POV-Ray : Newsgroups : povray.programming : POV-reg entries=? Server Time
10 Oct 2026 01:06:09 EDT (-0400)
  POV-reg entries=? (Message 1 to 20 of 20)
Subject: POV-reg entries=?
Date: 6 Nov 2001 17:48:26
Message: <3be868ba$1@news.povray.org>
Is there either a way to run POV without having actually run the install
program (i.e all program files but no registry entries) or an unofficial
compile that doesn't use the reg. entries? I'd like to be able to use POV at
school, but the security won't allow registry changes.
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
Subject: Re: POV-reg entries=?
Date: 7 Nov 2001 00:52:10
Message: <3be8cc0a$1@news.povray.org>
Mahalis wrote in message <3be868ba$1@news.povray.org>...
at
SkyPOV ( http://www.geocities.com/Rengaw03/povray.html ) can work without
the registry entries.  I developed it on my university's computers, and for
some reason, the install program won't run on them, so the registry entries
couldn't be set up.
Mark
Date: 7 Nov 2001 01:29:02
Message: <3BE8D4AF.D187F1B@gmx.de>
The Cygwin version does not need registry entries, but be aware it's just
text mode and also usually slower than the GUI version:
http://www.schunter.etc.tu-bs.de/~chris/povcyg/index.html
Date: 7 Nov 2001 07:12:10
Message: <3be9251a$1@news.povray.org>
Thank you. It still retains all the regular POV features, correct?
//Mahalis
"Mark Wagner" <mar### [at] gtenet> wrote in message
news:3be8cc0a$1@news.povray.org...
> at
for
entries
> couldn't be set up.
> Mark
Date: 7 Nov 2001 07:46:20
Message: <c1biut0kiurh2m60n53fudihsnnd6jm7lq@4ax.com>
On Wed, 07 Nov 2001 07:29:03 +0100, Christoph Hormann <chr### [at] gmxde>
And what is most important there is no (published) version of it for POV 3.5 *)
*) of  course I know it is beta time but it could allow test some slower
features on faster machines in my company without agresive changing enviroment
(they are important machines)
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 7 Nov 2001 08:50:13
Message: <3be93c15$1@news.povray.org>
It says it needs MegaPOV or POV 3.1 installed (and it also seems to want
that annoying HOME= entry in the registry), but the reason I was looking for
this kind of thing in the first place was because I couldn't run the install
program.
//Mahalis
> at
for
entries
> couldn't be set up.
> Mark
Date: 7 Nov 2001 11:54:39
Message: <3BE96750.E2C0E859@gmx.de>
BTW, it could turn out to be more difficult that you may think, the
-mno-cygwin flag only works with C and not C++ so you will either have to
use the Cygwin DLL (which would be problematic for a binary release) or
use the MinGW gcc instead.
Date: 7 Nov 2001 11:56:40
Message: <2tpiutotp1to2auo1lhkklj5j878p9fbs6@4ax.com>
On Wed, 07 Nov 2001 17:54:40 +0100, Christoph Hormann <chr### [at] gmxde>
have you tested DJGPP ?
ABX
Date: 7 Nov 2001 12:52:52
Message: <3BE974F2.D470F264@gmx.de>
No, but AFAIK that's a DOS port of gcc, not exactly what would be useful
here.
Date: 7 Nov 2001 13:17:52
Message: <3be97ad0@news.povray.org>
I'm not sure what you are talking about (is 3.5 written in C++?), but
compiling the "povcyg" version with mingw instead of cygwin is no problem, I
only had to change the pathes in the makefile..
#macro C(X,Y)cylinder{X*x<X,0,-Y/2>.1}#end#macro U(R,X,Y)intersection{torus{.9
.1}box{-1 0rotate y*R*90}translate<X,0,Y>scale 1-z*.5}#end union{U(0,0,0)U(1,0
,0)U(2,-1,-1)U(1,1,0)U(1,1.5,-3)U(1,2,0)U(3,1,0)U(2,2,0)U(0,3,0)U(3,2,.5)C(.1,
2)C(.8,1)C(.8,-1)C(1.1,1)C(1.9,-1)pigment{rgb 10}rotate x*90translate<-1,0,4>}
Date: 8 Nov 2001 02:01:29
Message: <3bea2dc9@news.povray.org>
Mahalis wrote in message <3be93c15$1@news.povray.org>...
for
install
>program.
Weird.  I didn't think I removed that for the final version.  It should
check for a Home= registry entry, and if it doesn't find that, it should
deduce the correct path from the path to the executable file, and if it
can't do that (which should never happen), it should use "c:\temp\workarea"
as the homepath.  The problem could be that it can't find the editor dlls or
that it can't find "colors.inc".
Mark
Date: 8 Nov 2001 03:33:32
Message: <1agkuts62utigs95u2iihtdangs11ane6l@4ax.com>
On Wed, 07 Nov 2001 18:52:50 +0100, Christoph Hormann <chr### [at] gmxde>
> here.
http://www.djgpp.org/
1) can't DOS port work as console version ?
2) as I know (I not tested this) DJGPP has libraries to compile windows apps
3) it compile C++ fine
4) I tested some time ago your cygwin compile with my djgpp compile of megapov
(or pov31) and IIRC your version was faster only a little
there is an important information about it
http://clio.rice.edu/djgpp/win2k/main.htm
ABX
Date: 8 Nov 2001 03:58:38
Message: <3BEA493C.217B9A85@gmx.de>
I suppose it will be quite different on 95/98/ME and NT/2k, using memory
consuming apps in the DOS emulation of NT is probably not very efficient.
Anyway, since Cygwin and MinGW should be perfectly sufficient i don't see
any need to use DJGPP.
Date: 8 Nov 2001 04:01:26
Message: <2dikut0dh3i1jdpioj2qkfdrm3436aibk8@4ax.com>
On Thu, 08 Nov 2001 09:58:36 +0100, Christoph Hormann <chr### [at] gmxde>
But I'm using it on NT. It works fine, fast and stable.
Right.
ABX
Date: 8 Nov 2001 06:31:33
Message: <3bea6d15$1@news.povray.org>
So I just need to copy SkyPOV into the Bin directory of POV 3.1 and it'll
work fine?
//Mahalis
news:3bea2dc9@news.povray.org...
> for
> install
> >program.
"c:\temp\workarea"
or
> Mark
Date: 8 Nov 2001 06:33:23
Message: <3bea6d83$1@news.povray.org>
I'm afraid, for me at least, I won't be able to use DOS either. The security
on these computers is so tight they're choking the life out of the people
who like to 'mess around' :-[
//Mahalis
"W³odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message
news:2dikut0dh3i1jdpioj2qkfdrm3436aibk8@4ax.com...
<chr### [at] gmxde>
efficient.
see
> Right.
> ABX
1}}
//ABX
1}}//POV35
Date: 9 Nov 2001 02:23:17
Message: <3beb8465@news.povray.org>
Mahalis wrote in message <3bea6d15$1@news.povray.org>...
>work fine?
Right.
Mark
Date: 9 Nov 2001 06:27:15
Message: <3bebbd93$1@news.povray.org>
Thanks.
//Mahalis
news:3beb8465@news.povray.org...
> >work fine?
> Right.
> Mark
Date: 9 Nov 2001 16:55:38
Message: <3bec50da$1@news.povray.org>
Well, I tried it out today and it still said it couldn't find the Home entry
in the registry.. Are you sure you took that part out?
//Mahalis
> >work fine?
> Right.
> Mark
Date: 9 Nov 2001 18:04:17
Message: <3bec60f1$1@news.povray.org>
So if 'colors.inc' isn't there, it won't work (or it will look for HOME=)?
That could be my problem. I'll check.
//Mahalis
> for
> install
> >program.
"c:\temp\workarea"
or
> Mark
