
the light. It's just that modelling light as rays is easier and faster and
more accurate.
Why do something a lot harder and slower to get the exact same image (or
even a worse image)?
particles,
model
> more accurate.
To do realistic refraction (two slit experiment) and if you can have the
camera rays do this, bending of light around objects (it's there, just VERY
slight).
__________________
RAY
I'm
Yes, I you could use the irid_wavelength for interference and diffraction
> would be "no."
I once saw some diffraction equations on a website. They were only for
slits, but I bet there are some formulas somewhere.
You could make a nice CD this way (or a diffraction grating) and have real
effects.
__________________
RAY
That's not refraction but interference, which is a completely different
phenomenon.
"RAY" <RAY### [at] yahoo com> wrote in message news:3c995155@news.povray.org...
VERY
> slight).
This is not refraction, but interference. Check Young's Experiment on this
subject.
Maan
> phenomenon.
The light refracts through the slits, causing the light not to be two
parallel lines.
__________________
RAY
In article <3c9a743a$1@news.povray.org>, "RAY" <RAY### [at] yahoo com>
> > phenomenon.
> parallel lines.
That isn't refraction, it is diffraction. Refraction is bending of light
at the interface of two media with different optical densities (which
doesn't have anything to do with their physical density).
Christopher James Huff <chr### [at] mac com>
POV-Ray TAG e-mail: chr### [at] tag povray org
They all sound the same ;-)
__________________
RAY
It is possible. Here is how I did it (crappily) a good while ago:
1. Sample a wavefront into a 2D matrix of complex values. This is
your light source.
2. Propagate this through the scene by either integration in the
space-domain (costly) or an appropriate fourier transform in
the frequency-domain.
3. Every intersection with an interface is a scalar adjustment to
the matrix.
4. Finally run the matrix thru a simulated lens to generate an
image.
Modern computers are not yet there to do this on anything but the
most primitive test scenes (ie Youngs slits experiment)
-tore
Do you have a pic of the results? I'm very interested in this kind of
experiments.
Apache
http://geitenkaas.dns2go.com/experiments/
apa### [at] yahoo com
