POV-Ray : Newsgroups : povray.programming : Povray compile with cygwin Server Time
15 May 2025 15:23:51 EDT (-0400)
  Povray compile with cygwin (Message 1 to 7 of 7)
Subject: Povray compile with cygwin
Date: 1 Jul 2000 03:36:50
Message: <395D9F92.2BC814EC@schunter.etc.tu-bs.de>
I was trying to compile the plain unix source of povray with cygwin version
1.1.2 to get a textmode version for windows and to later try Chris Huff's new
patch.
Everything went fine without any modification! I was able to render some scenes,
but the file output was always totally black, no matter what fileformat I
specified.
Anyone who had similar problems in the past or who could help otherwise ?
Subject: Re: Povray compile with cygwin
Date: 1 Jul 2000 09:42:40
Message: <chrishuff-50F31A.08424701072000@news.povray.org>
In article <395D9F92.2BC814EC@schunter.etc.tu-bs.de>,
> version 1.1.2 to get a textmode version for windows and to later try
> Chris Huff's new patch.
> some scenes, but the file output was always totally black, no matter
> what fileformat I specified.
Was this before adding my patch, or after?
Date: 1 Jul 2000 09:46:42
Message: <395DF642.3E55BFF6@schunter.etc.tu-bs.de>
For the first tries I only used the official version.
Date: 4 Jul 2000 09:39:16
Message: <3961E91B.2C0B0B39@numerik.uni-kiel.de>
Try the output format ppm, and see why the output is black, either it is
just written black, or the pic is empty.
If we'd know which, this could help quite a lot.
(ppm is easy, just look at it in a editor).
Axel
Date: 4 Jul 2000 11:24:50
Message: <396201BF.F4F4F39F@schunter.etc.tu-bs.de>
> Axel
The problem occurs with all file formats (ppm, tga compressed/uncompressed, png)
All files are generated with correct header and filesize but all pixels are
black.
Date: 25 Jul 2000 14:01:58
Message: <397DD366.746BB15A@global2000.net>
Did you use light_sources?
Brendan
Date: 25 Jul 2000 14:47:17
Message: <397DE0C0.EDCEF460@schunter.etc.tu-bs.de>
> Brendan
Yes, i took several simple scenes that render just fine with the official
compile, but i get black output.  Render statistics are also indicating that it
actually renders the scene, when turning display on (+d) i also get no output,
so it's probably not just the file writing routines.
BTW, If anyone has made a textmode version with another compiler i would be
interested too.
