POV-Ray : Newsgroups : povray.programming : HF height: bug report Server Time
8 Nov 2026 10:21:53 EST (-0500)
  HF height: bug report (Message 1 to 20 of 20)
Subject: HF height: bug report
Date: 4 Aug 2001 20:38:54
Message: <3b6c959e@news.povray.org>
The following is an excerpt from express.c
(MegaPov 0.6a, lines 505 and below):
  if( hfield->Type & HFIELD_OBJECT != HFIELD_OBJECT )
    Error( "Cannot find height of non-height-field.\n" );
  if( ( Val < 0 ) || ( Val2 < 0 ) ||
    ( Val > 1 ) || ( Val2 > 1 ) )
      Error( "Height-field index out of bounds [0 1].\n" );
Since the precedence of 'not equal' is higher than that
of 'bitwise and', the very first line really means
  if( hfield->Type & 0 )
and thus the error message never appears. In fact,
optimizing compilers eliminate entire statement. I
quoted a little bit more than necessary just to illustrate
(and rant :-) how... unwise people use parentheses.
BTW (to those who are interested): this strange
precedence rule goes deep into the history of C...
From the very beginning, there were no such things
as 'logical and' and 'logical or' (that is, '&&' and '||'),
the only 'and' and 'or' operators were '&' and 'I',
respectively, serving as either logical or bitwise
based upon context ("truth-value-context"). When
their "pure logical" counterparts were introduced,
K&R were forced to stick with their current
precedence to maintain compatibility with existing
code.That's that.
Subject: Re: HF height: bug report
Date: 5 Aug 2001 07:34:15
Message: <3b6d2f36@news.povray.org>
A good compiler would issue a warning there (because the condition is
always false) and the bug would have been located immediately.
  However, as the POV-Ray source code issues about 10000 warnings I suppose
that no-one has full warnings turned on in their compilers (or if they have,
this specific warning gets buried under all the other 9999 ones).
  Warnings are always important and they shouldn't be taken lightly. This
ideology has not been followed in POV-Ray.
  Fortunately now that POV-Ray will be written in C++ it will be possible to
completely get rid of all warnings (C++ allows getting rid of certain
warnings the C version has and you can't do anything about it: Unused function
parameters: Just don't give the parameter a name).
Date: 5 Aug 2001 09:22:14
Message: <3b6d4886@news.povray.org>
In article <3b6d2f36@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
This bug is actually one of the many code quality problems in MegaPOV.  A
good developer should know which warnings are informative and which are more
like non-fatal errors.  Turn off the float-double conversion warning and you
get only very few warnings.
For example, would you consider the legal code ISO C/C++ "long I = 'abcd';"
worth a (by default on) warning?  Well, the gcc developers think so...
    Thorsten
e-mail: tho### [at] trfde
Date: 5 Aug 2001 09:23:53
Message: <3b6d48e9$1@news.povray.org>
In article <3b6c959e@news.povray.org> , "Vadim Sytnikov" <syt### [at] rucom>
This particular feature will probably be removed in future versions of
MegaPOV as it is not part of POV-Ray 3.5.  The suggested method is to use
"trace".
    Thorsten
Date: 5 Aug 2001 11:59:20
Message: <3b6d6d58@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote in message
news:3b6d4886@news.povray.org...
'abcd';"
Yes, definitely. Although it's legal, it is implementation-defined
(i.e. the characters are mapped into the execution character set
in the implementation-defined manner). BTW, that's the reason
behind the MKFOURCC macro in Windows.h.
That's especially important for POV-Ray. Just imagine porting code with
that constant to, say, ancient Honeywell Bull with 36-bit chars...
Date: 5 Aug 2001 12:57:38
Message: <3b6d7b02@news.povray.org>
In article <3b6d6d58@news.povray.org> , "Vadim Sytnikov" <syt### [at] rucom>
Exactly that is my point.  It isn't the business of the compiler to lecture
the programmer about the language definition in such a case.  It is clearly
specified as resulting in an implementation defined integer constant.  This
is a well-defined behavior and if the programmer isn't aware of it, i.e. by
doing a comparison like 'abcd' > 1234 it is at least very bad style (nearly
programming error).  However, declaring i.e. an enumeration with
multicharacter constants is fine, after all comparing an enumeration value
against an integer constant is bad style.
So why should a compiler issue a warning about something that is absolutely
legal?  Well, the simple answer is that it should shut up by default and
assume the programmer knows the standard.  A compiler should not assume an
incompetent programmer by default - and a multicharacter constant can hardly
be considered accidental.  Or should a compiler warn i.e. in a case like
"int i = 01;" because the programmer might have meant to write "0"?  If i
write a multicharacter constant I mean it, and it is a perfectly legal
program on every platform, thus the compiler does no need to "comment" it.
So because some stoneage non-standard hardware and software it has to be on
on every 32 and 64 bit processor?   I like that ... after all there is
nothing wrong with a character constant on a 36 bit system.  Of course it
would be different if the resulting value would not _fit_ into an "int".
But obviously a four character constant fits will into a "int" on every 32+
bit system.  On a system with 16 bit "int"s it would of course be
appropriate if the compiler would issue an error (or warning) if a constant
is out of range!
On the other hand, to force the programmer to use tricks to get the compiler
to shut up is far more dangerous and leads to bloated and unreadable code.
The programmer is the master of the compiler*, not the other way around!!!
    Thorsten
* IMO, very ambiguous code should be considered an error and there would be
no default warnings at all in a really good C/C++ compiler.  Of course, a
well-specified and implemented language would not have such problems in the
first place <sigh>
Date: 5 Aug 2001 17:41:21
Message: <3B6DBB69.3DA0F6F0@faricy.net>
POV gives about 10000 warnings on what warning level?  I keep my copy of
msvc on level 3.  On level 4 (highest) I get tons of crap I don't care
about like "assignment in conditional expression."  I know, that's what
I want!  On level 3 though I always try to get rid of the warning
messages my code makes.
But then, is msvc a "good compiler"?  ;)
(ya know, like "if( !(fil = fopen(...)) )")
Date: 5 Aug 2001 19:58:32
Message: <3b6ddda7@news.povray.org>
In povray.unofficial.patches Thorsten Froehlich <thorsten@trf.de> wrote:
: Or should a compiler warn i.e. in a case like
: "int i = 01;" because the programmer might have meant to write "0"?
  Actually 01 is an octal number ;)
  (In fact, that's another place where you can shoot yourself in the foot
with C. You might sometimes write something like "i = 011;" to "indent" the
number with other similar numbers and then you are surprised when the
program behaves very strangely...)
  This is actually one place where the compiler assumes that the user
really wanted an octal number and that it wasn't just a mistake.
Date: 5 Aug 2001 23:17:31
Message: <slrn9ms32e.2h8.ron.parker@fwi.com>
and is distinct from 0l.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 6 Aug 2001 07:03:06
Message: <3b6e796a$1@news.povray.org>
In article <3b6ddda7@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Exactly.  And in my example (unlike 011) it wouldn't even make a difference
if one wrote 01 or 1.  So why does it make a difference if I write 'ab'? --
Both are features of the language.  They are both a bit "unexpected", but
still perfectly legal!
    Thorsten
Date: 5 Aug 2001 09:14:16
Message: <3b6d46a8@news.povray.org>
Unfortunately, such things are not C-specific, and thus C++ is
not a panacea. They are tackled differently, yes, but I dare say
C is not worse at that.
For example, those unused function parameters you mention. For
decades, it's been a good C programming habit to write an extra
statement like this
    (void) my_unused_function_argument;
to prevent compiler from generating a warning. I'm pretty sure I
could point out a C counterpart of every "C++ feat" in that area.
Not to say that lint is by far stricter than any C++ compiler.
You're rigth in that warnings shouldn't (must not, I would say) be
taken lightly. Somebody must take care of that.
Warp <war### [at] tagpovrayorg> wrote in message news:3b6d2f36@news.povray.org...
suppose
have,
to
function
Date: 6 Aug 2001 08:50:54
Message: <3b6e92ae$1@news.povray.org>
There is a HUGE difference between the two.
On any machine, both 01 and 1 (decimal) get translated into
0x00000001 (hex).
While 'ab' may be translated into 0x00006261, or 0x00006162,
or god knows what. The Standard does not define that.
Somebody has pointed out that using multicharacter constants
would be OK in enums... Not quite so. Multicharacter constants
do not define lexical order. What you can (only!) do with enum
elements defined as multicharacter constants is to compare then
for equality; you cannot tell which is bigger and which is smaller.
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3b6e796a$1@news.povray.org...
foot
the
difference
'ab'? --
>     Thorsten
Date: 6 Aug 2001 13:34:54
Message: <3b6ed53e@news.povray.org>
In article <3b6e92ae$1@news.povray.org> , "Vadim Sytnikov" <syt### [at] rucom>
And what is wrong with this???  Why would I even care about the integer
value?  Simple: In a properly written program, I do not (see below)!
Quite so.  It works very well and is widely used (examples: TIFF, TrueType
fonts, Mac OS, Windows, etc).  Please don't make a problem out of something
where there is _none_ and has never been in the past two decades except in
the minds of the writers of a certain compiler who seem to have been locked
in their ivory tower for too long ;-)
programming error).  [...]  after all comparing an enumeration value against
an integer constant is bad style. <<
    Thorsten
Date: 6 Aug 2001 14:11:43
Message: <3b6edddf$1@news.povray.org>
Ah, well, well... Thorsten, take this:
How are you going to *reliably* save and restore your data?
In programs made with different compilers (let alone on different
platforms)? (Please don't say "I don't want to save my data!"
You do. And please don't resort to indexing or other tricks).
There is a known way of doing this for integer values: write
byte-by-byte, then restore byte-by-byte (doing proper shifts
and additions); POV-Ray does exactly that when, say,
loads tga files.
Save your 'long' with multibyte constant (by whatever method),
then just recompile your program with different compiler, then
load your 'long' back. There is *absolutely* NO guarantee that
the following, or anything you could devise, will work:
  enum my_enum_t { MY_MB = 'ab'; };
  long my_long = MY_MB;
  if( must_save )
     // PART1: save by whatever method
  if( must_load )
    // PART2: load by whatever method
  if( my_long != MY_MB ) { /* shit happens... */ }
If PART1 is executed in the program compiled with one
compiler, and PART2 -- in that same program but compiled
with another compiler, then you *will* get into the last set
of curly braces sooner or later.
We all know Microsoft's attitude to portability, and yet
their exists the MKFOURCC() macro. Guess why.
news:3b6ed53e@news.povray.org...
<syt### [at] rucom>
something
locked
(nearly
against
>     Thorsten
Date: 6 Aug 2001 15:12:59
Message: <3b6eec3b@news.povray.org>
In article <3b6edddf$1@news.povray.org> , "Vadim Sytnikov" <syt### [at] rucom>
I knew you would say this despite my _clear_ hint that it is no problem
(TIFF and TrueType are both cross-platform file formats and I have still to
see them not being readable anywhere).
* Let me deal with the cross-platform issue first (because its short to
answer):
As you know byte order is always an issue, so any storage format will have
to be specified in such a way that it is portable.  You simply can't store
the raw data, it won't work most of the time.  There are very different
formats for many other things, not just multicharacter constants.  Non-IEEE
floating-point numbers are just one example.
* Now to the cross-compiler issue:
Storing raw structures?  Again a very bad idea and not because of
multicharacter constants.  For example data alignment in memory.  Different
compilers may decide to use a different alignment of struct elements.  Not
to say that i.e. storing raw structures is a bad idea when it comes to more
complex data that i.e. has pointers in the structs so you end up having to
fix those anyway.
But even if all these were the same because of some common standard on that
particular platform (it is not uncommon to agree on common formats, or
formats set by some dominating force on a platform), then how likely is it
that the platform's compiler struct standard doesn't cover multicharacter
constants?
Further, if you define the file format you will have no other way but to
define it in such a way that the meaning of every byte is clear.  As you
have to do it anyway (i.e. it is even possible to have different byte orders
on the same platform) there is no additional work needed to do it for
multicharacter constants just like for any other type!  So again, here they
require no additional work that wouldn't be necessary for each and every
other data type.
Basically, you are confusing two things here: Cross-platform/compiler design
and unspecified implementation of data formats.  Both are _not_ the same
problem.  They are two very distinct problems:
The C/C++ standards also lets the representation of an integer as
implementation defined. There isn't even anything in there that says
integers have to have the same representation using different compiler on
the same platform.  However, you assume the format is the same for integers
but deny it for multicharacter constants?
Of course, by agreement on one platform the format of integers will probably
be the same, but it doesn't have to be!!!
So, if you observe all used compilers on one platform you will probably find
out that the representation of every built-in type (at least with some
compiler switch) will be the same.  In conclusion, it is reasonable to
assume (as you did with integers) cross-compiler issues that cannot be
worked around without modifying the source code on a particular platform do
not exist (sorry for this complicated sentence).
In summary, there is no cross-compiler-same-platform problem _specific_ to
> there exists the MKFOURCC() macro.
What the macro is actually doing most of the time (not always!) is add
enough garbage to get certain compilers to not complain about the
multicharacter constants.  Apart from this, it can only change the bit
order, which in turn, assuming some common sense and will only be an issue
of byte order.  This in turn will be covered by the regular byte order
conversion you need to do anyway when reading/writing from/to disk
Of course, if someone thinks there is a particular brilliant better format
(after all the format isn't defined at all by the standard) than storing
each character in one byte in either little or big endian you would need to
to more, but there is always something like "common sense" (see above).
However, all this macro does has nothing to do with disk storage in the
first place!
    Thorsten
Date: 6 Aug 2001 17:27:31
Message: <3b6f0bc3@news.povray.org>
Thorsten,
(if you would like to answer, please: provide code snippets
or something; not just general thoughts)
I asked you about aportable way of storing/loading of a
*single* number. You failed? You started to talk about non-IEEE
fp numbers... Thorsten, I state that non-IEEE numbers
represent a lesser problem then multicharacter constants.
If your platform/compiler deal with such numbers, for some
reason, you still can output them as, say
  fprintf( my_file, "%g", my_non_IEEE_number );
and then *reliably* read in (on a different platform) as
  fscanf( my_other_file, "%g", &my_IEEE_number );
With your multicharacter constants, what are you going to do?
Your assumption about integers' representation not been
standartized is, again, wrong. According to ISO, there is a single
possible representation for unsigned integers, plus several
possible representations for signed numbers. If I were
concerned about portability of signed integets (which is normally
not the case), I would store them as n-INT_MIN, and, after
reading, would convert to n+INT_MIN. That would be rock-solid.
Now about MKFOURCC -- you just don't understand. You write:
The keywords here are 'byte order conversion'. Even just the term
'order'. This statement implies knowledge of that 'order'. And you
always have that, on each platform -- for short, int, long, float, double,
whatever -- but not for multicharacter constants. Endianness is
one thing, storing characters within long is another thing. You *first*
pack characters into 'long' (this is governed by some INTERNAL
compiler rules, UNAVAILABLE to mere mortals), and *then* put
that 'long' into memory (this is governed by 'endianness').
That's just plainly non-portable. To be able to convert, you have to
know *WHAT* on Eath do you have.
Phew...
Date: 6 Aug 2001 19:22:17
Message: <3b6f26a9@news.povray.org>
In article <3b6f0bc3@news.povray.org> , "Vadim Sytnikov" <syt### [at] rucom>
Code for what?  Portable reading/writing of multicharacter constants?  As I
have now pointed out, reading and writing to disk of any binary
representation of any basic type is implementation dependent!
> fp numbers...
And where is the difference?  There is *no* portable way to write any binary
representation of basic types.  I tried to explain it, but it seems I did
not succeed :-(
If you have found a solution how write fully portable code (obviously
without conditional compilation) that can write binary representations i.e.
of the basic type "int" I would really like to see it!
Well, from your statement
    "There is a known way of doing this for integer values: write
    loads tga files."
and the previous discussion I concluded that you were talking about binary
files, not text files.  Obviously I am talking about binary files (what else
are TIFF or TrueType files?)
Further, what do text files have to do with your problem with multicharacter
constants?
And can you prove it?
As far as I know, the C library specification is missing functions that
output multicharacter constants.  Of course, for a C library (as it is
usually specific to a compiler to some extend), it would have been no
problem to specify such an output format in the standard.  Don't blame me
for this not being in there...
Where?  In my copy of ISO/IEC 14882:1998(E) (ISO C++ Standard) I cannot find
any such specification.  To the contrary, section 3.9.1 _only_ specifies
that "Plain ints have the natural size suggested by the architecture of the
execution environment; the other signed integer types are provided to meet
special needs".  For unsigned numbers it only requires that they have the
same size, alignment requirements and "obey the laws of arithmetic modulo
2n".  The whole section, nor the whole standard contains a normative
reference to any other ISO standard that defines any of the basic types'
formats.
In particular, "even if the implementation defines two or more basic types
to have the same value representation they are nevertheless different types"
is important if you understand the term "implementation" (3.9.1.10) - in
short it refers to the compiler and thus it is up to the compiler, not the
architecture (of the platform) to specify the size of basic types!
Well, do you _know_ the byte order of an integer?  How so, it is also
"governed by some INTERNAL compiler rules" according to the ISO C/C++
standards (as I pointed out above)!!!
All you can know is the maximum value you can store in an integer, but you
know next to nothing about its internal representation.  In fact, the byte
order of integers, or to be more general the representation of all basic
types is completely transparent and there is no standard method to determine
it in a program in a portable way!
Indeed, this is the root of all cross-platform problems:  The C/C++
standards don't specify internal representations in order to allow you they
most flexibility when doing low level programming with a specific
compiler/platform combination.  For the standard there is no "world" outside
a single implementation of the standard.
Thus, all assumptions you make are based on your observations or good
compiler documentation, but not because they are specified that way in the
C/C++ standards!  Essentially you have proven that the information you claim
to be "UNAVAILABLE to mere mortals" is available to you because if you know
unspecified implementation dependent details like "short, int, long, float,
double".  So, using the same method you used to obtain this information can
be used to obtain the implementation dependent format of every basic type's
data, and surely the implementation dependent details of multicharacter
constants - you forgot that multicharacter constants, by specification, are
integers.  As the number of integers is finite you can obtain the
representation of every multicharacter constant in every implementation
without exception.
However, you will never need to do so because all (existing) implementations
of ISO C++ use one byte ASCII characters and store the value of each byte of
each character of a multicharacter constant either starting with the highest
or lowest byte and then following the obvious order.  Of course, this is not
part of the standard, but if you assume it and test you won't have to use
the method I outlined above in order to determine the value of every
multicharacter constant without this assumption.
> know *WHAT* on Earth do you have.
Contrary to your claim above I have shown that it is possible to determine
the integer representation of every possible multicharacter constant.  Thus,
multicharacter constants are portable because the all implementation details
can be determined and proper action can be taken when reading/writing
In summary, I get the impression you assume good C/C++ code will always be
portable *without* any implementation specific changes.  This is plain
wrong.  The very nature of C/C++, by targeting a range of applications from
GUIs to kernels and drivers, and the language specification itself
explicitly trade portability for low-level programming options in many
places.
    Thorsten
Date: 7 Aug 2001 10:40:04
Message: <3B6FFDD9.4D82F1E5@aicoss.de>
> statement like this
Which will issue another warning like "code has no effect".
Which I get. ;-)
You can always get rid of all warnings. And I tend to try
that (not always being succesfull). But I have a small system
developed by me and my company which is well over 150000
lines of code and issues exactly 4 (four) warning like the
above.
Markus
Date: 7 Aug 2001 10:48:09
Message: <3b6fffa9@news.povray.org>
Markus Becker <bec### [at] aicossde> wrote:
: You can always get rid of all warnings.
  But you should do it the right way.
  Making awful code just in order to keep the compiler happy is not the
right way.
Date: 7 Aug 2001 13:52:47
Message: <3b702aef@news.povray.org>
>> statement like this
> Which I get. ;-)
> above.
And of the 300000 lines on the project I'm working on now (about 30-50% at a
rough guess, written by me), we generate *no* warnings at all, on three
*different* compilers, and without resorting to compiler ifdefs except with
regards to the libraries provided with the compilers themselves.
It both is possible and desireable to write code without warnings.  The
patch I'm writing for POV regularly gets checked and fixed for such things.
Geoff
