POV-Ray : Newsgroups : povray.programming : Wierd Idea Server Time
10 Oct 2026 01:06:06 EDT (-0400)
  Wierd Idea (Message 1 to 12 of 12)
Subject: Wierd Idea
Date: 29 Jan 2002 15:01:05
Message: <3c56ff81@news.povray.org>
Hi everyone,
I've had an idea as to a method of using an automatic algorithm to build
images from photos of a complex object, and was interested to see what
others thought of it...
The basic idea is using an 'evolving' system to add multiple objects to a
scene, working like most adaptive algorithms
1. Start off with a first guess approximation
2. Add random noise in the form of small objects/blobs in a different manner
to say 1000 test scenes.
3. Test each scene for similarity to the photos
4. Take the highest scoring models, and 'breed them' merging commands, then
repeat from step 2.
Run for several tens of thousands of iterations (anyone got a spare super
computer?) The lighting will have to be altered as well as the object
patterns...
What do y'all think? Any suggestions? Anyone with any experience in this
kind of coding?
Just a thought,
Luke
Subject: Re: Wierd Idea
Date: 29 Jan 2002 18:35:44
Message: <r6ce5ucdceko3t7o0j351jhql0k5kt3jbh@4ax.com>
On Tue, 29 Jan 2002 19:57:03 -0000, "Luke Church"
>kind of coding?
Given almost infinite time, what you'll probably end up with is a
large amount of small objects, each taking a pixel (or several), which
will only make sense when looking from a specific point in 3D space.
You can do that with a single iteration so why bother? :)
Peter Popov ICQ : 15002700
Date: 29 Jan 2002 19:06:59
Message: <3c573923$1@news.povray.org>
Certainly true if only one perspective is used. Sorry, I wasn't clear... I
was considering using at least 3 photos of the same object under similar
lighting conditions taken ideally at equal intervals around the object and
comparing all of them to the model...
The original idea for this was effectively a poor mans digitiser using an
algorithm to make up for not being able to afford to build proper sensing
equipment, with the hope of arriving at a more 'real looking' model of a
complex object that would otherwise be practical...
Thanks for the input, :)
Luke
Date: 29 Jan 2002 19:20:23
Message: <slrna5ef2b.l4n.ron.parker@fwi.com>
You could still converge to disjoint clouds of particles, each of which only
appears in one of the three (or whatever) views of the scene.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 29 Jan 2002 19:41:00
Message: <chrishuff-AD16C8.19432129012002@netplex.aussie.org>
In article <slr### [at] fwicom>,
That might actually be quite interesting...sort of an abstract sculpture
with an actual point. It might be worth making something that does
this...not a POV script, but a separate program that does a bunch of
renders with scanlining or some other technique to figure out the
information and then outputs the data, either as particles or voxel
data. It could save every 100th frame or so, and might produce results
within a reasonable period of time...
Date: 29 Jan 2002 22:13:58
Message: <2660626.5OnKVQPIDv@3-e.net>
A lot of work has already been done with generating 3d geometry from
multiple 2d images using techniques such as structured light.
http://www.prip.tuwien.ac.at/Research/3DVision/struct.html
> Luke
Date: 30 Jan 2002 17:31:35
Message: <4j4f5u0cgb2cs8gbjgt7jb4q48qsve030b@4ax.com>
On Wed, 30 Jan 2002 00:03:55 -0000, "Luke Church"
Ah, image reconstruction... there's a lot of info on that on the net.
For now, given almost infinite time, stick with this scenario:
1. Make a prism or cone with its vertex at location and its base
extending about as much beyond look_at. Have it pass through a pixel
of the image and be of approximately the same visual size.
2. Repeat for all pixels
3. Union all those cones
4. Repeat 1-3 for all viewpoints
5. Intersect all those unions
6. Grow old waiting :)
Date: 30 Jan 2002 17:46:43
Message: <mzd6zra23w.fsf@zefiro.peace.co.nz>
Ron Parker writes:
Applying a penalty to the "fitness" of the generated images which
increases as the number of objects increases might avoid that.  Large
render times could also be penalised.  Of course, that may increase
the number of iterations required.
Rohan
Date: 1 Feb 2002 08:35:06
Message: <3C5A9983.881AE27@namtar.qub.ac.uk>
But you can solve that just by using more reference photos. Might look
kewl anyhow!
signature{
Date: 3 Feb 2002 13:01:13
Message: <3c5d7ae9@news.povray.org>
Not so weird, use a genetic algorithm and remember to write a fitness
function which in some way ranks better less complex solutions (otherwise
you really end with a sphere for each voxel...).
By the way, it is a really interesting project!
Bye!!!
        Alessandro Coppo
        a.c### [at] REMOVEiolit
Date: 5 Feb 2002 15:49:36
Message: <3c604560@news.povray.org>
Ok everyone,
I think that I'll give it a go and see what happens... I'll keep you'll
posted when it comes out as beta. (Hopefully)
If anyone wants to know how it's going or has any further ideas to offer
feel free to email me or post somewhere round here, though I expect the
process to be slow, as I don't have a lot of spare time.
(Or more likely I'll be back asking for help)
BTW, a non-technical idea... Would it be possible to hold a database of
ideas currently in development in the Pov Community, so that information and
ideas could be shared and people might not 'waste' their time redeveloping
things that have already been developed or are in development... More than
once I begun developing an mini-app only to find about half way through that
someone else realises a version of it! My suggestion is a bit like perhaps a
micro-source forge, but without the hosting capability to save money...
Many thanks for your opinions,
Luke
Date: 6 Feb 2002 06:47:25
Message: <3C6117C5.388AB7B2@namtar.qub.ac.uk>
Grey Knight wrote:
> > which only appears in one of the three (or whatever) views of the
> > scene.
> kewl anyhow!
In fact, you might be able to *force* this behaviour by using an actual
image for one reference, and noise for the other two. Ta-da!
Instant(well, nearly) abstract sculpture thingy!
signature{
