POV-Ray : Newsgroups : povray.programming : Scattering In POV Ray Server Time
10 Oct 2026 06:15:44 EDT (-0400)
  Scattering In POV Ray (Message 1 to 4 of 4)
Subject: Scattering In POV Ray
Date: 23 Aug 2000 08:19:55
Message: <39a3c16b$1@news.povray.org>
Hi
Fromt what I understand, wave independent scattering is not physically
accuarate since it doesn't take the wavelength into account, but to be
honest
I don't really understand the principal of that. (Some sort of a detailed
explanation would help!!)
I also need the precise algorithm POV Ray uses for Rayleigh scattering and
how it could be modified so that it becomes Wave dependent.
I need this information asap PLEASE.
Thank you
Ammar
Subject: Re: Scattering In POV Ray
Date: 27 Aug 2000 22:43:35
Message: <39a9d1d7$1@news.povray.org>
"Ammar Al-Allak" <a.a### [at] ueaacuk> wrote...
> Hi
> honest
Making it fully wave-dependent would be nearly (if not fully) impossible,
because POV uses the RGB format to store all colors.  This means that the
specturm is discritized into three steps - red, green, and blue.  This
leaves very little information to be used by wavelength-dependent features.
However... scattering can be color-dependent.  Note that I say
color-dependent and not wavelength-dependent... they are different.  Used
properly, you can make color-dependent scattering look a whole lot like
wavelength-dependent scattering.  For example, some work has been done using
scattering type 4 to simulate earth's atmosphere (using scattering type 2
for clouds within the atmosphere).  Using a bluish color for scattering,
with an appropriate density and an extinction of 1.0 generates a nice blue
sky.  And when the light source (sun) is rotated around this virtual earth,
nice pink and red sunsets appear almost magically.  I did some tests a while
back (based on someone else's original code) and it worked very well (though
it was _very_ slow).
The source code can be downloaded from www.povray.org.  That, plus the docs,
should be sufficient for determining the exact algorithm.
-Nathan
Date: 28 Aug 2000 04:34:14
Message: <39AA23C1.F993134D@yahoo.com>
where can one find these tests you did?
> > Hi
> > honest
> -Nathan
Date: 10 Oct 2000 13:41:20
Message: <39e354c0@news.povray.org>
"Nathan Kopp" <Nat### [at] Koppcom> wrote in message
news:39a9d1d7$1@news.povray.org...
features.
using
earth,
while
(though
Can you point me to where I might find any examples of what you describe
here?
Thanx..
