POV-Ray : Newsgroups : povray.programming : Adding a new object Server Time
10 Oct 2026 01:05:39 EDT (-0400)
  Adding a new object (Message 1 to 17 of 17)
Subject: Adding a new object
Date: 3 Aug 2002 02:34:02
Message: <3D4B7962.DF754423@hotmail.com>
There are a couple of primitives I'm thinking of suggesting for V4.
Since I'd like to do all the legwork for implementing these primitives
(writing the ray intersection tests, automatic bounding calculations,
etc), so that the suggestion will put less work on the POV-Ray team,
excatly what functions are needed to fully support a primitive
under POV-Ray?
John
Subject: Re: Adding a new object
Date: 3 Aug 2002 06:31:43
Message: <3d4bb10f@news.povray.org>
> under POV-Ray?
  Would it be possible for you to mention which types of primitives are
you thinking about?
Date: 3 Aug 2002 17:01:49
Message: <chrishuff-BE646E.15523903082002@netplex.aussie.org>
In article <3D4B7962.DF754423@hotmail.com>,
> under POV-Ray?
Well, POV 3.5 uses methods that compute the normal, insideness of a
point, all intersections with a ray, UV coordinates, copy/destroy the
shape, invert the shape, and the various transformations (translate,
rotate, scale, and transform). There are also functions for creation and
computing bounding boxes, and sometimes others. Make a 3.5 patch and it
shouldn't be too hard to adapt for 4.0, but it is likely you would have
to rewrite most of the code, and there could be very different
requirements.
Going to give any hints as to what you are planning? ;-)
Date: 5 Aug 2002 14:46:53
Message: <3D4EC82C.C892E71F@hotmail.com>
> are you thinking about?
Two rather ambitious ones:
First, incorporate quadrilaterals into the mesh object.  This would
make polygon modelling simpler.
Second, a recursive object (ie, a fractal).
John
Date: 5 Aug 2002 17:43:51
Message: <chrishuff-D1FC98.16334605082002@netplex.aussie.org>
In article <3D4EC82C.C892E71F@hotmail.com>,
That wouldn't really be a primitive, just an addition to the mesh
syntax. Probably quite easy, just look at how it parses triangles and
add code to parse a quad instead, splitting it into two triangles to add
to the mesh.
Like an L-system? That would be very interesting...I haven't done
anything with them. Not sure how useful it would be though.
Date: 6 Aug 2002 03:33:49
Message: <3d4f7bdd@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
Why not just script one?
...Chambers
Date: 6 Aug 2002 10:51:07
Message: <3D4FE2EF.8010907@free.fr>
> to the mesh.
Why stop at the quadrilateral, let's have also a plain polygon
(no hole) in the mesh parser (while still storing only triangles).
Then handling the quadrilateral is just a subcase of the generic polygon.
Date: 6 Aug 2002 12:57:16
Message: <chrishuff-D43982.11471206082002@netplex.aussie.org>
In article <3d4f7bdd@news.povray.org>,
Simple: slow parsing. Since POV 4.0 will probably use a VM for the
language, that isn't such a big deal for the future.
Date: 6 Aug 2002 15:02:46
Message: <3D501D67.23725A51@hotmail.com>
To allow memory to be saved (at the expense of rendering speed, but
some people would welcome that).
John
Date: 6 Aug 2002 15:07:30
Message: <3D501E84.99B8A6AD@hotmail.com>
> > and add code to parse a quad instead, splitting it into two
> > triangles to add to the mesh.
> polygon.
I was actually thinking of storing the quads as quads, internally,
on the guess that they can be optimized to the point that they render
faster than the two triangles that would replace each.
Maybe not.
I'm also working on my subdivision surface macros, and have found a
way to extend the Loop surface to support quadrilaterals in addition
to triangles; hence my interest in adding that to the mesh.
John
Date: 6 Aug 2002 18:20:03
Message: <3d504b93@news.povray.org>
  What would be the advantage of this over using two triangles?
Date: 7 Aug 2002 03:37:55
Message: <3D50CE54.50901@free.fr>
None for native pov, but when converting other 3D mesh formats, some
of them do not stick to the triangles and have either quadrilaterals,
or simple polygon ("simple", because not like the Pov polygon object).
So supporting the polygon in mesh would allows an easier writing of the
conversion programs.
Date: 9 Aug 2002 13:31:33
Message: <3D53FC78.58CDC5DE@hotmail.com>
When something is extruded, it makes more sense to extrude edges as
quads rather than a pair of triangles.
It also makes it easier to deal with a problem involving the Loop
method of surface subdivision.
John
Date: 9 Aug 2002 16:39:31
Message: <3d542883@news.povray.org>
I have another advantage: UV-mapping a quadrilateral consisting of two
triangles simply doesn't work right. A true quadrilateral with properly
implemented UV-mapping would work right.
  Of course this poses a problem: How do you texture an UV-mapped
quadrilateral in patological cases (eg. when it's concave)?
Date: 10 Aug 2002 04:00:02
Message: <3uh9luos2jm4g4i745e1berj6jonbuda9h@4ax.com>
I can tell you how to do the forward operation (i.e. from uv to xyz),
but I gave up trying to reverse it, although I am dead sure it has a
unique solution.
Peter Popov ICQ : 15002700
Date: 10 Aug 2002 10:30:18
Message: <3d55237a@news.povray.org>
By the way, this scene demonstrates the problem with uv-mapping when
using two triangles to make a quadrilateral (AFAIK there's no way to
avoid this effect):
camera { location -z*4 look_at 0 }
mesh2
{ vertex_vectors { 4, <-2,-1.5,0>, <2,-1.5,0>, <1,1.5,0>, <-1,1.5,0> }
  uv_vectors { 4, <0,0>, <1,0>, <1,1>, <0,1> }
  face_indices { 2, <0,1,2>, <0,2,3> }
  uv_mapping
  texture
  { pigment { gradient x color_map { [0 rgb 0][1 rgb 1] } scale .1 }
    finish { ambient 1 }
  A true quadrilateral could interpolate the texture along the whole
quadrilateral instead of the two separate triangles, giving a more logical
result.
Date: 11 Aug 2002 08:45:04
Message: <3D565C55.A6BC827F@hotmail.com>
> two triangles simply doesn't work right. A true quadrilateral with
> properly implemented UV-mapping would work right.
Put a warning in the docs that it may not work right...
